dibble777
Damage To Fuselage Aluminium Vs Carbon Fibre
Sat Jul 13, 2013 5:19 am
In the case of damage to a fuselage by a truck or by fire how does repair of an aluminium skin and underlying structure compare with the repair of a carbon fibre skin? In terms of time/cost/feasibility.
Klaus
RE: Damage To Fuselage Aluminium Vs Carbon Fibre
Sun Jul 14, 2013 10:13 am
One thing I'm wondering about: With thermal damage in the crown area on the ET 787, how do you determine the exact extent of the skin area to replace, assuming that the heat spread beyond just the area where external damage actually became visually apparent?
How do you know how far the composite structure is actually damaged? Do you cut out pieces and subject them to microscopic and chemical testing?
How would you determine the extent of such damage with aluminium skin?
fr8mech
Sun Jul 14, 2013 3:01 pm
Quoting Klaus (Reply 1):
Eddy current conductivity testing and sometimes hardness testing.
Klaus
Sun Jul 14, 2013 4:06 pm
Quoting fr8mech (Reply 2):
Okay... so external sample testing is usually not required even after a partial fire?
fr8mech
Sun Jul 14, 2013 4:12 pm
Quoting Klaus (Reply 3):
We've never done it.
But, we always follow engineering's lead in these matters and they'll typically talk to the manufacturer.
Klaus
Sun Jul 14, 2013 6:20 pm
Quoting fr8mech (Reply 4):
If that procedure has been validated properly, there shouldn't be a problem with it.
Makes sense.
Are repair procedures for the 787 already known? I would expect that to be the case at least at the existing operators.
KPWMSpotter
Sun Jul 14, 2013 8:14 pm
There are a handful of established non-destructive inspection methods for composite laminates. Most maintenance checks only specify a general visual inspection for damaged fibers on the surface of the laminate. A more detailed first check is a "sonic tap test", where a trained mechanic will tap a heavy metal coin against the component, listening for any change in sound across the part where there may be damage. Where there is large delamination it is very easy to tell by the tap test (a good laminate will have a sharp tapping sound, a delaminated part will make more of a dull thud). Boeing's inspection manuals (at least for the 737, 757, and 767, possibly others too) provide guidelines for a proper tap-test, down to the required size and weight of the "coin" used to tap the part.
Where damage is suspected, inspectors can utilize thermal, ultrasonic, or X-Ray inspection. Thermographic inspection is used where moisture ingression is suspected. The part is heated in an oven, then brought out to cool at room temperature. Composite structure will cool rapidly, but trapped moisture will remain hot and show up on a thermal camera.
Ultrasonic is the best method to find exact damage. A tool is used which emits a sonic pulse and measures the return echo (very similar to SONAR, but on a smaller scale). Changes in the return pattern can indicate voids, defects, or damage.
I'm sure there are other inspection methods available, but these methods have been in place for decades to inspect composite components. The 787 requires inspection on a much larger scale, so Boeing may have developed entirely new procedures.
I reject your reality and substitute my own...
Klaus
Sun Jul 14, 2013 9:08 pm
Quoting KPWMSpotter (Reply 6):
Sounds a bit... unscientific, though, doesn't it...?
I was asking because if the crown area in question was indeed open without a crew rest module up there, the heat should have spread out across a larger area, with decreasing intensity.
Given the very tight tolerances for the fuselage, Boeing must have specified and certified safe damage limits for the material. They will need to have quantifiable tests for whether a fix / replacement is required in a certain area.
I guess the actual repair will be documented to the public to some extent. It would just be interesting to have a look into the repair manuals right away...
dynamicsguy
Mon Jul 15, 2013 9:14 am
Quoting Klaus (Reply 7):
Sounds it, but it's actually really effective, even for an untrained chump like me. An Australian 20 cent piece is about right.
This repair won't be in any manual - it'll have to be designed. I can't see how they'll be able to get away with anything other than cutting out a fairly large section and splicing in a new one. It will be very intersting to see how much gets replaced and how the section is manufactured.
bikerthai
Mon Jul 15, 2013 2:22 pm
Yes, except the thermal insulation blanket in that area does impact how much heat damaged is spread. (That is if the blanket didn't catch fire themselves  )
Quoting dynamicsguy (Reply 8):
Deja Vu . . . could have sworn I read this comment from you a couple of years ago when we were discussing composite repair
bt
Klaus
Mon Jul 15, 2013 3:58 pm
No disrespect intended or implied – I'm sure this works well.
But doesn't that test detect only actual delaminations and not merely weakened resin that just hasn't delaminated yet (but might still do so once stressed again)?
Would there be enough of a safety margin even in a highly critical part like a pressurized fuselage barrel to accept that possibility?
bikerthai
Mon Jul 15, 2013 6:59 pm
Quoting Klaus (Reply 10):
True. What they will probably have to do is take specimen along the area beyond the visible damage and do flex tensile test.
Good flex tensile test should tell you that the material have not experienced heat damage.
bt
Klaus
Mon Jul 15, 2013 7:57 pm
Quoting bikerthai (Reply 11):
Does that mean stressing it mechanically and then checking whether any delaminations have developed?
bikerthai
Tue Jul 16, 2013 6:49 pm
Quoting Klaus (Reply 12):
Nope. I believe they are checking for modulus. Changes in modulus will show that the composite is compromised even no decontamination occurs. This will specially be true for heat damage.
bt
Users browsing this forum: B6JFKH81, rg787 and 1 guest
