lebb757
Right Handed Captains In Airbus?
Thu May 30, 2013 11:56 pm
The captains stick in airbus airplanes is placed to his left. Does that make it any harder for captains who are not lefties to fly manually? Does anybody have any experience on this issue? Greetings from BOS
XFSUgimpLB41X
Fri May 31, 2013 12:03 am
Commonly asked question.
The fact is, whether you fly with a yoke or a sidestick, you only use your outside hand for most hand flying.
So, when flying with a yoke and sitting in the left seat, you hand fly with your left hand and your right hand is on the throttle.
This is the case from your very first flight getting your private pilot license.
Chicks dig winglets.
rfields5421
Fri May 31, 2013 12:27 am
I would also add - a right handed Captain in a Yoke aircraft flies with his left hand. Because if he flew with his right hand, he could not do all the additional tasks of throttle, radios, FMS, etc.
The base question is also equal to
Can a right-handed person drive a stickshift car with the steering wheel on the left side of the vehicle (such as the United States) ?
BreninTW
Fri May 31, 2013 1:38 am
Quoting rfields5421 (Reply 2):
I think it should be "Can a left-handed person drive a LHD stickshift?" Since in LHD cars, the shifter is to the right of the driver.
I'm a righty ... and I drive both LHD and RHD stickshifts with no problems other than occasionally turning onto the wrong side of the road.
Mastropiero
Fri May 31, 2013 10:07 am
Quoting BreninTW (Reply 3):
I fail to see any difference between rfields5421's post and yours, other than different wording.
flyingturtle
Fri May 31, 2013 11:41 am
One becomes very adept with his "wrong" hand. Practice, practice.
The same question about yokes and sidesticks can be put to biologists or surgeons, who have to use both hands to dissect, hold and cut very small body parts.
There is also keyboard writing, piano playing and climbing, among other stuff where the left hand has to do the same as the right one, and after practice, it will become natural. I'm sure this stuff is more difficult than using a sidestick with the left hand.
David
flymia
Fri May 31, 2013 1:33 pm
Quoting lebb757 (Thread starter):
No. Airbus, Boeing, CRJ or Cessna does not matter the person sitting in the left seat uses his left hand to fly and the person sitting in the right seat uses his right hand to fly.
Don't you use your left hand on the steering wheel more often than your right hand? I drive an automatic car but I will still find myself using my left hand much more often than my right hand.
PapaChuck
Fri May 31, 2013 1:57 pm
I am right handed. I learned to fly from the left seat, using my left hand to fly. It actually came pretty naturally to me. Not long after getting my PPL, I went for a ride with a friend in an Archer. I finally got to fly with my right hand, and I was lost. My first touch and go was quite ugly. I found flying with my left hand was an easy skill to pick up, but a hard habit to break.
I also drive a stick shift. Learning to use the clutch was a lot harder for me than learning to steer with my left hand. Ironically, that led to a bad habit I had to break while I was working on my PPL. Out of reflex I naturally wanted to mash the left pedal to the floor when braking. Didn't impress my instructor that day.
PC
In-trail spacing is a team effort.
26point2
Fri May 31, 2013 1:58 pm
Back in the old days when I was a busy CFI I was more comfortable and could get better landings from the right seat. Flying from the left seat was a rarity for me back then so I chose to fly from the right even when solo or with passengers.
Single seat fighters are flown with the right hand on the stick and the left for throttle. I have seen guys struggle with the transition to left seat flying with only fighter jet experience.
Helicopters are nearly always flown from the Right seat though. Not sure why but perhaps it's more natural for the pilot to hold the cyclic stick with his right hand. Helicopters are unstable by nature and one doesn't let go of the cyclic.
hivue
Fri May 31, 2013 2:36 pm
Quoting 26point2 (Reply 8):
I think the collective and cyclic usually are oriented the same on the right side and left side so it's a wash. I think the pilot sitting on the right side is some sort of visibility issue when hovering/landing.
Jetlagged
Fri May 31, 2013 4:20 pm
I've flown Airbus simulators from both seats and not noticed any problem. You don't need the extra precision your "good" hand gives you. I'm lefthanded and can use either hand for most things except handwriting. No doubt righthanded people are generally the same. At this moment I'm typing with both hands and using the mouse with my right hand.
Fri May 31, 2013 4:32 pm
Quoting PapaChuck (Reply 7):
Muscle memory is a funny thing. I'll just chime and say it is not a problem. Heck, I learned to drive a motorcycle without issues and that is way more convoluted than hand flying a plane. Clutch with left hand, accelerator and front brake with right hand (at the same time if you want to finesse it), shift with left foot, rear brake with right foot.
vikkyvik
Fri May 31, 2013 4:59 pm
   Same here. Probably because I used to steer a lot with my left hand when driving automatics, too.
bueb0g
Fri May 31, 2013 8:36 pm
This question comes up literally every week. This site does have a search function. And the answer will be the same every time - no, it's not an issue at all and it's no different to flying a yoke aircraft.
Roger roger, what's our vector, victor?
JoeCanuck
RE: Right Handed Captains In Airbus?
Sun Jun 02, 2013 2:29 am
Quoting bueb0g (Reply 13):
I don't think it comes up 'literally' every week...or even metaphorically every week. Regardless, the search function sucks on this site.
I just did a search for 'left handed flying', also for 'right hand captains' and 'hand flying', and the most recent response was from 2011.
What the...?
flyingturtle
Sun Jun 02, 2013 2:16 pm
Quoting JoeCanuck (Reply 14):
Just use Google.
keyword site:airliners.net
is all you need.
(With a similar trick, you can specifically search for webcam images, by the way.)
David
JoeCanuck
Mon Jun 03, 2013 6:02 am
Quoting flyingturtle (Reply 15):
There are tons of search tricks, still I find it ironic that people will use twice the effort to tell someone to 'use the search function', than it would take to simply answer the question.
Really...what's the point of having a discussion forum if topics are only allowed to be discussed once?
Besides, why have a search function that, well, doesn't function? As well, google search results are, as often as not, a convoluted mess that are more trouble than they're worth...and your question still doesn't get answered.
A google search of 'left handed flying', turns up a bunch of threads on guitars. 'left handed flying', airliners.net, comes up with threads about sitting on the left side of the plane and left handed pilots.
It's so much better to ask questions to groups of people who actually may have the answers or some specific insight than using google.
It's a discussion forum...if one wants to partake, discuss. If one doesn't, they don't have to.
What the...?
PGNCS
Mon Jun 03, 2013 5:46 pm
Thank you (again) bueb0g.
Posters, PLEASE use the search function; this is repeatedly asked and those of us who have actual experience flying the aircraft repeatedly say there is no issue with it at all.
sprout5199
Mon Jun 03, 2013 7:04 pm
Quoting Starlionblue (Reply 11):
Just try to drive an old Triumph, with the shifter on the right and brake on the left. That will mess you up.
Dan in Jupiter
Mon Jun 03, 2013 9:08 pm
Quoting sprout5199 (Reply 18):
Yet another great British eccentricity in design then?
JoeCanuck
Tue Jun 04, 2013 10:04 am
Quoting PGNCS (Reply 17):
Again, the search function doesn't work. If a question bothers you, ignore it. If it really bothers you, ask to have it deleted.
What the...?
Users browsing this forum: Bing [Bot] and 1 guest
