a380900
Circular Cross Sections?
Thu Jun 27, 2013 1:04 am
I read in another thread that the 777 was the first Boeing with a "circular cross section". I don't know whether that's true but I wonder which airliners have a perfectly circular cross section. It is quite obvious that the A380 does not. But what about the A300/10/20/30/40/50? The 787? And how far are 757, 737 and 767 from a circle?
And I guess if these are perfect circles, it must have a technical explanation. Is it more about aerodynamics or more about pressurization issues? And how bad is it for the A380 and the others not to not have this shape?
How about concorde by the way? Was the fuselage cross section close to a circle?
[Edited 2013-06-26 18:07:33]
RE: Circular Cross Sections?
Thu Jun 27, 2013 1:23 am
Quoting A380900 (Thread starter):
The 707/720, 737, 727 and 757 all share the same cross section, but have different lower lobes. The upper lobes are quite circular, with the different models having different degrees of bulge on the bottom. The 727 and 737 are closest to circular.
707
727
737
757
The 767 is rather oval.
AFAIK the 330/340 is circular.
Pressurization and structure in general. A cylinder is inherently stronger, and thus can be made lighter. However in other respects a cylinder could be heavier. It really depends on the capacity of the airliner you're designing whether a cylinder is a good idea or not.
It's all about design compromises. Methinks a cylinder on the scale of the 380 would be too wide for the middle decks to be practical I think. Imagine three aisles with 3-4-4-3 seating. Also it would mean shorter wings, and the 380 is already hard up against the ICAO size limit of 80 meters wingspan.
One of the 380 proposals was basically two 340 fuselages side by side but structurally it would have been quite heavy.
BMI727
Thu Jun 27, 2013 2:21 am
It's structurally the most efficient: pressurization is trying to push a vessel into a circle anyway. A circle also has the most area per perimeter of any shape, but that brings you to the reason why you might not want a circle: drag.
A circle gives the most interior space, but not all of it is useful, especially as you get bigger. A large circular cross section will have space in the crown and keel that is not revenue producing. Now a lot of it can be used for EE bays, ductwork, hydraulics, etc. but eventually some of it is not needed. So a circle is the best area per perimeter (which translates pretty directly to surface area, which translates to drag), but maybe not the least perimeter for a given useful area. A non-circular shape can cut drag for a given cabin/cargo bay size, but at the cost of structural efficiency. It turns into a big tradeoff, but for all the circular planes out there, Gulfstream switched from circular to a flat bottom cross section on the G650.
LH707330
Thu Jun 27, 2013 7:27 am
One reason for the non-circular cross-sections is the floor. If you don't have anything inside, a cylinder makes the most sense, but if you have floor beams in tension, then it makes sense to have two partial cylinders in a double-bubble (or figure-8) arrangement, because it cuts down on drag.
Viscount724
Thu Jun 27, 2013 11:14 pm
Didn't the KC-135 have a circular fuselage section (unlike the wider 707 fuselage)?
Thu Jun 27, 2013 11:36 pm
Quoting Viscount724 (Reply 4):
Nope. Incidentally, this was Boeing model 717.
LH707330
Fri Jun 28, 2013 12:45 am
Same lower lobe, slightly narrower upper lobe. It's oval, not figure-8.
vikkyvik
Fri Jun 28, 2013 2:06 am
Quoting LH707330 (Reply 3):
Maybe I'm misunderstanding, but how does drag, whether for circular or double-bubble cross section, relate to floor load?
Fri Jun 28, 2013 2:45 am
Quoting vikkyvik (Reply 7):
I believe LH707330 is not speaking about floor load from cargo, but rather about the fact that the deck beams are part of the structure and thus partially relieving the load on the fuselage itself. Thus the fuselage can be made as strong as if it were circular even if it is not.
rwessel
Fri Jun 28, 2013 5:16 am
While a circular fuselage will contain the maximum volume for a given surface area (wetted area = parasitic drag), much of that space is not usable (see, for example, the very large crown area on the 777). For typical loads, a double (or triple) bubble can enclose more *usable* space for a given wetted (surface) area, hence less drag. Structurally, the circular fuselage is simpler and lighter for the enclosed volume (hence less induced drag), and a double bubble requires heavy reinforcement along the plane joining the bubbles (although it does save on skin area, and hence skin weight). For airliners in particular, the main deck floor needs to be there anyway, and slightly strengthening that to handle the chore is usually not a big increase over the other design loads for the floor.
From a passenger and cargo perspective, you'd ideally like a rectangular cross section (think railroad box car), but that's problematic from a pressurization perspective (and the angular corners are not particularly aerodynamic).
LH707330
Sat Jun 29, 2013 3:49 am
Apologies for the confusion, I wasn't being very clear.
Quoting Starlionblue (Reply 8):
Quoting rwessel (Reply 9):
These two did a good job explaining what I was trying to say: a cylinder is best from a structural standpoint, and an oval is best for drag. A double-bubble consisting of two partial circles with a tensioned floor beam is a good compromise.
Users browsing this forum: airxliban, ikolkyo and 3 guests
