Zunhao
MD-11F - Fuel Burn
Tue May 28, 2013 3:13 pm
Can anyone answer the following question:
What is the Fuel Consumption for a 3 hour sector fully loaded MD11-F? - Great thanks
sdf880
RE: MD-11F - Fuel Burn
Wed May 29, 2013 6:35 am
About 46 - 48,000 pounds. What speed/MACH # ? LRC, HSC? Engine type, GE. PRATT?
BravoOne
Wed May 29, 2013 10:46 am
Just so there is no confusion about the three hour burn versus the fuel required (domestic rules) here is some more data. International rules have increased fuel requirements in most cases.
GE power
MD11F with a 120K pay load
3:00 = 43910#
FL390
.83
45 minute hold: 4038#
Fuel to alternate: TBD
Taxi: 1500#
Not sure what the max pay load is but obviously that will be a cause for increased burn.
wilco737
Wed May 29, 2013 4:28 pm
Quoting BravoOne (Reply 2):
We had 95 tons of max payload on the LCAG MD11F
Sure, the more weight, the more fuel burn.
IIRC we used 7,200 kgs per hour as average fuel burn. So for 3 hours means 21,6 tons of fuel (without reserves), so add the reserves and you get to something around 30 tons of minimum fuel to carry for a 3 hour flight.
wilco737
BravoOne
Wed May 29, 2013 4:33 pm
Yes my numbers came directly from a flight plan a ran to see what would come up. Just did not have the max load capacity at my finger tips. I flew the airplane for about 5000 hours but it's been long enough ago that I do not remember those kind of details.
wilco737
Wed May 29, 2013 4:42 pm
Quoting BravoOne (Reply 4):
No problem. I know how that feels. I left the MD11F 2,5 years ago and some things are just gone, but others I still remember. I 'only' have 2200 hours on the MD11F.
Thanks for your posts
wilco737
CosmicCruiser
Wed May 29, 2013 7:07 pm
yeah guys for the same reason I didn't reply. I was estimating about 45-50,000lb but no statistics just memory. The max payload would be a lot higher than what someone posted. Hey Wilco737, we started getting some of the higher wgt -11s there at Fedex. I miss the -11 what fun to fly!! CC
Zunhao
Thu May 30, 2013 5:10 am
Great thanks to you both.
sdf880
Thu May 30, 2013 5:32 am
I ran actual numbers tonight on my computer at 5X. Planned a 3 hour flight,US domestic, MAX zero fuel weight, no alternate, domestic reserves. I ran GE and Pratt as we have them both then averaged the numbers. Cost index zero which worked out to Mach .818, MZFW 461.3, average burn 56,000 pounds.
SDF880
Nicoeddf
Thu May 30, 2013 11:33 am
Quoting wilco737 (Reply 3):
We had 95 tons
...more like 85 tons...no?
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
wilco737
Thu May 30, 2013 1:50 pm
Quoting nicoeddf (Reply 9):
Well, I had several flights with payload of 95 tons. I am 100% certain with this number.
wilco737
744lover
Thu May 30, 2013 7:01 pm
Hi.
GEC uses a kind of "high MZFW" version of the MD-11
Basically what you have is:
DOW: 114.0 t
MZFW: 209.2t (therefore max. payload: 95.2t)
MTOW: 286.0t
MLW: 222.0t
Now let's have this bird landing with 222t at SEQU on any given day... It's an interesting landing, to say the least
BR,
744lover
wilco737
Thu May 30, 2013 7:12 pm
Quoting 744lover (Reply 11):
Every landing with that weight is interesting
I have only been once to SEQU/ UIO and it is an interesting approach indeed. But amazing view. Doubt with 95 tons of cargo this would be legally possible.
wilco737
Nicoeddf
Thu May 30, 2013 10:15 pm
Quoting wilco737 (Reply 10):
You should know...
CosmicCruiser
Fri May 31, 2013 12:28 pm
Our standard -11s had a ZFW of 451,000 lb and MLW of 481,500 lb. We had some as wilco737 knows that were ZFW 461,000 and MLW 491,000.
I don't know SEQU but I did see a few occasions with a wet runway especially not grooved that we had to take a longer runway. 27R CDG, 28 DEL to name two. That Vapp at MLW was smokin'! 168 kts I believe
wilco737
Fri May 31, 2013 12:32 pm
Quoting CosmicCruiser (Reply 14):
I don't know SEQU
9400 feet elevation within a valley of even higher mountains. And rather short runway.
Oh yeah, I remember DEL or NBO with 5500 feet elevation. And then use Flaps 35 and you are above 170 knots V appr. I think 173 is the highest I saw. With the hot and high day in NBO you get close to the max tyre speed of 204 knots...
wilco737
CosmicCruiser
Fri May 31, 2013 2:37 pm
My wake up call was going into CDG on day at close to MLW. They were landing 27R departing 27L. There seemed to be no problem. As we got closer I listened to ATIS one more time and noticed they mention runways wet. I asked the F/O to check the landing dist once more with a wet runway and was shocked to find that even though all the jets were landing 27R we couldn't come close with that weight and wet surface. We immediately told CDG approach we needed 27L and got the approval. Just over the approach lights a moderate rain fell and as we exited and taxied to our ramp I remember telling the F/O that had wetaken 27R we would never have stopped on the runway!! I became much more serious about heavy wgt/wet/ungrooved runways after that!
Users browsing this forum: RushmoreAir and 1 guest
