cha747
Is Aviation Keeping The Dot Matrix Printer Alive?
Fri Jul 05, 2013 12:31 am
OK...totally random thought. I step onto a modern marvel of an airplane that was designed by advanced CAD programming, whose seats have more computing power in the IFE than the Apollo astronauts had to land on the moon, and I've used my smart phone to actually board the plane. So why are the reports brought to the cockpit from the gate agent printed on a dot matrix printer? Would it be that hard to convert over? Is the continuous tractor feed an absolute necessity? I just looked at the prices of a few dot matrix printers and they are actually pricier than entry-level laser printers. What gives? Why are we still using 1970's/1980's technology in 2013 at the gate?
You land a million planes safely, then you have one little mid-air and you never hear the end of it - Pushing Tin
OB1504
RE: Is Aviation Keeping The Dot Matrix Printer Alive?
Fri Jul 05, 2013 12:40 am
I actually never stopped to consider that until now, despite constantly fighting with a dot-matrix printer every day at work.
BreninTW
The big advantage of a dot-matrix printer over laser printers is that it can (relatively) quickly and cheaply print duplicates. Dot-matrix printers are still pretty common in any application where a duplicate is required. They are the modern equivalent of writing with a sheet of carbon paper between two blank sheets of paper.
Another advantage of the tractor feed is the sheer amount of paper it can feed ... most laser printers are limited to a ream in the tray (500 sheets) -- while that may sound like a lot, a box of tractor-feed paper can easily have many times that many sheets. This reduces the risk of a flight taking a delay while hunting down paper to refill a printer tray.
Prost
And they're oh so wonderful when the ribbon is out of ink.
brilondon
Fri Jul 05, 2013 12:49 am
Quoting Prost (Reply 3):
And I loved to change the ribbon...
Rush for ever; Yankees all the way!!
Prost
Fri Jul 05, 2013 12:52 am
That may explain why the ribbon is always low!
PITingres
Fri Jul 05, 2013 1:00 am
Quoting cha747 (Thread starter):
Because it works?
Re the thread title, aviation certainly isn't the only user of dot matrix printing. Consider car rentals, for instance; many (not all) are still using dot matrix, because they work with multi-part forms.
Fly, you fools! Fly!
cha747
Fri Jul 05, 2013 1:24 am
Quoting PITingres (Reply 6):
Because it works?
Fair enough...but so did hand-written bag tags, hand-written boarding passes, paper tickets, and.... well, you get my point. Everything else has changed, why not this?
Type-Rated
Fri Jul 05, 2013 1:26 am
A lot of retailers use dot matrix printers to print sales receipts, warehouse pick slips and such. The Okidata 320 dot matrix printer used to be ubiquitous because it was a very reliable printer and it can print forms 6 copies deep.
And retailers also use them to print reports that will have copies sent to different departments too.
What brand dot matrix printers do you normally see at airports?
Fly North Central Airlines..The route of the Northliners!
B757capt
Fri Jul 05, 2013 1:30 am
Quoting OB1504 (Reply 1):
Long live the okie data!
The views written by this user are in no manner the views of my employer and should not be thought as such.
AeroWesty
Fri Jul 05, 2013 1:33 am
I always thought it had to do with modern-day printers not having a parallel port interface for legacy mainframes which the airlines operate on. It would cost a lot of time and effort to recode for a different kind of print interface, is what I was told. As dot matrix is still a rather cheap and mature technology, there isn't any great rush to replace them.
Lengthy printouts done at the gate now will probably be transmitted by tablet in the near future anyway, making the investment in a different type of printing apparatus irrelevant.
International Homo of Mystery
DocLightning
Fri Jul 05, 2013 1:42 am
The medical industry uses its fair share of dot matrix printers. For example, our carbon duplicate lab slips have each physician's name and a checkbox next to it so that we can simply check the box next our name and the lab knows where to send the results. Our names are printed using a DM.
When the ability to print a carbon copy is more important than font quality, DM makes sense.
-Doc Lightning-
-Carl Sagan
9252fly
Fri Jul 05, 2013 1:57 am
They commonly have addresses information can be sent to remotely,sometimes from on the other side of the world. The idea is to get the attention of those monitoring/using the printer,especially considering the amount of noise they produce when printing. Examples would be flight plans and status updates,fuel loads,passenger handling information,baggage tracing and forwards,the list goes on and on.
rfields5421
Fri Jul 05, 2013 3:27 am
Your smart phone has 10X or more computing power than the Apollo astronauts had on their ship. I don't think the Hubble has been upgraded to better than a 486 processor yet.
But those entry level lasers will not handle the printing load at a gate. You need something running in the $900-1,200 dollar range for a laser printer - for every gate.
Quoting brilondon (Reply 4):
But at least the copies are legible. When you run a departure list, printing seven copies - and find the toner cartridge is out. Not only will you have to change the cartridge, but the flight will have to hold to wait on their copies.
Quoting cha747 (Reply 7):
It will change when (1) the costs come down for laser printing to be cheaper, (2) the lasers are more reliable, and the big reason (3) the software for the gates is rewritten to print the correct number of copies automatically on laser printers.
Of course, the plan to get rid of three letter IATA codes and use four letter ICAO codes is also waiting on a software rewrite - been doing so for some 20 years.
I would not hold my breath waiting for the change over.
And I'm not sure that the laser printers are faster from hitting the print command to actual output of all the multiple copies than the dot-matrix printer.
BreninTW
Fri Jul 05, 2013 3:40 am
Quoting rfields5421 (Reply 13):
And laser printers have this rather nasty habit of overheating at the worst possible moment ... something that rarely happens with DM printers.
jfidler
Fri Jul 05, 2013 3:51 am
I'm guessing #3 is the main reason. Laser printers can be loaded with multiple paper trays, and report back their tray status and toner status over the network to an IT person, so those issues can be dealt with before they arise. It's got to be a huge effort to reprogram all the gate software though.
FlyBTV
Fri Jul 05, 2013 3:52 am
This may be obvious/implied, but not every carrier uses DM printers. When I was with B6, we printed everything at the gate on laser. In my time there, I don't think I ever saw a DM printer, though all the other airlines had them.
Edit: Actually, we did print a few reports on thermal paper at the gate, now that I think about it. But this was before they made the reservation system transition. Not sure what they do now. No DM anywhere though.
[Edited 2013-07-04 20:55:10]
blueflyer
Fri Jul 05, 2013 6:35 am
Money.
As aluded to by flyBTV, a new airline buying the newest software versions from the usual vendors (eg Sabre) and building their infrastructure from scratch will use laser printers because they're natively supported and the acquisition and maintenance costs are lower.
They are not so lower, however, that it would make sense for a legacy airline to retire their existing printers, parts and supplies, rip out their current infrastructure for a new one, upgrade to newer software or update their current one, etc...
In addition, laser printers in large environments such as airlines work best in an IP network. That means not just new printers, but new computers, new network management, new switches, etc...
There are other industries besides aviation in the same boat. My semi-educated guess is that most legacy airlines will retain their dot matrix printers until wireless networks are advanced and secure enough to replace their existing network and bypass wired IP altogether. When a handful of antennas on top of IAD's main terminal is all it takes for United to connect to the printer and terminal at every gate, then they'll roll out the laser printers.
Democracy 2016: 3 million California votes < 100,000 Midwest votes.
flyhigh@tom
Fri Jul 05, 2013 7:17 am
Out of the top of my head...i think the dot matrix is so versatile...esp in aviation where you need triplicates and more of every document.
On a daily basis...we get to sign fuel receipts (6 of them with carbon paper in between), load sheet (4 copies), pax manifest (triplicate), cargo manifest (triplicate) ....all on board sheet (triplicate)
the dot matrix is really useful for the above applications and still provides hell a lot of savings over laser.
long live dot matrix
YLWbased
Fri Jul 05, 2013 8:26 am
Majority of the Taxi Receipts in Hong Kong are printed with Dot Matrix printers, and courier forms.
I think aviation industry only makes up a small percentage of all dot matrix users.
YLWbased
Hong Kong is not China. Not better or worse, just different.
EIDL
Fri Jul 05, 2013 8:46 am
Still extensively used in the medical sector here for printing on NCR security paper stock - every state contractor doctors surgery and every single pharmacy will have at least one, generally an Oki / Okidata 3320 in pharmacies which seems to be the one at every gate in every airport here too.
I've got three different, new, ones in my van at the moment.
Palmyboy12
Fri Jul 05, 2013 10:37 am
Why do we still board (and for most avgeeks, god-worship) an almost 50 year old quadjet?
"You can't be a real country unless you have a beer and an airline." Frank Zappa
abrown532
Fri Jul 05, 2013 10:44 am
It is handy for printing triplicate copies relatively quickly...which when needing to print out pax lists/loadsheets and loadplans is handy, however, not when they sometimes inevitably suck in the paper they have just printed which has happened to me several times requiring a complete dismantling of the machine to free the paper, they have their downsides! But mostly good....
9lflyguy
Fri Jul 05, 2013 11:46 am
At my company, and I'm sure its the same for many regionals, the flight attendant's paper work is included in the pilots dispatch release. Having several places per page that are perforated makes separating the two a lot easier for the flight crew and no one loses any of the information they need.
Where I work as a flight attendant, we have both. At our base IAD we print in the crew lounge via laser and at our out stations via dot matrix. My self personally, I prefer the dot matrix. It's uniform, easy and clear to read, usually prints reasonably straight and having perforated sections so i can filter what I need for each flight and what I don't makes the dot matrix printers the clear winner. Just an opinion from someone who deals with this paperwork on a daily basis.
319 320 321 722 732 733 734 735 737 738 739 752 753 763 772 CR2 CR7 CR9 DHA D8B D8C D95 145 170 175 190 M82 M88 M90 S340
Slcpilot
Fri Jul 05, 2013 12:13 pm
Urban legend.... May be true or not...who knows?
Delta supposedly has several warehouses full of DM paper, and that's been part of the reason for the continued DM use. In fact, more than one gate agent has joked D-E-L-T-A
Destroy
Every
Last
Tree
Available
It seems to me a paperless cockpit will greatly reduce the need to print at the gate, but certainly not entirely!
Cheers!
SLCPilot
I don't like to be fueled by anger, I don't like to be fooled by lust...
smi0006
Fri Jul 05, 2013 12:19 pm
Ughh the bane of my existence! I can't say how many flights have been delayed be a min here or there, as I rapidly try to rebuild the bloody things after it got jammed!
We still use them for all our pre-flight editing as well, I find it therapeutic sitting there editing, marking off group coded pax for the flight whilst sipping my coffee. Using A4 paper and a laser printer wouldn't quiet be the same.
But I still love them, something very nostalgic about folding a long manifest as it prints, whilst you watch the passenger board - Romance of travel, no. Romance of groundstaff maybe :P
brilondon
Fri Jul 05, 2013 1:03 pm
Quoting Slcpilot (Reply 24):
Destroy
Every
Last
Tree
Available
Cheers!
SLCPilot
They then could not say we just need to finish up the paper work to explain why they are 20 minutes late leaving the gate.
airbazar
Fri Jul 05, 2013 3:05 pm
What I've alays wondered is, why do we need printers at all? Can't that information be transfered electronically?
exFWAOONW
Fri Jul 05, 2013 3:23 pm
Fed regulations require a copy of the flight release signed by the pilot be kept for a minimum of 1 year, to ensure he has/had a correct copy in case anything went wrong with the flight.
At NW we went to recycled paper in the printers. It was a continuous roll (like you see in bathrooms) with no folds. We used to cut to length over any convenient countertop edge. It could be a real pain as you got to the end of the roll as the pages all wanted to curl up instead of laying flat on your workspace.
Is just me, or is flying not as much fun anymore?
kgaiflyer
Fri Jul 05, 2013 3:26 pm
Quoting b757capt (Reply 9):
I just priced an Okidata Microline 320 at $500.26.
OTOH, retailers are hawking cheap laser printers for as little as $129.00 in my area. True -- they won't do six-part forms.
[Edited 2013-07-05 08:55:58]
airbazar
Fri Jul 05, 2013 3:49 pm
Quoting exFWAOONW (Reply 28):
You can do all of that with electronic versions, right down to signing it. I work in the financial services industry. We too have very strict SEC regulations.
flyby519
Fri Jul 05, 2013 4:10 pm
Quoting airbazar (Reply 30):
Anything in aviation is a good 10-15 years behind the rest of the industries in the world.
These postings or comments are not a company-sponsored source of communication.
exFWAOONW
Fri Jul 05, 2013 4:40 pm
True, but when the ^%%$ hits the fan, (I won't use the appropriate aviation version of that phrase) they want to see originals, not digiatal copies that can be doctored after the fact.
blueflyer
Fri Jul 05, 2013 7:54 pm
AFAIK, there is no approved electronic signature protocol for flight planning purpose yet.
Quoting exFWAOONW (Reply 32):
It's not necessarily an issue, there are many ways to make digital copies (almost) tamper-proof, starting with storing the copy in several independent storage systems...
JBo
FOD?
I'd take the awe of understanding over the awe of ignorance any day.
FlyASAGuy2005
Sat Jul 06, 2013 1:38 am
Quoting kgaiflyer (Reply 29):
I just priced an Okidata Microline 320 at $500.26.OTOH, retailers are hawking cheap laser printers for as little as $129.00 in my area. True -- they won't do six-part forms.
From our IT site, we're getting them (TTY printer) for significantly less. Of course this is because we're getting a HUGE corporate discount.
Flip side of it is we recently got a brand new laser printer for our office. It has yet to print a single sheet of paper due to software and hardware issues. HP finally decided to take it back and they will send us a new one after sitting for over a month.
What gets measured gets done.
Sat Jul 06, 2013 2:41 am
Quoting blueflyer (Reply 17):
Rental car companies, for example.
Quoting YLWbased (Reply 19):
All the HK taxi receipts I have seen are printed with thermal printers, not dot matrix.
There is a difference in magnitude. A large trading firm can easily process hundreds of thousands of trades per day. If you had to print out the confirmations (one for the customer, one for each counterpart) methinks that would be way more paper than an airliner produces.
More importantly, there is a difference in speed. I can't remember the exact details but recent Dodd-Frank regulations and so forth require confirmations to reach customers in something like ten minutes after the trade. You can't do that with paper.
There simply is no big enough incentive for airlines to invest in such systems even if regulations allowed them. On the other hand, in areas where going paperless has bigger advantages, like Electronic Flight Bags, airlines are rushing to adopt.
Booking systems are by and large a bastion of old mainframe systems, which is kinda funny since that's where many mainframe systems started. In the financial industry, product complexity and trading volumes have exploded in the past few decades, necessitating ever more advanced systems. For airlines, on the other hand, a booking now is not much different from a booking thirty years ago.
MSJYOP28Apilot
Sat Jul 06, 2013 6:54 am
The biggest thing keeping dot matrix printer alive is fear of modern technology. Just about everything can be done electronically. The FAA in most FSDO offices will and have approved Op Specs for just about anything kind of electronic record keeping and the dispatcher signature.
With pilots getting iPads, you could get the release and flight plan from dispatch on there and if the airline POI allows, it could be used to satisfy the FAR that requires the release and flight plan be carried o n the plane.
The big thing keeping Dot Matrix alive is that airlines dont trust modern technology. A flight cannot depart unless it is authorized by the dispatcher. The dispatcher must be able to send out the release for all his flights which normally number in 50-60 range. Modern technology is very prone to glitches and crashing. Older technology such as the AA Sabre system is a lot more stable and doesnt crash very often.
Airlines dont trust modern technology enough because they like the reliability of the older systems. Many dispatch offices use technology that is 10 to even 30 years behind the times. AA Sabre DECS is decades behind the times technology wise.
If the dispatcher cant plan a flight or send the release or the station/crew can pull the release because the system crashes often or gets glitchy, you will start taking delays and cancellations for it.
There are also some FAA FSDOs that dont trust modern technology and like things documented like they have been in the past.
Even with iPads, you are screwed if the iPad breaks or goes missing and are at an outstation unless you have a paper backup available to have the release on.
The dispatch release and appended weather package have so much info on them that it is almost better to have it in paper copy. The dispatch release has the fuel load breakdown in terms of how much fuel is given for enroute, alternate, reserve and extra fuel. It has the aircraft tail number, type of flight plan filed, equipment codes, MEL list, the flight plan and the winds/temps aloft at each fix plus all the weather. This is a huge amount of info. Add on to that the all the amendments made to the release such as changing, adding or removing alternates or MELs and it almost makes it a lot easier to have a paper copy to keep everyone the same page especially if their is some accident and the FAA wants documentation.
Many pilots check mark things off on the release. That forms part of their own personal check list so they know they also checked the weather, NOTAMs, and release just in the case the dispatcher missed anything or things have changed. It is a joint legal responsibility.
Sat Jul 06, 2013 8:07 am
Quoting MSJYOP28Apilot (Reply 37):
Airlines are businesses and will (in an ideal world) make the investments with the best return. If this means moving to new printers, or away from printers entirely, they will do so.
However if an investment in, say, new branding or new aircraft or new routes has a higher return, airlines will do that instead. When I worked at a major technology company, a European railroad company was on the verge of renewing all their servers. When it came time to announce the vendor, they told everyone they were buying new locomotives instead as this was a better use of their capital.
This is a common misconception. Modern technology is not more prone to glitches and crashing than old technology; rather the opposite in the grand scheme of things. You are confusing consumer systems with enterprise systems. The stuff that corporations (should) use for mission critical applications bears little resemblance beyond the interface to what sits on the home laptop. Modern enterprise systems are at least as reliable, if not more so, than their older counterparts. Most importantly change management, testing and redundancy on enterprise systems are the as robust today as thirty years ago.
Then have three iPads. Paper has reliability issues as well, and can also go missing. Printers break all the time.
The fact that there is so much info should make a paperless solution better. Amendments are way easier to handle electronically. If there's an accident paper can be lost or destroyed. Enterprise document management and enterprise resource planning systems (I have worked with both) have very robust tracking routines for things like amendments.
Even in General Aviation, paperless is taking over. I never bring charts or do flight planning on paper. All on the iPad (ForeFlight rules). Sure the iPad could break down but I would still have an advanced avionics system with a moving map, and multiple radios. Doing weight and balance on paper? Forget it. There's an app for that. And this is in a Cessna 172. I'm much more likely to make a mistake doing fuel planning or weight and balance on paper than on the iPad.
Easily implementable on an iPad. As a parallel, many modern airliners have electronic checklists with "checkmarks". Heck, a Cessna 172 with G1000 has electronic checklists. As for not missing anything, with electronic checklists you can have an actual record beyond just a checkmark on a piece of paper that could burn with the airplane if there is an accident.
As I see it, the whole thing is as generational as dead tree books versus ereaders. As the years pass, the people who are enamored with paper will retire, to be replaced with e-heads.
[Edited 2013-07-06 01:09:58]
[Edited 2013-07-06 01:11:47]
FlyDeltaJets
Sat Jul 06, 2013 3:50 pm
I worked ops for 1 airline and we had a virtual printer that allowed us to only print what was needed. Now the airline I currently work ops for anything that is sent is automatically printed to no less than 6 different printers. Total waste of paper.
The only valid opinions are those based in facts
jetblast
Sat Jul 06, 2013 6:16 pm
Seems a bit overkill! I order the DM paper as well as ribbons from Staples, they still make them.
Speedbird Concorde One
dtw2hyd
Wed Jul 10, 2013 5:54 pm
It is possible but requires a software redesign to make sure no manipulations of electronic records is possible. Note that financial services industry did it because law forced them after all the scandals. Few years back any corporation can say they will keep e-mail only for a month. That was a major excuse to produce to old records. Now they cannot do that.
DMP is the only "impact" printer which can print different fonts and graphics, so as long as there is lot of pre-printed stationary sitting around in airlines will continue to use it.
Even though you can print same page multiple times with laser it will cost more. There is no simple way to implement color coded copies. And most of the laser printers are full page printers and paper need to be certain weight for it to work properly. You can literally use wafer thin paper with DMP.
With thermal printers, print disappears after a while.
Viscount724
Wed Jul 10, 2013 10:06 pm
And I assume a dot matrix ribbon is much cheaper than laser or inkjet printer toner. When I have to replace the 4 separate ink cartridges for my old (but reliable) Epson inkjet printer it costs almost as much as the printer itself.
rfields5421
Wed Jul 10, 2013 10:38 pm
Quoting Viscount724 (Reply 42):
By design. Gillette didn't get rich selling razors - blades is what made money
Klaus
Fri Jul 12, 2013 10:38 am
Or unless you've got another iPad at hand (all airlines using them have one for each pilot as far as I'm aware). And even if both should break (highly unlikely) you can provide information to the pilots' smartphones via secure VPN for at least quadruple redundancy even just on board.
Quite the opposite. The more information, the better it gets on the electronic screen as long as access and presentation are handled properly. Clarity and resolution are plenty on current iPads and much better than regular dot-matrix printouts.
Much easier and more reliable with a proper electronic implementation.
Quoting DTW2HYD (Reply 41):
That is bog-standard technology by now.
Goldenshield
Mon Jul 15, 2013 10:15 am
Another thing to note is that airlines still use the SITA teletype messaging system for everything from inventory mangement to passenger manifests, and it's easier to print out and tear off a 3 inch message, than to waste an entire sheet of paper on it.
sprout5199
Tue Jul 16, 2013 1:37 am
Quoting Starlionblue (Reply 38):
You don't take a sectional with you? IIRC here in the states, you are required to have one if you are flying beyond the local area(25 miles) of you home base on a VFR flight.
Dan in Jupiter
Tue Jul 16, 2013 1:44 am
Quoting sprout5199 (Reply 46):
I do have a sectional. It's on the iPad. It is also on the iPhone for that matter. Exactly identical to the paper sectional except that I can zoom in and out, click on airports, MOAs, etc to get info, I have weather overlays...
The examiner on my IFR checkride didn't seem to mind. She uses Foreflight herself. Having said that, the instructors at my school say that it is a bit of a grey area in the regs.
sprout5199
Wed Jul 17, 2013 11:04 am
Quoting Starlionblue (Reply 47):
I did some research and you are not "required" to have one, however, if there is an issue, the FAA will come down hard with the good old "failure to prepare" for a flight.
I should get one as my old eyes have a hard time seeing the radio freqs and so forth on the sectional.
Dan in Jupiter
Wed Jul 17, 2013 11:23 am
Quoting sprout5199 (Reply 48):
Absolutely fair. However lots of people get lost or miss radio frequencies with a sectional. I'm not saying one is better than the other in absolute (for me the iPad is better), just that if I am well prepared with an iPad and Foreflight plus a moving map on the G1000, I'm not really worse off than with a sectional.
No need for the sectional. Radio freqs are listed in the airport details of Foreflight. Worst case Foreflight can display the actual pertinent A/FD page.
Not to mention the G1000 database has all the radio frequencies so all I need to do is scroll to the airport and click a few times for automatic tuning.
[Edited 2013-07-17 04:56:57]
Users browsing this forum: Mani87 and 3 guests
