trnswrld
Question About Wing Flex. Newer Aircraft Vs Old
Sat May 25, 2013 10:00 pm
Sorry if this is a topic that has been talked about before, but in a brief search nothing came up that got into what im talking about.
So I have been wondering for some time now about some of the details regarding wing flex. Why did older aircraft not really experience this where as most newer large aircraft have in some cases extreme flexing of the wings? For example I do not recall seeing aircraft such as the DC-10, L1011, 707, A300, even the classic 747s with very large wings had minimal movement of the wings. Sure they bounce up and down in turbulence, but im more so talking about heavy takeoffs where you see those wings flexing and doing so much work lifting all that weight. It seems that the first large aircraft that had wings that really flexed was the 767. Nowadays aircraft like the 744/748, 787, A330 etc etc have wings that move significantly depending on the phase of flight and weight etc etc.
So with all that said what has changed in the materials and design of wings over the years that causes such significant movement of the wings and larger aircraft starting with the 767? I'm just taking a guess here, but were older aircraft over engineered or something along those lines? How can an airplane such as a DC-10 or a 747-100 with such large wings have such minimal flex even on max weight takeoffs?
Thanks for any information regarding this subject.
hh65man
RE: Question About Wing Flex. Newer Aircraft Vs Old
Sat May 25, 2013 10:43 pm
Ever seen the wing flex on a B-52? From the early to the current models. The B-52 has been been flying for as long as ive been alive. It's quite impressive.
Sun May 26, 2013 8:38 am
Quoting TrnsWrld (Thread starter):
As HH65MAN says, it really depends on the aircraft. Certainly a stiffer wing needs to be stronger, and thus heavier. If you can get away with more flex without flutter and such, it may well allow a lighter structure.
The 747 classic did flex a lot!
akiss20
Sun May 26, 2013 10:33 pm
The increasing use of composites will also result in next gen aircraft having a lot more wing flex than before. Composites enable aspect ratios we used to only dream about, resulting a lot "floppier" wings
Change will not come if we wait for some other person or some other time. We are the ones we've been waiting for. We are
LH707330
Mon May 27, 2013 4:57 pm
Quoting akiss20 (Reply 3):
I would add CFD as a factor for higher aspect ratios. Since the first jets, aerodynamicists have been able to reduce sweep, thicken and lengthen the wing, and maintain a .83-.85 cruise. Don't the A330s have the highest aspect ratio (10.06 IIRC) out there with a metal wing?
flyingturtle
Mon May 27, 2013 7:03 pm
Quoting LH707330 (Reply 4):
Vickie Pedia says the Dash 8 Q400 has 12.8.
David
LH707330
Mon May 27, 2013 7:29 pm
Quoting flyingturtle (Reply 5):
Fair point. Of widebody jets, I think the A330 is up on the podium though.
YQBexYHZBGM
Fri Sep 20, 2013 9:57 pm
I recall 727s having much more wing flex than any other aircraft I have flown on, including DC9 / MD80 variants which, like the 727, lack wing-mounted engines that would tend to dampen the flex effect. I've never noticed much flex at all on the CRJ or ERJ, which also have rear engines, but whose wings are much smaller and shorter than those of the 727.
Al
YQBexYHZBGM
CALTECH
Sat Sep 21, 2013 12:03 am
Quoting HH65MAN (Reply 1):
IIRC, the B-52 had a wing flex of 17 feet at the tips. When they came in after a flight, if one wing had substantially less fuel than the other one, had to get a stand to put in the outrigger gear pins.
http://cdn-www.airliners.net/aviation-photos/photos/1/0/8/1400801.jpg
UNITED Would Be Nice
Users browsing this forum: gtae07, Miguel1982 and 2 guests
