celestar
Runway Designation
Fri Jun 28, 2013 3:29 am
All runways for airport have designation such as XXR or YYL - I can understand the R and L means but with respect to the first two numerical words, how is it being determined? Please shed some lights on this.
Btriple7
RE: Runway Designation
Fri Jun 28, 2013 3:50 am
It's based on the runway's compass heading. A runway facing south (1-8-0 degrees) would be designated runway 18. East: runway 9. West: 27. Etc. etc. and everything in-between.
Just...fly.
SPREE34
Fri Jun 28, 2013 3:51 am
Magnetic alignment. RWY 9 would have a magnetic alignment closest to 090 degrees. RWY 24,..240 degrees, etc.
I don't understand everything I don't know about this.
SPREE34
Fri Jun 28, 2013 3:53 am
Wow, two good answers in 4 seconds.
Btriple7
Fri Jun 28, 2013 3:58 am
Quoting SPREE34 (Reply 3):
I figured this would be one of those race-to-reply threads.
For everything else you would ever want to know about runways: https://en.wikipedia.org/wiki/Runway
-Bt7
Just...fly.
KPWMSpotter
Fri Jun 28, 2013 2:26 pm
As the above responses explained, yes, runways are numbered to the nearest magnetic heading. There are a couple of circumstances where the numbering system isn't quite as clear-cut.
Some airports have multiple (in excess of three) parallel runways. For most parallels they simply add an "L" "R" or "C" (left, right, center), but with more than three runways this can get confusing. For example, Atlanta has five parallels, all aligned at 095 degrees magnetic. In these cases, the runways are numbered in logical sets. Atlanta was numbered as 8L, 8R, 9L, 9R, and 10. The runways which are mis-matched from their magnetic heading usually feature prominent signage and notes in the AFD stating the actual runway magnetic heading.
Another problem arises due to change in magnetic variation. Earth's magnetic North Pole is constantly moving, while runways are decidedly fixed in position. Shift in magnetic variation is slow (a degree every 20 to 30 years in most places), but must be accounted for. The main runway at Peachtree DeKalb airport in Atlanta has been numbered 2R since the airport was built. Last year, due to shift in magnetic variation, its magnetic heading shifted to 026 degrees. The airport has just finished renovating all runway markings, so the runway is now known as 3R.
I reject your reality and substitute my own...
rfields5421
Fri Jun 28, 2013 11:05 pm
At least one airport numbers the runways by true heading, not magentic heading.
BGTL / THU - Thule, Greenland - uses Rwy 08T / 26T (085 True / 265 True)
Because of its location so close to the magnetic North Pole - 800nm - the runway magnetic heading changes significantly every year.
26point2
Sat Jun 29, 2013 12:28 am
Juneau, AK has runway 8W/26W. Many other "W" runways out there. Always land "gear up" on a W runway.
Viscount724
Sat Jun 29, 2013 1:16 am
Quoting rfields5421 (Reply 6):
Quite a few runways in northern Canada are also numbered based on true headings.
Cubsrule
Sun Jun 30, 2013 2:33 am
Quoting KPWMSpotter (Reply 5):
JAX (7-24 and 13-31 to 8-26 and 14-32) and TPA (9-27 and 18-36 to 10-28 and 1-19) are two larger airports that have re-numbered in the past 5 years or so.
Mir
Sun Jun 30, 2013 4:38 pm
Quoting Cubsrule (Reply 9):
AMS (1-19 to 18-36) and MAN (6-24 to 5-23) are two others, though not quite as recent.
-Mir
Viscount724
Sun Jun 30, 2013 10:29 pm
Quoting Mir (Reply 10):
YYC runways are being re-numbered sometime this year. 16/34 will become 17/35, 10/28 will become 11/29, and 07/25 will be 08/26.
Similar changes at Springbank airport (YBW) just west of Calgary, heavily used by general aviation and training.
Related press release:
http://www.yyc.com/News/tabid/91/art...cleType/ArticleView/articleId/129/
Gemuser
Sun Jun 30, 2013 10:42 pm
Quoting Btriple7 (Reply 1):
In most (all?) countries outside North America single digit runway numbers are not permitted. Hence a runway with a magmatic heading of 90 degrees would be runway 09. So SYD's "East-West" runway is 07/25.
Gemuser
DC23468910;B72172273373G73873H74374475275376377L77W;A319 320321332333343;BAe146;C402;DHC6;F27;L188;MD80MD85
