CrimsonNL
Partially Polished Nacelle On KLM MD-11
Thu Jun 20, 2013 2:32 pm
Hi guys,
One of KLM's last 6 MD-11's, PH-KCD, has been flying around with an interesting pattern on the nacelle of engine #2. You can recognize her beacause of thise from a distance without seeing the registration. The nacelle has several "stripes" of metal which look to be polished, whatever it is it's much brighter then the metal around it. Can anyone tell me what the purpose of this is? I've never seen it before on any other MD-11, or any airliner that I can remember.
Photo © Aaron Willis
Photo © Gilbert Hechema
Thanks and regards,
Martijn
n901wa
RE: Partially Polished Nacelle On KLM MD-11
Thu Jun 20, 2013 2:59 pm
It's been a long time since I been inside/outside a MD-11 nbr 2 intake, and even longer in a GE powered one. But it looks like the stripes line up with the round access panels that were on the outside of the intake. Maybe a repair of some sort? Not sure, but some info that might help you. Sorry, I am not of more help.
SpaceshipDC10
Thu Jun 20, 2013 8:28 pm
Can it be some kind of aluminum tape or looking like used to mark specific points for some sort of airflow test ? The idea of tape came from the time Swiss began operations with Swissair titled aircraft where the 'air' part was covered.
JAGflyer
Thu Jun 20, 2013 11:50 pm
My first thought is that some sort of repair was carried out which involved riveting new sections or doubler/tripler panels over an area that sustained damage. Due to the symetrical nature of the nacelle's shiny areas, I'm not sure if this is an accident repair or perhaps something to do with where specific mounting screws are.
If you flew today, thank a Flight Dispatcher!
Horstroad
Fri Jun 21, 2013 7:19 am
Quoting SpaceshipDC10 (Reply 2):
I would not tape anything on the engine nose cowl, especially not metal tape. the adhesive will fail sooner or later... engine A/I probably won't delay that.
looks like some kind of repair.
klemmi85
Fri Jun 21, 2013 2:04 pm
quit a.net 07/2016
747classic
Fri Jun 21, 2013 2:17 pm
Highly unlikely that tests are performed, seen the very limited time that the last active MD11 aircraft will remain in the KLM fleet. (phase out will be completed in 1-2 years)
Probably a repaired or modified nose cowl was installed.
The repaired patches (exactly located above the stringers?) or doubler plates are probably new or have been polished.
After a few months airline service the polished plates will also be blackened (oxidised) like the surrounding nose cowl structure and the repairs will hardly be noticed anymore.
Operating a twin over the ocean, you're always one engine failure from a total emergency.
CrimsonNL
Fri Jun 21, 2013 2:39 pm
Quoting 747classic (Reply 6):
I've been browsing through the data base and pictures of KCD with these "stripes" go back as far as late 2011! I found 2 more excellent shots including a nice close-up.
Photo © Stefan Sonnenberg
Photo © Jason Wood
Martijn
SpaceshipDC10
Fri Jun 21, 2013 9:40 pm
It would have surprised me too if the tape suggestion I did was right. On the close-up picture it's really visible that it's something more substantial than just tape.
flyingturtle
Fri Jun 21, 2013 10:20 pm
I've seen a (perhaps) similar thing on the 320 engine.
On the engine pylon, you see a brighter part and at the sides, one that has a much darker grey. The brighter one has a rough surface, while the grey one seems to be smooth.
Why is that?
David
CALTECH
Fri Jun 21, 2013 11:02 pm
Quoting flyingturtle (Reply 9):
Why is that?
Color difference between Aluminum and titanium.
As far as the KLM Florence Nightengale MD-11, looks like a repair or reinforcement of the inlet. KLM would know.
Video below.
http://www.youtube.com/watch?v=5PaZy...NbQg&feature=player_embedded#at=70
http://www.youtube.com/watch?v=jAfQw...bYMM&feature=player_embedded#at=67
[Edited 2013-06-21 16:19:52]
UNITED Would Be Nice
flyingturtle
Sat Jun 22, 2013 4:53 pm
Quoting CALTECH (Reply 10):
Thank you! (But now I'm super-officially stupid, because I own a titanium cooking pot for camping. It has the very same color.)
David
AA737-823
Sun Jun 23, 2013 10:09 pm
Quoting flyingturtle (Reply 11):
The alloys in your "titanium" cooking pot are most likely different alloys than those used on the A320 pylon.
Parts of the Airbus pylons get hot, and so titanium is used here, as I understand it. Conversely, Boeing typically employs cool pylons (except 757s and 747s with RB211 engines, which have precoolers in the pylons as well). You'll notice that a 747 with Rolls Royce engines doesn't have any "Boeing gray" paint on the pylons.
Anyhow, I suspect your cooking pot maybe have different coloration than the pylon due to different chemical makeups of the "titanium" alloys.
bikerthai
Tue Jun 25, 2013 4:38 pm
Quoting AA737-823 (Reply 12):
Typically the aircraft titanium alloy used is Ti 6AL-4V. There are some newer grade titanium that may be used with supper plastic forming. For cookware, I think pure titanium may be used as it is easier to form.
Titanium typically do not have any finish as the surface is already corrosion resistant/proof. Aluminum, specially skin aluminum will have a layer of pure aluminum cladding on the surface that will make it shinier.
I think you can anodize titanium to give it a permanent shine (I heard that some customized titanium bicycle frames are anodized for this purpose). Otherwise a regular titanium surface will readily attract fingerprints.
bt
CALTECH
Mon Jul 01, 2013 2:21 pm
Quoting CrimsonNL (Thread starter):
Some photos of a 757 nacelle and slat with polishing and repairs in place.
http://i297.photobucket.com/albums/mm233/CALTECHphoto/010_zps6446dba1.jpg
http://i297.photobucket.com/albums/mm233/CALTECHphoto/011_zps20c5f2c1.jpg
http://i297.photobucket.com/albums/mm233/CALTECHphoto/013_zps2a05ffa4.jpg
Users browsing this forum: StereoTechque, Teganuma and 1 guest
