hstrasbe
ERJ-135/145 Cabin Pressure
Mon Jul 29, 2013 6:41 pm
How is the cabin pressure on the ERJ-135 and ERJ-145? My ears have a hard time with the CRJ. They seem to be better on the ERJ-170, but I have never tried the ERJ-135 or ERJ-145. Would the pressure on the ERJ-135/145 be expected to be better, worse or the same as the CRJ?
AA737-823
RE: ERJ-135/145 Cabin Pressure
Tue Jul 30, 2013 7:36 am
Air pressure is air pressure. The "pressure" itself is whatever it is.
The difference between aircraft is in how gently the controller adjusts the rate of climb or descent.
I've always found the 737 to be more gentle on my ears than the CRJ or the ERJ. And I've further found the 757 to be more gentle than the 737.
DashTrash
Tue Jul 30, 2013 12:55 pm
I'm pretty sure I know what you're asking, and I think you'll find the ERJ better than the CRJ. Anything with CF-34s messes with my ears a little as well.
kenanc
Sun Aug 25, 2013 6:19 am
I can see what you are saying. I have no issues flying on a E190 but on E145s I have issues hearing for half an hour after the flight.
Acey559
Thu Sep 12, 2013 9:05 pm
Not sure if this will help any at all but max cabin pressure differential on the -135/-145 is 7.8psi with a max cabin altitude of 8,000 feet. Of course if you're on a shorter flight you'll be at a lower altitude so the cabin will be lower and so will the pressure differential. I guess I've gotten used to the pressurization because it doesn't bother me much if at all anymore. It also depends on how aggressive the pilots are in their descents. I like to keep mine shallow because it's more comfortable but that's not always possible. I can't speak for the -175s or the CRJ series but I hope that helps a little bit.
pilotpip
Sat Sep 14, 2013 4:10 am
Same on the 170/190. 7.8psi to 37,000ft then 8.34psi to 41,000 to maintain an 8,000ft cabin. The system is a little more automated on the ejet but I don't know if it makes a difference. Can't really point to the engines either because they areCF-34 variants that are close to the cr7 and 9.
DMI
Woodreau
Sun Sep 15, 2013 2:29 pm
Quoting hstrasbe (Thread starter):
During which phase of flight are your ears having a problem with the CRJ? In the climb or descent?
I've noticed problems with ear discomfort in the cabin descent on a CRJ, but none on an EMB-135/145.
On the Canadair, after takeoff the pressurization controller is supposed to maintain departure field pressure until 10 minutes after takeoff, to allow for returns to field, but in practice, the controller pressurizes the cabin aggressively for landing field elevation when the thrust levers pulled back from TO detent to the CLB detent. It's not a problem when the landing field elevation is higher than takeoff elevation, the cabin remains at departure field elevation. But if the landing elevation is lower than takeoff, the cabin starts pressurizing toward the lower field elevation immediately. As the climb continues, the cabin rate reverses and climbs to where it needs to be for cruise.
I've noticed the transition from takeoff power to climb power as the hardest part of the pressurization schedule in terms of discomfort in the ears. So when the landing elevation is less than departure elevation, I don't set the landing elevation in the pressurization controller until the aircraft has reached cruise altitude to preclude the cabin from descending to landing field elevation after takeoff. (Of course it does suck if you forget to set the landing elevation before descent, especially when the aircraft catches the cabin in the descent.)
During descent, the cabin pressure descent rate seems to descend at a constant rate unaffected by the actual aircraft descent rate, whether the aircraft is descending at 1000ft/min or descending at 7500ft/min.
On an EMB-135/145, I haven't noticed the same problems with ear discomfort in any phase of flight, that I have on a CRJ when the cabin is descending.
[Edited 2013-09-15 07:31:29]
Users browsing this forum: CWizard and 17 guests
