trex8
787 Electric Architecture Due Wings Too Thin
Wed Jul 03, 2013 2:56 am
I can't find this on the Flightglobal website but in the print June 25-Jul 1 edition on page 11 in an article "Boeing locks down 777X performance, strategy" they quote Mike Blair VP marketing commenting on the de icing system on the 777X
"Although the 787's electric architecture is billed as a fuel saving innovation, Blair says, the actual reason it was selected was because the composite wing was too thin to accommodate a pneumatic system"
they go on to say the 777X wing doesn't have this problem so it will be pneumatic
A year or two before the 787 first flight there was a FG article also quoting a 787 electrical systems supplier that they saw no or very little likely fuel saving advantage to the all electric system. I could see a maintenance advantage though same article also said the same supplier said the electrical systems are so much higher in capacity that may not be true either.
So more PR hype by the marketing boys?
RE: 787 Electric Architecture Due Wings Too Thin
Wed Jul 03, 2013 3:41 am
If the 787 wing is too thin for hot air deicing, how can an MD-80 or 737 have it?
Quoting trex8 (Thread starter):
Even if this is so, removing the bleeds entirely means a big decrease in complexity for the engines, meaning as you say less maintenance, but also less design and construction cost.
7BOEING7
Wed Jul 03, 2013 4:17 am
It's one thing to use electric deicing on the wing but the size and complexity of the electrical system is way beyond what would be required for just that.
DocLightning
Wed Jul 03, 2013 5:49 am
I read an interview with Mr. Leahy where he said that he had discussed going all-electric on the A350 with his engineers and was talked out of it after they told him that, yes, it would be slightly more efficient, but a lot more expensive to design and that he would be unhappy with the reliability of such a system.
Sure enough, the 787's all-electric architecture is having some reliability issues.
Nothing that won't be worked out in the long run, of course. But it's been an unusually trying "teething period."
-Doc Lightning-
-Carl Sagan
bikerthai
Wed Jul 03, 2013 1:28 pm
Are they talking about fuel savings from a pure energy input/output stand point or did they consider the also the fuel impact of the weight of an electrical vs a pneumatic system?
Quoting Starlionblue (Reply 1):
Perhaps not too thin but too flexible. Imagine the number of flex joint you will need to duct a titanium tube up the wing.
Aren't the 787 leading edge a composite part with an aluminum wear strip? If so, then you are not going to blow hot air on to that leading edge for anti-ice. If that leading edge is all aluminum, then ignore that last comment . . . but the flexing of the wing would still be true.
bt
PITingres
Wed Jul 03, 2013 2:28 pm
I'm more inclined to think that the BS part is "the 777X wing doesn't have this problem so it will be pneumatic". If the 777X keeps its existing pneumatic bleed system, surely it's more to reduce the amount of redesign needed and maintain commonality with the existing systems architecture, than because of any dimensional properties of the new wing.
Revising the 777X into a no-bleed architecture would be a massive job, I would have to think beyond what one would want to do with a derivative.
Fly, you fools! Fly!
bikerthai
Wed Jul 03, 2013 6:29 pm
Quoting PITingres (Reply 5):
And would require engine manufacturers cooperation.
bt
airmagnac
Wed Jul 03, 2013 8:14 pm
I'd say it's somewhat the opposite, they're playing down the all-electric hype. Boeing PR touted the all-electric architecture as the best invention since sliced bread, so one would expect any future B product to be as electric as possible.
But today, generally speaking, reality is that power electric systems are bigger and heavier, imply a different management of thermal loads, new constraints on systems installation and still require relatively high maintenance. The benefits exist for sure, but they are far from being as clear cut as the 787 marketing claimed.
As said in previous posts, it makes perfect technical sense to be conservative on the 777X, but it kind of goes against the earlier claims of the marketing department. So it seems to me they're a little       :
"Well, ya know, it's really great, it really really is, but, well, ya know, maybe not as much as we said....But it's still great, I swear !"
My goal as an engineer is to fill my soul with coffee and become immortal
trex8
Wed Jul 03, 2013 8:17 pm
As a non technical type I was hoping technical types like yourself could enlighten me!
Quoting bikerthai (Reply 4):
It seems to me that when the 787 was developed B said that there would be a 20% fuel savings over the 767 and then various people in the media made much of it being of composite manufacture and the bleedless systems. As we now know, most if not 3/4 of that savings is from the engines, the rest probably split pretty equally between better aerodynamics, lighter weight from composites and some magical improvement due to bleedless equipment so I think they are talking about overall fuel use.
that seems to make a lot of sense
hivue
Wed Jul 03, 2013 8:27 pm
The 777X wing will have a lot of flex too, right?
Which I suspect is the real reason Boeing is going with pneumatic wing deicing on the 777X (and no electric brakes, too). They're going to have bleed air anyway, so why not use it?
Thu Jul 04, 2013 1:21 am
Quoting hivue (Reply 9):
Agreed. Why reinvent the wheel? Same deal as with the 747-8. Evolution not revolution.
Quoting trex8 (Reply 8):
For the record, I'm not a technical type. I went from enthusiast to pilot, and so far only pilot of small planes sans fancy stuff like leading edge heating or, heck, air conditioning. I just know how to break the things.
cornutt
Thu Jul 04, 2013 2:26 am
Hmm... makes me wonder how Boeing was planning to handle this back when they were thinking about the folding wing ends for the 777.
Thu Jul 04, 2013 9:34 am
Quoting cornutt (Reply 11):
Not saying the folding wings would have been a trivial design challenge but designing an opening rigid conduit does not present the same issues as designing a flexible conduit.
[Edited 2013-07-04 02:34:17]
CALTECH
Thu Jul 04, 2013 4:16 pm
No Bleed Air = Fuel Savings. Whether it will save money in the long run with this electrical anti-ice protection for the leading edge shall have to wait to be seen. It is different. There is Bleed Air for anti-icing protection on the 787 however, just not as extensive as it's predecessors.
It has already been done since the 707 days with Boeing. Flexibility of the wing has nothing to do with the type of anti-icing system on the 787 wing.
UNITED Would Be Nice
bikerthai
Fri Jul 05, 2013 1:17 pm
As noted in artist sketches. We will have to see when the plane actually takes off.
The wing flex would be a design challenge, but do-able.
My real question is:
Will the new 777 engine use the same core/similar core as the old 777 engines or will they use the 787 or similar core.
How hard it would be to take the old 777 core and make it "bleedless similar to the 787". I put bleedless in quotes as we all know that it's not completely bleedless.
bt
Stitch
Sat Jul 06, 2013 1:58 am
Quoting bikerthai (Reply 14):
Looks like it's a new core based on what's been reported, as using a scaled GEnx core would only get them half of the SFC reduction Boeing wants.
The GE9X's HPC will have 11 stages compared to the 10 on GE90 as well as new powdered metal alloys to increase the pressure ratio from 19:1 to 27:1. The total pressure ratio will be 60:1 vs. 50:1 on the GEnx and 40:1 on the GE90.
a380900
Sat Jul 06, 2013 1:21 pm
So this feels like "mystery solved" to me. That must explain why the A350 wings look so similar to previous airliners in shape and flex whereas the 787 wings look like a new generation of airplane. We see that the 777X will not use that.
I thought the 787 had some bleed, for deicing the engine nacelles or something. No?
7BOEING7
Sat Jul 06, 2013 4:36 pm
Quoting A380900 (Reply 16):
It does.
ferpe
Sun Jul 07, 2013 4:24 am
The GE-9X is as clean sheet as can be (check the GE-9X thread where a guy in the know makes that clear, jetlife2) so that has no influence on the choice of deice. GE could have done little aircraft bleed (GEnx-1B where only the engine inlet is deiced with bleed) or big bleed like the 777. The deciding factor was probably whether they wanted to grandfather the electrical architecture from the 777 or from the 787 and this has normally certification considerations behind it but also fuselage design considerations. If you go to more electrical you need more avionics equipment bay space, more cable conduit space and so on. It essentially means a totally redesigned fuselage on top of a new wing, then you might as well go clean-sheet altogether.
The more electrical architecture was discussed at length (and depth) in the early parts of the A350 prototypes thread, CM (who was part of the 787 project) then clearly stated it saves fuel and maintenance (in the end when mature) but it is not better in weight until the power conversion stuff can be made with air cooling of the semiconductors. Right now it is liquid cooling (like the IBM mainframes CPUs) and that is heavy and a bit complicated as you need an extra cooling system in the frame just for the (famous  ) power conversion racks.
There was also a long and deep discussion on the power conversion efficiency of pressure to work (ie bleed) or electrical to work, the electrical to work proponents seemed to have better arguments. If B goes less electrical next time when they do clean-sheet then we know there is something we don't know about the 787 architecture  .
Non French in France
JoeCanuck
Sun Jul 07, 2013 10:05 pm
The bleed architecture of the 777x has everything to do with getting as much of the new plane grandfathered in on the 777 approvals, as well as to keep r&d costs down, and nothing to do with wing thickness.
Bleed is a significant system in aircraft that use it and takes a lot to get certified. To lose the certifications for, and have to re-cert, all of the pressurization, heating, cooling, anti-ice, engine start and numerous other vital systems, really would make the 777x an all new plane.
The flexibility of the anti ice tubes is the least of the problems, and has never been much of an issue. Just look at the flex of a B-52 wing.
What the...?
lightsaber
Crew
Mon Jul 08, 2013 3:33 am
Quoting DocLightning (Reply 3):
Really? Pneumatic system are notorious for taking more maintenance time than electrical (or even hydraulic). Did they screw up on the heating pads and having them burn out?
Any my job is now to design pneumatic components. So while I would *love* what you said to be true (job security), it is the opposite of my engineering experience on other projects though...
Quoting JoeCanuck (Reply 19):
Your correct in the extensiveness of bleed air certification. Quite a bit of work is done to verify not only adequate heating, but durability of the system to thermal shock. And then you have to add an engine with all of its "adventure" into the game.
Not the frame I was thinking, but there have been some highly flexible wings with conventional anti-icing.
Quoting Stitch (Reply 15):
It will have to be a new core for the CMC turbine blades and the new compressor blade designs. That would be giving up too much of the fuel burn improvement (as you noted).
Not hard, but what's the point? The GE-90 core is now out of date...
Lightsaber
JHwk
Thu Jul 11, 2013 4:54 pm
Quoting lightsaber (Reply 20):
Electric systems throughout the ages have taken a long time to make reliable. You might be able to take advantage of 99% of lessons learned from marine and stationary applications, but that still only covers about 60% of the design issues.
The electrical power system for a data center has ~99.999% availability if you provide two independent power paths to every load. The power system for a utility has 99.9% availability.
Boeing seems to have learned a number of important lessons on all-electric systems, but there still seems to be a level of evolution needed to make it a mainstay. Give it 10 years on the 787 and then give it a shot for the next product.
DocLightning
Fri Jul 12, 2013 8:14 am
Was the entire type grounded for a problem in its pneumatic system? That's a pretty serious reliability issue. And please don't tell me that the battery is unrelated to the electrical system.
In fact, most of the delays in the program have revolved around the all-electric architecture.
-Doc Lightning-
-Carl Sagan
bikerthai
Fri Jul 12, 2013 1:29 pm
Quoting DocLightning (Reply 22):
Doc,
If you wait 10 years and look back at this incident, you may conclude that the grounding was an over reaction to something unknown.
To nit pick, the grounding was because of a safety concern (which may have come from both reliability and system design short fall) but not because of reliability in itself.
Beside, is it really true that many of the bugs and delays they are having with the 787 come from systems that were converted from pneumatic to electrical?
As for the battery fire issue, the battery was there for back-up. The system that replaced the pneumatic starting system didn't really fail did it?
bt
PPVRA
Fri Jul 12, 2013 4:03 pm
Doesn't a thinner wing save fuel?
"If goods do not cross borders, soldiers will" - Frederic Bastiat
Sat Jul 13, 2013 12:17 am
Quoting PPVRA (Reply 24):
Not necessarily. It depends on the specific wing shape and the operating speeds. For example, supercritical wings for transonic flight tend to be fatter than more non-supercritical ones.
Users browsing this forum: 77west, Google Adsense [Bot], Raventech and 1 guest
