astuteman
Was The 747 Really "bought For Its Range"?
Sat Jun 08, 2013 10:05 am
I've created this to move a discussion out of Civ Av to here, where it probably belongs
What I'm hoping for is data, evidence, quotes etc rather than rhetoric.
I'd like to examine the question in a more analytical way.
to kick off...
As far as I can tell from some fairly brief research
By service entry date
1967 - DC8 62 - 5 200Nm
1970 - 747-100 - 4 900Nm
1971 - 747-200B (JT 9D) - 5 000nm
1972 - DC10 30 - 5 750Nm
1975 - 747SP - 5 800Nm
The JT9D powered 747's by my estimation account for about the first 380 frames off the line, and were outranged by existing frames.
Then the CF6/RB211 powered versions came along and heralded a 16 year long "golden era" for the 747 in terms of range
1976 - 747-200B (CF6) - 6 900nm
1983 - 747-300 - 6 800nm
1989 - 747-400 - 7 250Nm
1990 - MD11 - 6 800Nm
1992 - A340 - 7 300Nm
That period from 1976 to 1992 saw the 747 have a c. 1000Nm range advantage over anything else
That period accounted for 460 frames (by my count)
Since then, there have been planes around that match or beat the 747's range
However "since then" accounts for 680 frames, including the 747-8
In summary
1970 - 1976 - 380 frames with no range advantage
1976 - 1992 - 460 CF6/RB211 powered frames with over 1000 Nm advantage
1992 - 2005 - 580 frames with no range advantage
2005 - present - 100 frames with no range advantage
I make that 1060 frames sold without a range advantage vs 460 with one. (a ratio of 2.3:1)
Please feel free to challenge, or offer alternative evidence.
This is about learning, not bigotry, as far as I'm concerned.
citationjet
RE: Was The 747 Really "bought For Its Range"?
Sat Jun 08, 2013 1:31 pm
I think the answer is no, the early 747s were not bought for their range. Braniff for instance bought the 100th 747 off the line. It flew their flagship route from Dallas to Hawaii, replacing existing 707-320s that already had the range capablility for this route.
Most early 747s were bought for prestige on existing routes, rather than opening up new routes that would require additional range. New routes were not easy to obtain in the early 70s compared to today. For instance PanAm replaced 707s on routes from NY to London. Airlines like Eastern and Continental had early 747s on domestic routes, so range was not the reason for their purchase.
It would be interesting if someone could provide examples of some of the early 747s being deployed on new routes that did not previously exist for the airline.
[Edited 2013-06-08 07:12:10]
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
astuteman
Sat Jun 08, 2013 1:58 pm
Quoting CitationJet (Reply 1):
The data above would suggest you are correct.
The range advantage only appears to have become real in c. 1976, when the CF6 and RB211 appeared on the frame.
747classic
Sat Jun 08, 2013 2:41 pm
Quoting astuteman (Reply 2):
The 747-100's and certainly the 747-200's powered by the original JT9D-7 series were actually underpowered, the range was limited by the T/O performance of the engines. During 1970-1974 the engines were very slowly improved by increasing the TO rating by water injection and by rebuilding the engine from -3/3A to -7/-7A standard. Finally the engine could be modified by installing new turbine blades, creating the -7F(W) and -7J, rated at 50.000 lbs.
The first serious range improvement became available in 1975 with the introduction of the CF6-50E engine, rated at 52.500 lbs.
This higher thrust rating allowed Boeing to upgrade the wing gauge to a wing type 6 , increasing the MTOW to 800.000 lbs at the first commercial aircraft (L/N 271, PH-BUH) .
This wing type 6 was later certified, with minor modifications, up to 833.000 lbs, the maximum for the 747-200/300 wing platform.(PH-BUH was also modified up to 833.000 lbs MTOW)
The later certified RB211-524 engine series and the second (JT9D-70A/7Q/7Q3) and third generation (JT9D-7R4G2) Pratt & Whitney engines were also able to deliver sufficient thrust to allow a MTOW increase to 833.000 lbs.
[Edited 2013-06-08 07:47:45]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
PW100
Sun Jun 09, 2013 2:52 pm
Quoting 747classic (Reply 3):
Was that made possible by the introduction of Directionally Solidified (DS) HP Turbine Blades? I think that Pratt was the driving force with this new material solution, first using them in military applications around 1969, and then being forced to use them in the JT9D to cope with the 747 thrust, and more importantly, reliability requirements (mainly extending Hot Section life). Did Pratt initially use Inconel or Rene alloy's?
PS. Astuteman, sorry to hijack your thread, but I guess I know the feeling . . .
PW100
timz
Sun Jun 09, 2013 8:13 pm
Did you try to make your ranges comparable? They're not all full-payload ranges, are they? Are they all full-pax-and-bags-no cargo? Did your figures come from the same place?
747classic
Sun Jun 09, 2013 9:28 pm
Quoting PW100 (Reply 4):
Yes, at the JT9D-7J the High Pressure Turbine was upgraded with DS Turbine blades, plus an increase in cooling air (further decreasing the TSFC)
I'm not 100% sure, but I think Inconel, because Rene was later used by General Electric.
astuteman
Quoting timz (Reply 5):
Yes
No
Yes
No
Seriously though - yes I have tried to achieve apples-for-apples. The two main sources were our own A-net database, and Wiki, but sometimes there were conflicts. In which case I have tried to take other sources, or go with the lowest figure.
The truth seems to be (naturally) that in fact there's something of a moving target in all of them, as improvements get factored into most airframes on a regular basis.
That's why I said I'm not precious about the complete accuracy - provided the picture is pretty robust.
If it isn't I'm happy to be pointed at the correct data
timz
Sun Jun 09, 2013 10:56 pm
As you see at
http://www.boeing.com/assets/pdf/com...ercial/airports/acaps/dc10sec3.pdf
a DC-10-30 wouldn't do 5700 nm with full pax-bags. Best not to believe figures given for airliner range unless the source is halfway specific about its assumptions.
Max Q
Mon Jun 10, 2013 3:54 am
Quoting astuteman (Thread starter):
Maybe you just typo'd that but that's way off.
The -SP's range is closer to 7000NM
Aaron747
Mon Jun 10, 2013 5:28 am
There were a lot of reasons to buy the 747. One of the main ones would be how great she looks in anyone's colors. She is unmistakable:
astuteman
Mon Jun 10, 2013 5:39 am
Quoting timz (Reply 8):
Thanks for that Timz. As I said, I'm not going to die in a ditch for my numbers -
our A-net database didn't help, only quoting max fuel range and max payload range
I took the range from Wiki (and accept that the assumptions may be vague). Thanks
Quoting Max Q (Reply 9):
I took those from our own A-net database.
5855 Nm with 331 pax and baggage
6650Nm with 276 pax and baggage
Stitch
Mon Jun 10, 2013 4:38 pm
Per the 747 ACAP, the 747SP with RB211s with 331 passengers and baggage is good for just under 6000nm. At Maximum Structural Payload, she can do just over 5000nm. To get to 7000nm, payload is about 25,000 pounds.
vikkyvik
Mon Jun 10, 2013 5:46 pm
Quoting aaron747 (Reply 10):
Spoken like a true A.netter!
CARST
Mon Jun 10, 2013 9:27 pm
In summary
My take on the reasons for buying the 747:
1970 - 1976 - 380 frames - bought for size and CASM advantage (this made flying available to the larger masses)
1976 - 1992 - 460 CF6/RB211 powered frames with over 1000 Nm advantage - CASM + range
1992 - 2005 - 580 frames with no range advantage - SIZE, no other frame in this size class, still with a good range
2005 - present - 100 frames with no range advantage - addons for fleet commonality, niche aircraft for LH and KE, freighter versions en masse
So range probably was just a reason for a few years (well still for 16+ years), but being the only aircraft with that size it was still the aircraft that brought the world closer together. No other airplane could transport that many people over such large distances. CASM, range and size where the major factors for the 747 sales up to 2005. With the advent of the 77L, 77W and A380 these advantage were lost. The 8i is a niche aircraft, 8F will still be produced for a long time. Long live the 747!
747classic
Tue Jun 11, 2013 6:10 am
Quoting CARST (Reply 14):
I agree with your conclusion. The only remark (as already stated in reply 3 in this thread):
In the 1976 -1992 period not only CF6/RB211 had the range advantage, but also the second (JT9D-7Q) and third (JT9D-7R4G2) generation P&W powered 747's were finally able to produce sufficient thrust for the increased range variants.
Jetlagged
Tue Jun 11, 2013 8:08 pm
Maybe not everyone's
Photo © Kazuchika Naya
I don't remember the 747 being sold as offering longer range, not until the 747SP was launched. What the 747 certainly did offer was increased capacity.
Viscount724
Tue Jun 11, 2013 9:41 pm
Quoting Jetlagged (Reply 16):
Too much, as it turned out during the first few years of service when many 747s flew well under half full and carriers were forced to introduce much lower fares to help fill them.
ADent
Fri Jun 21, 2013 5:03 am
What was the range on the initial DC-10-30s?
One site shows the 1981 model (aka DC-10-30ER) with increased MTOW and additional fuel had a 5750 nmi range, an increase of 700 nmi over the initial model.
LH707330
Fri Jun 21, 2013 6:04 am
Quoting ADent (Reply 18):
These ones had tanks in the hold, and IIRC, few were built.
astuteman
Sat Jun 22, 2013 8:33 am
Quoting LH707330 (Reply 19):
In the context of the thread question though; If "range" was really the issue....
Of course by then the CF6 powered 747's were already around
I guess that's the number I picked up in the opening post, but attributed it to the baseline DC10-30
not in 1972 it wouldn't
lax777lr
Mon Jun 24, 2013 3:42 am
Yes at least for the 744. I clearly recall analyses on that bird being used for its range in the '90s and pre-777-200ER.
ImperialEagle
Mon Jun 24, 2013 11:18 pm
Yes.
And a lot of carriers here in the U.S. only bought them because the competition might use them. A good example was DL. The company was not going to take a chance that NW might use the 74's on ORD-TPA or ORD-MIA----which they did. Also there was always the threat that NA might use them out of ATL even though that route was to prove nothing more than a thorn in the side of DL.
PA used them on the DL/PA interchange to/from Europe. EA got a few to compete with PA to Puerto Rico, then ran some JFK to MIA which scared DL's mule.
UA had to have them because PA was sure to use them from the West Coast to Hawaii. And if UA had them AA and TW had to have them, etc. etc.TW especially because of PA. In ATL we used to joke that when PI and SO got authority into ORD or an airport in the N.E.Corridor----they would buy 74's.
"If everything seems under control, you're just not going fast enough!"
Viscount724
Tue Jun 25, 2013 4:01 am
Quoting ImperialEagle (Reply 22):
Ironically, the 3 aircraft were leased from Pan Am, for only about a year or slightly longer. They were all returned to PA by early 1972.
ferpe
Sun Jun 30, 2013 5:45 am
Thanks for an interesting topic Astute.
It seems the early 747 (and it's competition as well) was mainly TATL capable, how did the USA to Asia routes work then in those days, ie how did you get to Tokyo, Singapore, Sydney?
Tokyo is on the limit from LAX (4800nm) but SFO is not much better (4600nm), a little headwind or catering etc and it does not work. Singapore is more the 7000nm so should be a problem also with the later versions?
Non French in France
Sun Jun 30, 2013 8:32 am
Quoting ferpe (Reply 24):
You didn't really.
Jokes aside, lots of flights landed in Anchorage. I guess you did LAX-ANC-NRT-SIN or from the other coast JFK-SEA-ANC-NRT-SIN. As I recall SK had a round the world flight that stopped in ANC and NRT.
Looking on the other side of the spheroid, LHR-SIN direct didn't happen until the 747-400 came along, and SQ advertised the hell out of that. I remember flying something like LHR-AUH-CMB-SIN on SQ in the early 80s.
seabosdca
Sun Jun 30, 2013 5:28 pm
It's worth noting that the first variant of the A340-300 that had 7000+ nm range was not delivered until 1996. The initial A340-311 had approximately 6700 nm range, with a shallower payload-range curve than the 747-400. The 744 enjoyed about eight years of untrammeled range superiority, particularly with a heavy payload.
Operators used this to great advantage on two relatively new types of nonstop sectors: Far East-Europe and transpacific. My view is that the "747 for range" trope arose from this time period more than from the late 1970s, when operators were regularly flying DC-10-30s and 747-200s on the same types of missions.
I'm not counting the A340-200, because it sold in such small numbers, and almost exclusively to operators who did not use it on ULR (at the time) missions.
[Edited 2013-06-30 10:30:58]
Viscount724
Sun Jun 30, 2013 10:36 pm
Pan Am 741s operated nonstop SFO-Tokyo in the early days of 747 service. The one that almost crashed on takeoff from SFO in July 1971 was departing for HND.
http://aviation-safety.net/database/record.php?id=19710730-2
Tokyo was the primary gateway to the rest of Asia via the Pacific then. Flights that couldn't make it nonstop to Tokyo mostly made a fuel stop at ANC.
Flights to SYD/AKL in those days almost all stopped at HNL, and a few at PPT.
ImperialEagle
Wed Jul 03, 2013 1:02 pm
Quoting Viscount724 (Reply 27):
Yes. Especially in the winter months, from SEA, many a NW 320B had to do a fuel stop in ANC with a good load of freight up front. It was almost automatic with a full 320C.
With the 741's fuel stops did not happen as often but the loads were not that heavy during that time (during the recession) unless doing a MATS charter. In any event, when the 742's came online that pretty much eliminated the stops.
Users browsing this forum: 7BOEING7, JAGflyer, NPeterman and 1 guest
