singel09
More Details On Tech Delays
Thu Jun 27, 2013 7:17 am
All,
I was wondering if there is a site where I can get [some] info technical delays?
A friend of mine was on a flight yesterday, delayed for 2,5 hours as a sensor needed to be replaced to get rid of an erroneous 'transit light' ; I was wondering if this info can be found anywhere
Maurice
Woodreau
RE: More Details On Tech Delays
Thu Jun 27, 2013 4:37 pm
The info on your technical delay can definitely be found in the airline's operations/maintenance computer system. You'd have to find someone who had access to it to tell you any details as it's definitely not publicly accessible.
mmedford
Thu Jun 27, 2013 4:42 pm
Sounds like you have as much information as needed... a sensor had to be replaced, which caused the delay.
Replacing a sensor takes time; you have to locate the part, do the maintenance and then the paperwork which usually takes the most time.
ILS = It'll Land Somewhere
AA737-823
Fri Jun 28, 2013 12:11 am
There are a limited number of items on the aircraft that have "IN TRANSIT" indications.
My first guess would be thrust reversers.
Other than that, without knowing the aircraft type involved, there are a number of pneumatic valves and fuel valves which have "IN TRANSIT" annunciation.
But aircraft maintenance information is NOT oublic domain, so no one is under any obligation to provide it to you.
Kind of a bummer, becase, as a mechanic, I ALWAYS want to know what was wrong with the plane I'm about to get on!
singel09
Fri Jun 28, 2013 11:30 pm
It was on the Transavia PH-XRE 737-7K2 and it had to do something with the slats.
thanks!
Users browsing this forum: Starlionblue, Yahoo [Bot] and 1 guest
