CX Flyboy
Accuracy Of Fuel Tank Stick Checks.
Thu Jun 13, 2013 7:37 am
Anyone able to tell me how accurate stick checks are on the 777 fuel tanks?
I ask because I had a flight where our fuel gauges were inaccurate and we had to perform a pre-departure stick check. The stick check gave us 1300kgs less than the figure we asked the refueller for. In the maintenance work-sheet for a stick check it was written that a straight and level aircraft can expect a 2% stick check accuracy. On a longhaul with over 100,000kgs of fuel, this potential shortfall of fuel is not acceptable. The engineer told me that the fuel figure was within 2% of what I asked for and therefore within limits. The way I saw it was that I potentially had 2% less than the stick check figure, giving us potentially 4,000kgs less than what I wanted. Once inflight we would have no real idea of knowing how much fuel was exactly in our tanks.
I have tried to get an answer from my own company but have not gotten anywhere with an answer that makes sense to me. Ideally, if this 2% error is true, it should be written under the DDG procedure for the fuel tank totalizer inaccuracy. This way, pilots can ask to be refuelled to a figure 2% more than what they need for the flight, and this will ensure enough fuel is loaded, rather than realising at a late stage of the pre-flight that we need additional fuel and causing a delay (45mins for us).
Thanks for any insight into this!
Tristarsteve
RE: Accuracy Of Fuel Tank Stick Checks.
Thu Jun 13, 2013 8:46 am
Stick checks on large aircraft are inaccurate. I would say that 2pc is good. To do one properly you must measure the pitch and roll of the aircraft (from the INS) and then let the fuel settle for a while. Even then two people will get readings that are different. The sticks 'stick' as they float and you have to flick them to get a reading. Depending on how you do it can easily give you the discrepancy you saw.
They are very useful to show there is fuel in the tank!, but as an accurate quantity check, no.
The B787 has no sticks.
CX Flyboy
Thu Jun 13, 2013 9:07 am
Thanks for the info. I asked the company why the 2% error is not written in the DDG (MEL) and the reply was that Boeing do not think it is necessary. I have my doubts and have visions of the swiss cheese lining up on a day where you declare a fuel mayday thinking you are short of fuel just as the engines flame out when that 3000kgs reserve you thought you had actually isn't there!
Thu Jun 13, 2013 10:26 am
The Aircraft would be needed to be aligned to the Pitch & Roll ideal position,Normally the spirit level/plumbob in the MWW is used, not sure on the B777s.....If Aligned accurately & Sp Gravity & Temp is know, one can be accurate with the required tolerances.
The DDG should have a limitation of the tolerances.
In this case was all the quantities INOP, then that would be a NOGO.
Only one Ind can be INOP if not mistaken.
Mender
Thu Jun 13, 2013 1:17 pm
Quoting HAWK21M (Reply 3):
This isn't necessary. Boeing produce fuel measuring stick manuals which provide the correct quantity for a given pitch or roll.
Personally,I've not had to use this document however, it should be available to you via your company's MyBoeingFleet account.
CX Flyboy
Thu Jun 13, 2013 1:36 pm
Our DDG makes no reference to tolerances so as far as flight crew are concerned, the stick check is accurate. This sort of contradicts the engineers worksheet stating a 2% accuracy.
In our case we had CWT totalizer inaccuracy. The wing tank indications were working normally.
fr8mech
Thu Jun 13, 2013 1:40 pm
A 2 % error isn't bad at all. I recall that on older aircraft you could expect an overall error in the gauging system of 4%.
Why Boeing has chosen not to add it to the DDG...who knows. Apparently they felt it was not significant.
CX Flyboy
Thu Jun 13, 2013 2:09 pm
Quoting fr8mech (Reply 6):
A 2% error on a longhaul flight means 2000-3000kgs of fuel difference. When your reserves are only 3000kgs anyway, it means the difference between diverting to to your alternate with reserve fuel intact, or having your engines flame out on short finals. This is VERY significant!
fr8mech
Thu Jun 13, 2013 4:17 pm
Quoting CX Flyboy (Reply 7):
Yes, It's significant across the whole aircraft. What about in the one tank with the inoperative fuel tank?
I'm not familiar with the tank lay-out, nor the total qty of each tank or the aircraft. How many tanks and what are their respective capacities?
And, I don't have access to a B777 manual, but I assume the 2% allowable limit is within the tank and not across the whole aircraft. Then again, I may be wrong.
CX Flyboy
Thu Jun 13, 2013 11:25 pm
Quoting fr8mech (Reply 8):
No actually you are right, it would be in the one affected tank only but it is still the difference potentially of a tonne. There are days when we can only make our destination because of higher than expected fuel burn where we disregard our alternate and start eating into that. There are a bunch of conditions which must be prevalent in order to throw away our alternate, basically landing must be ensured at destination. This is how tight airlines operate these days. To have a tonne less than you think in these situations is still not acceptable.
If the CDL can mention the need to increase fuel burn by 0.5% for missing seals etc, you would think that a 2% shortfall in fuel would also be written up.
Mender
Thu Jun 13, 2013 11:59 pm
Leaving aside dripstick fuel measurements, what do your company procedures allow for the difference between the calculated fuel uplift and the actual fuel uplift.
CX Flyboy
Fri Jun 14, 2013 2:38 am
Quoting Mender (Reply 10):
For a longhaul flight with fuel in the CWT, fuel must be within a discrepancy of +2000kgs or -1000kgs on the 77W. Anything outside of this and we have to make sure we know what has happened to the fuel and can only then depart when we are satisfied that there is an adequate reason and that we have enough fuel on board.
However, if the stick check shows less than the fuel we ask for, that is a different issue.
vc10
Fri Jun 14, 2013 8:34 am
Can I just ask what the tolerance is on the aircraft's fuel gauging . If this is also 2% then on a 100 tonne fuel lift you could be up to 2 000 kgs short without knowing about it
Horstroad
Fri Jun 14, 2013 9:01 am
2% is quite good. with the MD11 you have a tolerance of 5%.
keep in mind that this is not the difference to the actual fuel on board, but the difference between the cockpit indication and the sticks... cockpit indication might be inaccurate as well... that's why you pull the sticks in the first place.
in the end you should trust the sticks, that's what they are there for.
Fri Jun 14, 2013 10:25 am
Quoting horstroad (Reply 13):
Comparing the two...The Sticks would be more accurate and reliable.
vc10
Fri Jun 14, 2013 11:53 am
I would agree with you on this point , but I am getting a bit out of date now so was not quite sure what the tolerances were on modern aircraft
Mender
Fri Jun 14, 2013 1:00 pm
Quoting CX Flyboy (Reply 11):
IIRC the company I work for allow for the difference between the calculated fuel uplift and the actual fuel uplift to be 500 kgs or 2% whichever is the greater.
I see your point but from a technical point of view a 2% error is very good. It sounds to me like the real issue is that the reserve fuel policy of your company was written for aircraft that hold no more than 50,000 kgs but has been applied to an aircraft that holds getting on for three times that amount.
CX Flyboy
Fri Jun 14, 2013 3:25 pm
Quoting Mender (Reply 16):
Is that for a 777?
Reserves are calculated at 30mins of flying tme at low altitude at the planned landing weight of the aircraft concerned. The total fuel capacity has no real bearing on this.
Interesting, but the cockpit indication on days when a stick check is required is considered u/s anyway, so what is the 2% being referenced to then? The engineer tried to sell me the idea that the stick check was within 2% of what I asked for so it was fine and within his 2% tolerance.
I would have thought the 777 FQIS was pretty accurate. The maintenance page shows a vast number of readouts for each fuel tank with various readings for when the tank is operative. Certainly gives the impression of extreme accuracy of the FQIS.
fr8mech
Fri Jun 14, 2013 4:57 pm
Quoting CX Flyboy (Reply 17):
The 2% should be off the calculated fuel. Fuel remaining, plus the calculated uplift (gal * density weight) should provide you with the calculated weight in that tank. The stick reading should be within 2% of that calculation.
While stick readings are quicker, when the turn time allowed, I would always pump the tank dry and have the fueler tell me how many gallons he put in the affected tank. Sometimes, this would require some playing around with the distribution in the other tanks to maintain some semblance of balance.
If the cockpit indication is unserviceable, it shouldn't be referenced for anything.
KELPkid
Fri Jun 14, 2013 7:03 pm
On small aircraft:
If the tanks are fixed volume, a stick check is very accurate.
If the tanks are of the rubber bladder type, all bets are out the window unless you've taken the wings apart recently and you know what kind of condition the bladders are in
CX Flyboy
Sat Jun 15, 2013 12:32 am
Quoting fr8mech (Reply 18):
Thanks for that. So what you're saying is that the mechanic's 2% is the same as our +2000/ -1000kgs. So if stick checks are accurate, and the discrepancy is for calculations only and not the actual amount in tanks, then the only issue here is that they short fueled us by 1300kgs and tried to fob it off as being within limits?
fr8mech
Sat Jun 15, 2013 1:35 pm
Quoting CX Flyboy (Reply 20):
It's early and I may not be understanding what you're saying.
An example, maybe (the following does not reflect an actual aircraft):
Aircraft lands with 4000 lbs of fuel in a tank with an inoperative indication system. This quantity is verified by stick reading (if possible), otherwise it is a calculated number. This is a point where an error can be introduced into your calculation.
Fueler puts 4000 gallons in the tank. This works out to 26800 lbs of fuel uplifted for a total of 30800 lbs in the tank. The calculation is: gallons uplifted * density (we use 6.7lbs/gal as a standard). Not sure if you're operator uses a standard density, density for the day, or density at the time of fueling, But, you can see where an error can be introduced at this point.
Now, maintenance pulls the sticks. The sticks are calibrated .2 inch. So, mx gets a stick measurement of 12.4" (I used to pull the stick 3 times and take an approx average) and that comes in at 30400lbs. This will be considered the "actual" fuel on board. If I'm doing the math correctly, this 400 lb error gives us a 1.3% error, in this tank.
Again, we see 2 places where errors are introduced: FOB before fueling and the density. Enter into the equation that the sticks are calibrated to a "perfect" attitude listed in the book, i.e. 1.5 deg nose down and .5 right wing down. Add to that that 2 people pulling the same stick may not read it exactly the same and you can see where the errors begin to compound on themselves.
Again, when time allowed or te DDG required, I would have emptied the tank and removed one potential error source, but a DDG may not require that.
Now, understand, in the aircraft have recently dealt with, we did not fuel by stick, we always fueled by transfer from a "good" tank or by fueling the tank individually and calculating fuel qty derived from the gallons pumped. Sticks were used to verify the qty in the tank.
I hope I haven't muddled this any further. But, you can see where there a couple of points where an error can be introduced into the manual fuel quantity determination.
CX Flyboy
Sat Jun 15, 2013 2:48 pm
Thanks for the explanation. I can see how there can be many errors introduced into the entire process. In the example I gave of my flight, I believe there was no stick check prior to refueling. The "known" amount was the totalizer amount left over in the tanks but since it was our centre tank indication that was faulty, the wing tank totalizers would have been pretty accurate. We had two refueling trucks in attendance since the aircraft was late on stand and we needed over 120,000kgs ASAP. The aircraft registered SG was the same as the one the mechanic used for fuel calculations.
The part where I was confused about was the 2% tolerance as written on his check sheet. I wondered what this 2% referred to and why as pilots we did not need to be told about it in the DDG. In your example where you worked out an error of 1.3%, would you say that it is within the 2% and therefore acceptable?
As a pilot any time I have less fuel than what I asked for, it makes me pause and think about whether it is enough for my flight ahead. Now if the stick check is accurate, I can simply ask for more fuel if I need it. If the stick check is not accurate then I takeoff not knowing exactly how much fuel I have and that is a scary thought.
fr8mech
Sat Jun 15, 2013 3:40 pm
Quoting cx flyboy (Reply 22):
Absolutely.
Something I failed to relate:
Our overall "calculated to indicated" tolerance is 4% (across the aircraft). If we come up with an error > 4%, and the incorrect fuel tank is not readily evident, we will pull the sticks, in all the tank, to help determine the faulty indication system.
The sticks are accurate, so long as they are used correctly.
CX Flyboy
Sat Jun 15, 2013 10:08 pm
Quoting fr8mech (Reply 23):
Interesting! So at what point would you consider that the flight has been short fuelled? See, 4% may be the acceptable discrepancy in working out the sums of how much fuel you expected to uplift but 4% on a long haul flight equals several tons and from my point of view I would be asking for more fuel if the shortfall came to even only a few hundred KGs. So if you did a stick check and the amount came to less than what the flight crew asked for, wouldn't you put more in? ...especially if the stick check was accurate.
vc10
Sun Jun 16, 2013 8:28 am
Cxflyboy
I agree with you on this point . If you are going to all the trouble to do a stick check [for whatever reason] then you have to believe what it tells you, and in my day the fall short of fuel would have been uplifted. However I do accept that modern airline management perhaps does not allow their crews this sort of freedom
CX Flyboy
Sun Jun 16, 2013 10:34 am
Quoting vc10 (Reply 25):
Cxflyboy
Thankfully our management still trust in the pilots and I am free to load as much fuel as I want within reason. I don't believe the mechanics in Hong Kong (outsourced) would have a directive to short fuel us which is why I am curious about why he thought the 2% was acceptable even though it was 1300kgs less than what I asked for. Either he had a misunderstanding of what the 2% meant, or there is something here that I still don't understand.
fr8mech
Sun Jun 16, 2013 12:05 pm
Quoting cx flyboy (Reply 24):
As far as I'm concerned, if a flight crew asks for more fuel, that's between him and dispatch. It is not a maintenance issue. They load more fuel, we do the calculation...you'll still be 2% off and your weight will be screwed up because I believe that the calculated number is used in weight calculations.
Quoting cx flyboy (Reply 26):
Because, according to the book, 2% is acceptable. There are limits for a reason.
CX Flyboy
Sun Jun 16, 2013 2:09 pm
Quoting fr8mech (Reply 27):
Maybe things are done differently over there. In my airline we do not have accredited dispatchers. We have staff who are trained to input parameters into a flight planning computer which then prints out a bunch of documents that we as flight crew use. The computer calculates the weights and fuel figures. I then write a fuel order form and hand it to the engineer or refueller. What figure I ask for is up to me. Dispatch won't even know about it. As far as they're concerned once they staple the papers together and hand them to me, they are done. Our load control people then send us the final zero fuel weight and in turn I ACARS them our fuel in tanks, takeoff fuel and trip fuel. A loadsheet is then produced with those figures.
If, after refuelling we do not have the figure we asked for, it is up to us to decide whether the shortfall or surplus is acceptable and if not, to correct it in conjunction with our engineer/mechanic. We rarely speak to the refueller directly and in most countries never even see them. If our fuel figures vastly differ from what we asked for and hence what we load our load control, then I have to give them new figures for a new load sheet. The 2% doesn't come into any of this.
Our refuelling discrepancy calculations are merely a safety measure to ensure that the figure they pump into the wings, plus the fuel remaining, equals the fuel we asked for. Just to confirm, this is what I inderstand the 2% to be for correct? ...because if the figures fall ourside our +2000/-1000Kgs, it means that there is something wrong somwehere (maybe an internal fuel leak, wrong fuel gauges etc...). All this is to work out that the fuel figure makes sense.....nothing to do with whether we have enough fuel for the task at hand which is a different issue....hence my confusion.
To me they are different issues...1) Do we have enough fuel? 2) Now that we have decided we have enough fuel, do the figures make sense?
My confusion lies with my perception that our mechanic tried to tell us that the figures made sense as they were within the 2% and therefore we had enough fuel, therein rolling the two separate issues into one. The way I saw it was that the fuel figures made sense as they were within limits, but we still didn't have enough fuel....instead of trying to convince me that we had enough fuel because we were within 2% of what I asked for!
Users browsing this forum: Legs and 1 guest
