zipsy
What Is This Hole On The Belly Of The 787?
Tue Jul 02, 2013 1:13 am
I'm interested what this hole on the belly of the 787 is for,any ideas?
Big version: Width: 1024 Height: 710 File size: 289kb
[Edited 2013-07-01 18:15:09]
Stitch
RE: What Is This Hole On The Belly Of The 787?
Tue Jul 02, 2013 1:47 am
This looks like it is at the front of the wingbox, not the back, and I believe the APU battery drain plug is in the aft area per Boeing presentations.
Web500sjc
Tue Jul 02, 2013 4:05 pm
the new battery drain?
Boiler Up!
KarelXWB
Crew
Fri Jul 05, 2013 12:20 pm
The battery exhaust should look like this:
Close, but no cigar http://vine.co/v/OjqeYWWpVWK
Fri Jul 05, 2013 4:13 pm
Any reason why the colour looks different in the opening thread pic of the area in question.
zipsy
Sat Jul 06, 2013 1:43 am
Found a better photo
Dalmd88
Sat Jul 06, 2013 12:36 pm
I'll take a guess. Exhaust for avionics cooling?
ferpe
Sun Jul 07, 2013 4:46 am
Quoting zipsy (Reply 5):
The hole is placed directly underneath the air cond (ECS) packs and should therefore be part of them I guess. Looks like some kind of drain hole perhaps for mositure? I think you can even see it in the principle picture below, the right hand pack has a tube that goes to the skin to expel something.
http://i298.photobucket.com/albums/mm262/ferpe_bucket/ECSdrainholeof787_zps23ba7701.jpg
http://i298.photobucket.com/albums/mm262/ferpe_bucket/787airconditioningpackinstallation_zps9de3a6f7.jpg
Seems like the form of the exit has evolved, my photo is from early prototypes and it is a flush back-angled exit, your exits seems to be with an exit cavity.
[Edited 2013-07-06 21:50:10]
Non French in France
zipsy
Sun Jul 07, 2013 8:36 pm
I thought is was some sort of drain for moisture too.Makes perfect sense
bikerthai
Mon Jul 08, 2013 2:16 pm
Quoting ferpe (Reply 7):
Quoting zipsy (Reply 8):
Don't look like a drain hole for moisture. Moisture drains are relatively small and usually mounted flush with pressure valve.
Don't think it's the battery vent drain as the batteries are located in the electronic bays (fore and aft). That vent is also small.
Strange how the hole is recessed with what I presume to be a titanium fitting as it is not painted. So, what ever it is it, the exhaust temperature is expected to be greater than 250F (120 C).
bt
kanban
Mon Jul 08, 2013 4:54 pm
BT, I agree with you, however it is odd that it is only under one pac with a keel beam between them. Could we have something above the pac that requires exhaust venting?
bikerthai
Mon Jul 08, 2013 7:48 pm
Quoting kanban (Reply 10):
I wish Tom was still around. He would have been able to answer this off the top of his head.
bt
zipsy
Tue Jul 09, 2013 2:38 am
ferpe
Tue Jul 09, 2013 7:28 am
Yes, it is the Nitrogen generation system exhaust, it is placed together (a bit behind) the left ECS pack, here a picture of it, one can see the exhaust:
7BOEING7
Tue Jul 09, 2013 8:48 pm
Quoting bikerthai (Reply 9):
Except on the 777 where they all have "little fins" that cover the drains. They are easy off/on for drain replacement. This was an FAA requirement to prevent any fluid (fuel) getting back into the airplane "bilge" during a negative pressure condition.
bikerthai
Wed Jul 10, 2013 2:49 pm
Quoting 7BOEING7 (Reply 14):
So, would this be true for the 787 and new models? Or have they found new ways to deal with the back pressure?
bt
Users browsing this forum: B2707SST and 2 guests
