danwoodman00
SEA-NRT Flight Plan Differences
Fri Jun 28, 2013 12:14 am
While thinking of a trip from Seattle to Tokyo, I looked at the flight plans for UA 875 and DL 155, both nonstop. UA875 is a 772, while DL155 just upgraded from a 763 to 744.
Using both Great Circle Mapper and Flight Aware, it looks like UA875 sticks to the "optimal" route. The DL flight, however, goes quite a long ways farther north -- following the pacific coastline up through Alaska, and coming down through the middle of the Kamchatka Peninsula on the other side.
I couldn't for the life of me figure out why Delta would have a *much* longer flight plan and duration? I was hoping someone here could help explain.
redtailmsp
RE: SEA-NRT Flight Plan Differences
Fri Jun 28, 2013 1:07 am
Could be any number of reasons. Great circle by itself does not necessarily mean fastest route, due to the position of the jetstreams. Going westbound, these winds are headwinds, so flying north of the jetstreams could be faster, and would probably be smoother too. Another issue recently has been some very active volcanoes along the Aleutian chain, so Delta could have been going to the expense of flying through Russian airspace over the Kamchatka Peninsula to stay away from any forecast volcanic ash. Normally, yes they would probably fly the most economic routing, but through an abundance of caution with regard to volcanic ash and turbulence, they will sometimes fly non optimal routings.
PSAjet17
Fri Jun 28, 2013 1:16 am
Did you look at these flights for just one day or for multiple days. As mentioned above, weather and winds play a big part in the actual route of flight.
roseflyer
Fri Jun 28, 2013 2:19 am
It is always interesting to see airplanes choose different tracks. It could be as simple as timing on the more southern route was full at that time.
What I find fascinating is on the SEA-ICN route asiana nd Korean will often go on different sides of North Korea with Asian taking the northern route over Russia and china while Korean goes over Japan and approaches ICN from the south east.
jetjack74
Fri Jun 28, 2013 2:53 am
Quoting danwoodman00 (Thread starter):
DL155 was upgraded from an A330, not a 763
Made from jets!
b747400erf
Fri Jun 28, 2013 5:59 am
Probably a combination of different weight, fuel burn and winds. My guess is the 777 was lighter and has a better fuel burn while the 744 was heavier and relied on going with the winds as much as possible to save costs.
Users browsing this forum: TOGA10 and 1 guest
