alberchico
Do Small Patrol Aircraft Carry Lavatories?
Mon May 27, 2013 7:29 pm
I've noticed that there are several small surveillance and patrol aircraft either in service or development.
http://www.diamond-sensing.com/index.php?id=da42mppguardian
http://www.tecnamswiss.ch/P2006-T_MRI_01.html
These aircraft are optimized for 6 to 8 hour missions and I was wondering if there any restroom facilities in these planes. What would a crewmember do to relieve himself on a 8 hour patrol in these small cramped aircraft ? Would a small chemical toilet even fit on board ? Or is this not even an issue for them ?
There doesn't seem to be a lot of room in these small cramped aircraft for bodily contingencies.....
short summary of every jewish holiday: they tried to kill us ,we won , lets eat !
SAAFNAV
RE: Do Small Patrol Aircraft Carry Lavatories?
Mon May 27, 2013 8:03 pm
As for number one, I guess Wee Jon's are in order.
If you have a bigger problem? Well, I guess you are stuck.
Worst nightmare... flying without amenities and the need arises!
NBGSkyGod
Mon May 27, 2013 11:21 pm
Open the door..bombs away?
Pilots are idiots, who at any given moment will attempt to kill themselves or others.
LH707330
Tue May 28, 2013 2:35 am
I think a number of smaller A/C have small "relief tubes," but for big business you're outta luck...
Woodreau
Tue May 28, 2013 3:40 am
I always carried a 1 gal ziplock freezer bag for the liquid variety in the SH-60B helos. Then dropped it out of the hole in the bottom after business was done.
mandala499
Tue May 28, 2013 4:18 am
Adult diapers anyone?
Just make sure you take a nice long shower post flight if you take that option...
sccutler
Tue May 28, 2013 7:15 am
For tee-tee: http://www.pilotmall.com/product/restop-1-liquid-wastebag-2-pack
Or, permanently-installed in the plane: http://www.chiefaircraft.com/pilot-shop/pilot-relief.html
As to the latter, it relies upon airflow to create a vacuum in the tube to draw the urine out of the aircraft, and the system works quite well, if properly installed and used. But... guy I know had one installed in his aircraft (a C210), and confidently went to use it while on a long flight (Colorado to Dallas, an easy trip for a plane with the long legs afforded by the 210s generous fuel capacity). He "unloaded" into the funnel, only to realize (too late) that the funnel was not fully-affixed to the tube, and it was dumping... onto his seat. The realization came too late to save him, though I have no idea how knowing earlier could have much helped - once you start, it ain't that easy to quit!
He sat and stewed in his mistake for the better part of an hour, and had quite a clean-up task after he landed. A lesson learned, the hard way.
As for solids, it has been done to simply replace a seat in an aircraft with a camp potty or the like if the aircraft is engaged in long-duration missions, but space is always at a premium...
...I've heard of charter pilots in extremis utilizing flight bags lined with sectional charts as emergency crappers, but cannot imagine using this exigency except in the most dire circumstances. Most pilots, anticipating a long-duration mission, try to adjust their food intake and "waste excretion" to minimize such issues. From my own experience, I now know: if you intend to eat a substantial quantity of dried mangoes, be sure that you do so in reasonable proximity of a potty. I was most fortunate to have learnt this lesson after beginning my hearty tropical snack 2/3 of the way through a lengthy trip; had I broken out the tasty treat upon first reaching cruise altitude, I would have certainly required a hasty descent to an emergency facility (so to speak), well short of my destination,and even at that, it would have been a near thing!
...three miles from BRONS, clear for the ILS one five approach...
SAAFNAV
Tue May 28, 2013 2:38 pm
Quoting sccutler (Reply 6):
While exchanging these kind of stories.... I was on a body recovery mission recently. Some hotel in Africa gave myself and the engineer quite the runs to say the least.
The mobile morgue gave some privacy, but pretty much all the passengers (walking wounded) knew what you are up to, since there are only so many things you can do with 2 refuse bags and a white roll of paper.
After the necessary time to ponder, you store your double lined bags in the ramp door where it is cold, and when you land, be sure to take it with you.
That scenario used to be one of my worst nightmares in aviation, but now that bridge has been crossed.
Erich
26point2
Tue May 28, 2013 3:39 pm
I flew a C-421 with a built in relief tube. Cabin is pressurized though which helps immensely. Not sure the plane in OP's pic would be equipped as such.
An old tale from a US Navy P-3 crew member was that the plane was equipped only with a honey pot. The first guy to use it was the same guy who had to empty its contents upon landing. No one wanted to be first.
Tue May 28, 2013 4:50 pm
SAAFNAV
Tue May 28, 2013 8:08 pm
Legendary: http://totalfratmove.com/your-averag...business-trip-gone-horribly-wrong/
Man, this is funny! I love the reference to Cosmo Cramer!
I've heard that if you sit on a apple or tennis ball or something just to keep the pressure on the washer, it will help a bit....
JAGflyer
Wed May 29, 2013 12:08 am
If your not careful you're liable to get "stuck" in the funnel due to the suction created. Uh oh!
Support the beer and soda can industry, your recycle old airplanes!
SAAFNAV
Wed May 29, 2013 4:08 am
Quoting jagflyer (Reply 11):
I read once on A.net about a guy who also designed a liquid disposal system for his glider or small plane.
Kind of a funnel and tubing to the outside of the airplane idea.
However, he never tested it with water, and the first time he used it, he quickly found out the vent was in a high pressure area
foxxray
Wed May 29, 2013 8:29 am
I used to do long surveillance and aerial survey flights, (Pa34, P68, ... so no lavatories) and it happened to me once, luckily i had a bottle of water. It's really difficult to stay focused on your flight in this situation
flyingturtle
Wed May 29, 2013 9:01 am
Well, we have an old thread...
How Do Single Pilots Go To The Toilet? (by Dainan Feb 27 2011 in Tech Ops)#12
David
Users browsing this forum: Baidu [Spider], skyhawkmatthew, TWA772LR and 1 guest
