CALTECH
Black Tar Substance Over Inside Of Cowl
Sun Jun 30, 2013 3:01 pm
Has a hydraulic pump failure recently, and there was this black tar like substance dripping all over the inside of the cowl. It looked just like tar. Seemed as though it might have been Skydrol and engine oil mixing a bit under heat and pressure, it did smell burnt, and then created this tar. Has anyone else run into this ? Never remember seeing this before.
UNITED Would Be Nice
fr8mech
Sun Jun 30, 2013 3:36 pm
The top breaks off in chunks and the under layer is gooey? It's burned Skydrol (or equivalent).
It's hard to clean. There is a commercially available cleaner, but the name escapes me.
As I recall, we have replaced engines because of this contamination. Apparently, the residue can cause damage to the engine case after repeated exposure to high heat.
atlamt
Mon Jul 01, 2013 1:28 am
I think the cleaner you are thinking of is call skykleen.
Fwd to MCO and Placard
fr8mech
RE: Black Tar Substance Over Inside Of Cowl
Mon Jul 01, 2013 11:17 am
Quoting atlamt (Reply 2):
That's the stuff.
CALTECH
Mon Jul 01, 2013 2:14 pm
All of the substance was very runny. And a lot of it. Should have taken a pic. Never saw this amount before. Ran a 737 B system down, hyd pump failed. No crust, all of it was like hot tar. Very plastic.
fr8mech
Mon Jul 01, 2013 2:27 pm
Quoting CALTECH (Reply 4):
Yeah, it's Skydrol that has been exposed to very high heat. The crust tends to form in the cooler areas. We had a B747 come in one night that had the stuff dripping out the bottom of the cowl. The leak was at the pylon disconnect. The Skydrol had left a trail all the way down the case and had chewed up the ablative coating on lower parts of the T/R halves. What a mess.
CALTECH
Mon Jul 01, 2013 2:48 pm
Never saw burnt phosphate ester in that amount before.
fr8mech
Mon Jul 01, 2013 3:23 pm
Quoting CALTECH (Reply 6):
I've seen a lot of hydraulic leaks on engines, in the past. But, the tar-like appearance is fairly recent, so far as I can recall. Say, 5 years or so.
I wonder if there has been a formulation change...
CALTECH
Thu Jul 04, 2013 5:28 am
Quoting fr8mech (Reply 7):
http://skydrol.com/pages/aircraft.asp
Now starting to notice the black substance all the aircraft. From the slats seems to be pretty bad. Noticing it on the engine in a few places.
Fri Jul 05, 2013 11:21 am
I presume by your wordings it was an EDP.....was the pumps not switched off when the LOP warnings appeared.
CALTECH
Sat Jul 06, 2013 7:04 pm
Quoting CALTECH (Reply 8):
That should read, starting to see the black substance on many aircraft in different areas on the airplanes.
Quoting HAWK21M (Reply 9):
Yes, it was a EDP and it failed, and yes it was switched off before the reservoir leaked down to zero. Then they ran the slats down for landing which lost the rest of the fluid.
Sancho99504
Sun Jul 07, 2013 5:05 am
When I left DL in 2008, we received all but 737-700 and 777-200's at my station and I notice the tar looking substance streaking down the belly just behind the MLG doors on the 757 and 767, and on the elevators, rudders, flaps and ailerons, but never on the slats. On the CRJ-200 we received daily, it only had it on the rudder hinges.....Is Skydrol bad for the fuselage and wing skin like it is for the for the engine case?
kill 'em all and let God sort 'em out-USMC
CALTECH
Tue Jul 09, 2013 5:59 am
Quoting sancho99504 (Reply 11):
Top of the wing behind the slats,...
Photo © flightdeckimages
Not really for the metal of the engine case, as said above, but the ablative coating. Now on some of the bigger engines, such as 757 Rolls-Royce RB-211s, you do not want anything, not even water, to get on the Fan Case kevlar wraps.But it doesn't hurt the metal.
Do not believe Skydrol hurts aluminum at all. Don't get it on your tires though.
Think this low density hydraulic fluid is dirtier than the old skydrol. Old stuff seemed to strip the paint, this newer composition just seems to leave a black sticky residue.
bikerthai
Tue Jul 09, 2013 1:17 pm
So are you all referring to skydrol in the generic term? or what I consider Skydol, the original stuff?
I thought that the original Skydrol, the real bad stuff, is not used any more except in the Military.
bt
CALTECH
Tue Jul 09, 2013 1:39 pm
It still is just as nasty as anything that has come before. In this incident where it was all over the engine cowl, to hear a 50+ year old Tech scream like a kid tells the story. Burns the eyes just as good as the old Skydrol did.
yeelep
Tue Jul 09, 2013 2:57 pm
CALTECH, what fluid are you guys using? We've being using Hy-jet IV-A plus for eons and have always had leakage issues, especially the early build -700 and -900's. Its a very well known issue on the 737NG, check out 737-SL-29-095-A for a decent overview.
Users browsing this forum: longhauler and 2 guests
