NWADC9
FAA Type Ratings - 61.31(a)(3)
Thu Jul 04, 2013 4:09 pm
Under 61.31, a pilot is required to hold a type rating for large aircraft, turbojets, and "other aircraft specified by the Administrator through aircraft type certificate procedures." Are there any aircraft that fall under that "other" category?
I convert Jet A and 100LL into noise.
Web500sjc
RE: FAA Type Ratings - 61.31(a)(3)
Thu Jul 04, 2013 4:51 pm
yes, Mitsubishi MU-2
Boiler Up!
DiamondFlyer
Thu Jul 04, 2013 10:42 pm
While not required by 61.31(a), the Zeppelin NT requires type specific training as set forth in 61.51(h), which is very similar to a type rating.
-DiamodnFlyer
From my cold, dead hands
ptrjong
Fri Jul 05, 2013 9:48 am
Quoting web500sjc (Reply 1):
Why the Mu-2?
mcdu
Fri Jul 05, 2013 10:09 am
Quoting ptrjong (Reply 3):
Why the Mu-2?
MU-2 has unique handling charecteristics. In lieu of ailerons it used spoilerons. Without the requirement of a type rating many pilots killed themselves and others because they has to have little formal training to fly the airplane. The MU-2 is a great fast airplane that had capabilities much greater than the pilots flying them. As a result of numerous crashes from losss of control the mandate to type rate was born.
ptrjong
Fri Jul 05, 2013 11:13 am
Thanks.
larshjort
Fri Jul 05, 2013 11:28 am
Why the Mu-2?
It has no ailerons, only flight spoilers which makes it a bit tricky to handle. I believe there were a few crashed in the US before it was a requirement.
http://en.wikipedia.org/wiki/Mitsubishi_MU-2#Safety_Concerns
/Lars
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
DashTrash
Fri Jul 05, 2013 5:34 pm
To my knowledge there is no MU-2 type rating. The aircraft does require type specific training and recurrent training, but after completion a pilot will not have a type rating on his certificate. It's actually a little more stringent since recurrent isn't required to continue flying other aircraft requiring a type after the checkride is passed under Part 91. The MU-2 does require recurrent to keep flying it.
ROSWELL41
Sat Jul 06, 2013 3:24 pm
Quoting DashTrash (Reply 7):
The MU-2 is also cheap to acquire which adds to the aforementioned problems.
Users browsing this forum: Nean1 and 2 guests
