a380900
Longer Plane, Smaller Tail: Even For The A380-900?
Fri May 31, 2013 5:08 am
Some tubes with wings have had different tail sizes depending on their lengths. I definitely remember that being the case for the A318 having a larger tail than other A320 family members. I think that was also the case for the A330-200/300 or maybe between 500/600? Are there any other case of special tail designed for specific derivative?
So I wondered too about the A380-900, wouldn't the weight gains be spectacular if they could reduce the tail's size? But wouldn't it cost a lot to engineer that compared to keeping a slightly oversized tail? Can the weight gains compensate the engineering costs?
Wouldn't an A380-900 with an A380-800 tail be a much lesser plane than if the tail was adjusted? I mean the bigger the plane, the higher the impact on weight and drag of reducing the size of such a massive component.
RE: Longer Plane, Smaller Tail: Even For The A380-900?
Fri May 31, 2013 5:40 am
Fin and rudder size is dependent on the requirement to have enough authority during engine out. As you say a longer body means more moment arm, in theory allowing a smaller fin and rudder. However the engines are more powerful, so this advantage might not be realizable. For example the 345 and 346 have the taller 330 fin despite being longer than the 342 and 343.
rwessel
Fri May 31, 2013 6:26 am
The 747SP had a larger tail than the "normal" models.
While a longer fuselage would enable a smaller tail, other design considerations might reduce that. For example, the A389 will certainly have bigger engines, requiring more rudder authority to handle an engine out. Also, it depends on how the stretch is done - if more of it happens forward of the CG (this might happen for CG purposes, or convenience in where fuselage sections can be stretched), the lever arm for the tail will not improve as much, and the destabilizing influence of the forward fuselage will increase.
As to the cost/benefit, while a smaller tail would certainly help (assuming the tail would otherwise be oversized), the cost to reengineer/change tooling/recertify that obviously has to be justified by the performance gains (as those lead to improved sales).
In any event, the A389 is not expected to be all that much bigger than the A388, so we’re probably not looking at any huge oversizing of the tail feathers, even if they’re not clipped.
ferpe
Fri May 31, 2013 9:16 am
Quoting rwessel (Reply 2):
There are a number of considerations when it comes to wether one could and should reduce the tail sizes or not and it differs for the Vertical and Horizontal tailplanes.
HTP
This is working all the time to balance a naturally stable aircraft. This means it produces drag due to lift (induced drag) and drag independent of lift (mostly skin friction drag) all the time. When the tail arm gets longer the induced part reduces so you have a reduction of HTP drag with a longer tail without reducing the HTP size. If you still want to reduce the size you want to reduce the area but not the span, otherwise there is not much gain from the operation. Hence for the most part nothing is done for the HTP.
VTP
This is normally not generating much of a force hence its drag due to lift (once again induced drag but in the horizontal direction) is low, its parasitic drag dominates. Here one can see that the height of the tail and thereby the VTP surface can be reduced sometimes be clipping the tip if the induced drag when one engine goes inop (OEI) is still Ok for the OEI certification criteria, you would gain reduced wetted area for the cruise phase and for the life of the aircraft.
Non French in France
Viscount724
Sat Jun 01, 2013 1:29 am
Quoting Starlionblue (Reply 1):
When the Convair 340/440 was converted to a 580, a major part of the modification involved increasing the area of both the vertical and horizontal tail to compensate for the much more powerful Allison 501 turboprops with about 50% more power than the original P&W R-2800s (roughly equivalent to adding a 3rd engine to the 340/440). The vertical stabilizer/rudder is about a foot taller on the 580 and the span of the horizontal stablizers was increased about 3 feet.
A few photos here of North Central aircraft undergoing that very successful modification.
http://northcentralmemories.blogspot...h/2009/07/convair-conversions.html
BEG2IAH
Sat Jun 01, 2013 2:53 am
Quoting ferpe (Reply 3):
HTP
VTP
ferpe, is there any reference (not really aerodynamics for dummies, but something close) where those of us who like aviation but are not engineers can relatively quickly learn some of the basics? I tried searching for good elementary books on Amazon and alike, but I end up biting more than I can chew. Any recommendation would be much appreciated.
Aviation is not so much a profession as it is a disease.
Sat Jun 01, 2013 6:17 am
Quoting BEG2IAH (Reply 5):
"Stick and Rudder" by Wolfgang Langewiesche might be a good start. It was written in the 1930s and as such the language is somewhat dated (elevators are called "flippers") but it is still an excellent text that explains flying well to the layman.
Once you've figured that one out, D.P. Davies' "Handling the Big Jets" is superlative. Written in the 1960s by the Chief Test Pilot of the UK aviation authority, it explains the aerodynamics and other aspects of modern aircraft (incl. spiral divergence, dutch roll, etc...) from a pilot's point of view. The language of this one is also a bit dated but it is an excellent text even today.
ferpe
Sat Jun 01, 2013 6:27 am
Quoting Starlionblue (Reply 6):
Thanks Starlionblue, those are reference that I have never read, sounds interesting. Another good start is NASA, they have web courses where this one is an excellent start and very pedagogical and you can gradually dig deeper and deeper:
http://www.grc.nasa.gov/WWW/k-12/airplane/bga.html
airmagnac
Sat Jun 01, 2013 10:22 am
Just finishing Langewiesche myself, after going through DP Davies. Great books indeed.
Here are a couple other links (but a bit more advanced) :
http://adg.stanford.edu/aa241/AircraftDesign.html
http://www.av8n.com/how/#contents
My goal as an engineer is to fill my soul with coffee and become immortal
trnswrld
Sat Jun 01, 2013 5:52 pm
Or like the DC8 which is long and skinny and has a very small vertical stabilizer. Infact so small that I always thought the real long DC8 models look kind of funny with that tiny tail.
ferpe
Sat Jun 01, 2013 6:33 pm
Quoting airmagnac (Reply 8):
The stanford link is really good, I based my model on it. It contains a lot of wisdom from R Shevell, the former Douglas head of advanced Aero design. Many practical numbers like the skin friction coefficients etc, climb fuel adders and so on. I verified his formulas and daa with some other well known books like Thorenbeek and Roskam, but the most I got from Shevell.
Viscount724
Sat Jun 01, 2013 9:45 pm
Quoting TrnsWrld (Reply 9):
Distance from the ground to the top of the DC-8 vertical stabilizer is almost identical to the same dimension on the 707, in some cases a few inches greater depending on the model. DC-8 fuselage is only one inch narrower than the 707.
thegeek
Sun Jun 02, 2013 1:41 am
HTP
I'm not aware of any aircraft which has varied the HTP size without a complete overhaul, besides the MD-11. And we know how that one went.
Unlikely to be much bigger engines than the 575t A388 though. I can't imagine any A389 breaching the 625t MTOW limit from the landing gear, for example.
I expect this is the consideration which will dominate. It just won't be worth it to shrink the tail, especially with only a few expected copies to be sold.
ferpe
Sun Jun 02, 2013 7:05 am
There is an absolutely lovely book that I forgot to mention, CM tipped my to have a look in it;
The Anatomy of the Airplane by Darrol Stinton.
He's CV is below, he writing is really with a practical eye first and foremost (and yes it is all slugs and feet etc as it has some years since made but that does not matter because it is his simplistic view on things that count). Though I might have read 10+ books on aerodynamics he got me to understand new things  but virtue of his masterfull explanation of things from a very footed standpoint, the signs of someone who have really understood it    :
Darrol Stinton MBE, PhD, CEng, FRAeS, FRINA, MIMechE, RAF(Retd) was born in New Zealand and grew up in England. He is a qualified test pilot and aeronautical engineer who worked in the design offices of the Blackburn and De Havilland aircraft companies before joining the RAF. His test flying spanned 35 years and more than 340 types of aircraft, first as an experimental test pilot at Farnborough; then 20 years as airworthiness certification test pilot for the UK Civil Aviation Authority on light airplanes and seaplanes, before turning freelance.
[Edited 2013-06-02 00:06:33]
BEG2IAH
Sun Jun 02, 2013 8:48 pm
Starlionblue, ferpe, airmagnac, thanks for great suggestions and links.
Jetlagged
Sun Jun 02, 2013 11:16 pm
Quoting thegeek (Reply 12):
The 747SP has a larger horizontal tailplane compared to the normal length 747.
To put it another way, the MD-11 is one of the very few instances, possibly the only one, where a stretched aircraft has been given smaller tail surfaces. As you hinted, it didn't go so well.
The fin of a stretched aircraft might not have to be quite so large to meet engine out criteria, but being bigger gives the aircraft better margins, lower Vmca and Vmcg. The drag penalty of the slightly over sized fin and tailplane is tiny.
thegeek
Sun Jun 02, 2013 11:29 pm
Quoting Jetlagged (Reply 15):
Thanks, didn't know that one.
Viscount724
Mon Jun 03, 2013 12:07 am
Quoting thegeek (Reply 16):
10 ft. difference. Horizontal stabilizer span 82 ft. 9 in. on the SP and 72 ft. 9 in. on the 100 through 400 (72 ft. 2 in. on the 747-8). The vertical stabilizer is 5 feet taller on the SP.
thegeek
Mon Jun 03, 2013 12:24 am
Hmm, the HTP was shrunk by 7in. on the 747-8. Perhaps a smaller tail is plausible for the A389.
Jetlagged
Mon Jun 03, 2013 12:50 am
Quoting thegeek (Reply 18):
Interesting. But then the 747-8 has a new wing too, so maybe Boeing thought they'd optimise the tail while they were at it.
LH707330
Tue Jun 04, 2013 4:40 am
Quoting Viscount724 (Reply 11):
But the 707 was much closer to the ground and the DC-8 had a nose-down stance, which tells us that its fin was smaller.
ferpe
Tue Jun 04, 2013 3:24 pm
When you change the wing profile but perhaps more important the high lift devices (slats and foremost flaps) you affect the requirement for the max authority of the tail + it's tail arm, i.e. the max moment it has deliver at the most inconvenient (read low) speed (most probably during start or landing).
So this is a cause for also touching the HTP, for the 748 both the wing profile and the flaps were changed. For the 389 the one thing we know is that the wing will stay the same (at least this is what A has said), they might tweak flap angles etc and that can affect=increase the max moment they need. But with the longer tail arm that should not be a problem. So, doubt that one would touch the HTP for the 389.
Users browsing this forum: Harry99 and 27 guests
