flyenthu
Landing/back Of Plane
Mon Jul 15, 2013 5:23 pm
Hi,
Just a question: Is the landing phase the most accident-prone phase in flight? If so, is the rear of an aeroplane, the least safe spot on a plane?
26point2
RE: Landing/back Of Plane
Mon Jul 15, 2013 6:54 pm
Anytime you are nearest the ground is the most "dangerous" part of your flight...landing would qualify.
Years ago there was a debate in the media about the "safest" place to sit and it was determined, then, that the back of the plane was safest. This was a typical media assumption made after a couple of accidents where most of the folks who walked away happened to be sitting near the back. AA in Little Rock might have been one of them? I don't recall but someone will remember.
roseflyer
Mon Jul 15, 2013 7:07 pm
Any true aviation expert will tell you that the safest part of the airplane is an aisle seat within 3 rows of an exit, or the emergency exit row itself.
The statistics showing front vs back, left vs right, center vs tail are all based on a sample size that isn't statistically significant since crashes are such a rare event and each one is different. The window seats that are 3/4 of the way back which provide a great view, tend to be the worst when it comes to an evacuation since those people are last off the plane.
[Edited 2013-07-15 12:08:37]
Tue Jul 16, 2013 1:50 am
Quoting flyenthu (Thread starter):
Take-off and landing tend to be the most accident-prone. Both are close to the ground so there's not a lot of room to maneuver if the fecal matter impacts the rotary air impeller. Both situations are high workload, especially landing.
On take-off you have high power settings, high weights and high fuel load.
On landing you have low power settings, wind influence, often visibility issues.
SlamClick once described taking off and landing as getting on or off a small boat from a pier. If you're on land or on the boat you are fine. It's the transition that is the tricky bit.
Quoting 26point2 (Reply 1):
These "facts" come up regularly in the media.
Quoting roseflyer (Reply 2):
flyenthu
Tue Jul 16, 2013 2:59 am
Thank you for your feedback. I think the Asiana Airlines accident is on my mind and hence my question.
I feel that because the rear of the plane is "most vulnerable" during the most crucial stages of flight- take off and landing, it makes the back of the plane the most unsafe area, in the rare event of an accident. Is this a wrong deduction?
Braniff747SP
Tue Jul 16, 2013 3:50 am
Quoting flyenthu (Reply 4):
Yes, as explained above--there are simply a plethora of factors at work when something happens, so it can't be determined which seat is 'safest'.
Not that it matters, considering that accidents are very rare.
The 747 will always be the TRUE queen of the skies!
Tue Jul 16, 2013 4:01 am
As Braniff747SP says, it is indeed the wrong deduction. All accidents are different. Think of a high speed overrun into an obstacle. Would you rather sit in the front of the rear? What about a fire in a hydraulic system in the wing box?
The aft section may seem more vulnerable because of tailstrike risk on rotation and flare, but tailstrikes hardly ever result in injuries or fatalities.
In order to get the Asiana situation, you have to stall the plane very close to the ground. This does not happen often with airliners.
Expanding on the discussion, if passengers want to minimize risk of injury in a plane, they should expand their views beyond "big accidents". Encounters with severe turbulence are much more common than a crash, with passengers and crew often incurring injury from crashing into things or heavy objects flying around.
roseflyer
Tue Jul 16, 2013 4:05 am
Yes it is a wrong deduction. You never know which end hits first. The first class cabin on united 232 in Sioux city was the deadliest section. You never know, so pick a seat by the exit.
vikkyvik
Wed Jul 17, 2013 4:05 pm
Quoting Starlionblue (Reply 3):
In one of my first aerospace engineering classes, the professor told us (approx), "Airplanes like to be in the air; that's what they're designed for. Landing and takeoff are simply necessities."
Well, why do you think they are "most vulnerable"?
SAAFNAV
Wed Jul 17, 2013 4:44 pm
Quoting vikkyvik (Reply 8):
Good question. The nose normally arrives at the scene of the accident first.
I guess the wing box area will alway be my first choice. Closest to the exits, and structurally on of the stronger parts.
Erich
RussianJet
Wed Jul 17, 2013 4:59 pm
Quoting SAAFNAV (Reply 9):
Is there potentially a greater risk of fire in that location though?
✈ Every strike of the hammer is a blow against the enemy. ✈
e38
Fri Jul 19, 2013 5:42 pm
Quoting flyenthu (reply 4), I feel that because the rear of the plane is "most vulnerable" during the most crucial stages of flight- take off and landing, it makes the back of the plane the most unsafe area, in the rare event of an accident. Is this a wrong deduction?"
I'm not sure why you think the rear of the airplane is the most vulnerable during takeoff and landing. If you are thinking about tailstrikes, those are very rare.
Your question, "Is this a wrong deduction," well, yes, sort of, but every accident is different, so it all depends on the situation, i.e. fire, structural damage, etc.
In the past, conventional wisdom dictated that the rear was actually safer than the front of the aircraft because the energy the aircraft experienced during an abrupt stop (i.e. the airplane impacting something in front) would be absorbed from front to rear resulting in less "concussion" to people seated in the back.
However, if there is fire, depending on where it occurs, the rear may not be the safest part of the airplane. Years ago, when the left engine of a Delta MD-88 separated during the initial part of the takeoff roll, the casualties were in the rear, adjacent to the engine.
It all depends, but when I fly, I normally try to be seated toward the rear of the aircraft.
e38
Klaus
Fri Jul 19, 2013 11:34 pm
Quoting Starlionblue (Reply 6):
And in such a case you can influence your risk primarily by keeping your seat belt on at all times when you're in your seat and having it properly adjusted.
bristolflyer
Sat Jul 20, 2013 2:36 am
I always thought that but then I learned that the only significant injury in the BA 777 LHR short landing a few years back was someone who got severe leg injuries caused by the landing gear being pushed up into the cabin. Maybe this was a one-off, maybe not.
Fortune favours the brave
flyenthu
Sun Jul 21, 2013 8:28 am
Quoting Klaus (Reply 12):
Yes, I was hinting at tailstrikes. Thanks for all of your wonderful input! It has been very helpful.
I take QR 295 from CCU to DOH and then 77 from DOH to IAH tomorrow. I am very excited! My onward trip was alright. I'll post a trip report once I am back home.
plebbin
Sun Jul 21, 2013 1:17 pm
There are two parts to the answer of your question: 1) survivability upon impact and deceleration; and 2) survival after plane has come to a stop.
Most of the comments are addressed to the first part. Statistically speaking it doesn't matter much where you are seated for part 1.
For Part 2, it is entirely a different answer. There have been many accidents where passengers survived only to die in the subsequent fire and smoke in the cabin. From past incidents, NTSB has shown that your survival depends on how close you are seated to an exit. From a review of their reports, you will want to be within 4 rows of an exit and don't forget the exits in the very rear. People forget there are exits behind the back cabin wall and NTSB has shown that those exits don't get used very often.
WIth all of that said, incidents that have at least one fatality are extremely rare. In my mind, it really doesn't matter where you sit. But if it makes you feel better, sit close to a exit if you can.
26point2
Sun Jul 21, 2013 3:07 pm
Some mandated "safety" training years ago lodged a few memorable nuggets in my head about passenger post-crash survivability:
-Always have yours shoes on for take-off and landing. You will need them in case of evac.
-Leather clothing is very fire resistant...blue jeans good too. Nylon stockings or anything synthetic can easily melt onto your skin.
-If you can't sit in an exit row count the number of seat-rows between you and the nearest exit ahead and behind. Easier to find the exit by "feel" if needed.
-Compact personal smoke hoods are available. Not sure how the TSA looks at it but thinking it would get a pass.
-Move away from the wreck toward the nose of the plane if possible (or upwind) and in plain sight.
That's what I recall. I must say this training was many years ago but still seems relevant.
e38
Thu Jul 25, 2013 9:47 pm
Quoting 26point2 (Reply 16, "Always have yours shoes on for take-off and landing. You will need them in case of evac."
I strongly agree with this, and we are not talking about "flip flops" or "sandals" that you slip on. While these may be very comfortable, they can easily come off during an abrupt abort or evacuation.
When we say keep your shoes on, we mean regular shoes that you tie or slip on (like an oxford or loafer or other type of casual shoe) or if you must wear sandals or slippers, at least wear ones that have some kind of a strap that will help keep them on your feet.
e38
Sun Jul 28, 2013 9:18 am
The landing phase is the most critical phase of flight.....undoubtly........
The rear of the cabin is the safest spot on an airliner but depends also on the type of accident/incident involved.
The ELT/CVR/FDR is located around here too.
Users browsing this forum: CrackInspector, Horstroad and 2 guests
