Gonzalo
AF A320 Near To A Stall On Approach?
Wed Aug 14, 2013 1:28 pm
I found this ( serious ) incident very intriguing.
From the article linked below :
" On approach to Bordeaux's runway 29 at 3000 feet the aircraft encountered hail causing the first officer's windshield to crack. The aircraft continued the approach, while descending through 2800 feet ( on autopilot ) the aircraft pitched up to 25 degrees nose up and alpha floor protection and TOGA LOCK activated "
http://avherald.com/h?article=466b79cf&opt=0
Questions :
Wasn't a bad idea trying to land there and not divert ?
Why the pitch up attitude ?? Obstructed pitot ?
Thoughts ?
Rgds.
G.
[Edited 2013-08-14 06:48:30]
Gear Up!!: DC-3 / EMB-110 / Fairchild-227 / Ab318-19-20-21 / B732 / B763 / B789
KC135Hydraulics
RE: AF A320 Near To A Stall On Approach?
Wed Aug 14, 2013 1:33 pm
Maybe the pitot tubes got clogged with ice and there was a subsequent malfunction is some air data computer?
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
KarelXWB
Crew
Wed Aug 14, 2013 1:35 pm
Quoting Gonzalo (Thread starter):
If the speed drops, the nose must go up to increase the lift.
Gonzalo
Wed Aug 14, 2013 2:10 pm
Quoting KarelXWB (Reply 2):
Well, yes, I know, but I don't see any reference to a "meaningful" or sudden loss of speed in the article... A change from a descent attitude to a 25 degrees nose up attitude needs two things, a really important loss of speed, and a crew not paying attention to that loss of speed in a timely manner ( in other words, before the Alpha Floor protection do something ).
Rgds.
G.
KarelXWB
Crew
Wed Aug 14, 2013 2:13 pm
That's another A320, here is the correct link: http://avherald.com/h?article=466d11a4&opt=0
DTWPurserBoy
Wed Aug 14, 2013 9:13 pm
If the speed drops, the nose goes DOWN to increase speed and increase airflow over the wings providing lift. If it goes up it will stall.
Qualified on Concorde/B707/B720/B727/B737/B747/B757/B767/B777/DC-8/DC-9/DC-10/A319/A320/A330/MD-88-90
KarelXWB
Crew
Wed Aug 14, 2013 9:19 pm
Quoting DTWPurserBoy (Reply 5):
Only if you can increase the speed again or when you have enough altitude. On flight 1549 (the A320 in the Hudson river), the FBW was gradually increasing the pitch to maintain lift.
[Edited 2013-08-14 14:20:55]
earlynff
Wed Aug 14, 2013 10:12 pm
so, the pilots disregarded a big red/magenta spot on their radar
Quoting KC135Hydraulics (Reply 1):
rather unlikely
Quoting Gonzalo (Reply 3):
once you fly through a cell of heavy precipitation (obviously), you´ll have a nice headwind component turning into a tailwind condition within seconds, augmented by additional downdraft in the centre of that cell. In that case you see the speed drop like a stone...
google for "microburst" and related accidents!
[Edited 2013-08-14 15:19:32]
Thu Aug 15, 2013 12:32 am
Could have been other damage such as a radome which prevented the AoA vanes from getting clean airflow.
Quoting earlynff (Reply 7):
Frozen material is not a good reflector of Wx radar.
airproxx
Thu Aug 15, 2013 12:53 am
You have radars that see hail?? Wow this is something!
If you can meet with triumph and disaster, and treat those two impostors just the same
barney captain
Thu Aug 15, 2013 1:47 am
Quoting airproxx (Reply 9):
While hail is a poor reflector of radar, the associated TRW was directly over the field at the time. The TRW would have certainly been visible on radar.
LFBD 021830Z AUTO 29012KT 2400 +TSRA BR BKN046/// BKN066/// BKN096/// //////CB 23/18 Q1014=
"....TOGA LOCK activated at 20:45L (18:45Z)"
Note the times.
Southeast Of Disorder
roseflyer
Thu Aug 15, 2013 1:54 am
It sounds like a possible micro burst. Glad they had enough altitude to recover safely. Enough haul to crack a windshield is going to be associated with some nasty weather. The 25 degree pitch up could be associated with the rapid drop in airspeed associated with exiting a microburst.
flymia
Thu Aug 15, 2013 3:17 am
I am a bit confused. What's with the speed drops nose up theory? If you are closing in on stall speed isn't nose down?? Haven't we had three crashes in recent years with pilots pulling up instead of down in stalls? OZ 214, AF 447 and Colgan 3407.
Someone mind if they can clear this up for me.
Thu Aug 15, 2013 8:48 am
Quoting barney captain (Reply 10):
Metars are for conditions within 5nm of the reference point, I often fly into airports with metars like that and never get wet. It means nothing in isolation.
Quoting roseflyer (Reply 11):
Could be many reasons, including following the correct windshear recovery technique which can result in even higher pitch attitudes and TOGA lock.
Thu Aug 15, 2013 9:01 am
Quoting flymia (Reply 12):
If the speed drops, the angle of attack must increase to maintain altitude. Of course you don't want to go too far to a stall but since the aircraft didn't stall...
Sure, but this assumes that the aircraft was heading for a stall. We don't know if the aircraft was approaching a stall or not. All we seems to know is that it was heading for hail and pitched up.
If you are trying to get out of windshear you want maximum lift, which is achieved at an angle of attack just short of the stalling AoA.
On windshear warning, the recovery procedure is something like this.
- TOGA power.
- Do NOT change configuration.
- Pitch up to Clmax or thereabouts for maximum lift. Max lift is right before stall. In the case of Boeing, this means pitch to stick shaker and in the case of Airbus FBW hold the stick back and let the system worry about Clmax.
The point is to climb as much as possible since if you go through a microburst you'll go from lots of headwind to downdraft to lots of tailwind in a hurry.
3rdGen
Thu Aug 15, 2013 4:22 pm
Its a bit early to start debating what happened. Firstly we don't know why the aircraft pitched up 25 degrees, i.e. was it weather related or due to malfunction. The other thing you must remember that Alpha floor is a function of angle of attack not of speed so if there was a large pitch up moment and a significant increase in load factor and AofA then with the speed already very low there's a good chance of A Floor Activation, aircraft may not actually have been in a sustained stall.
لا اله الا الله محمد رسول الله
flymia
Thu Aug 15, 2013 5:44 pm
Quoting Starlionblue (Reply 14):
Got, not getting to stall speed, yea that makes sense.
Thanks for the info!
XFSUgimpLB41X
Fri Aug 16, 2013 2:30 am
Quoting zeke (Reply 13):
Considering the aircraft got hail damage, they obviously got a bit wet. Pretty safe to say the metar and what they experienced are related....
Chicks dig winglets.
Fri Aug 16, 2013 3:59 am
Quoting XFSUgimpLB41X (Reply 17):
Not obvious at all, I have been in hail before and not in rain.
XFSUgimpLB41X
Fri Aug 16, 2013 4:47 am
Quoting zeke (Reply 18):
You're being obtuse at best. Perhaps some more practice flying 180 to 5 miles is in order?
Fri Aug 16, 2013 7:12 am
Quoting XFSUgimpLB41X (Reply 19):
Not at all, the contents of a metar do not reflect what an aircraft will see on the final approach path (around 0.2 sq nm in area). The metar relates to conditions within 5 nm of the reference point (around 80 square nm), and it is possible not to go into rain or hail while the metar has a TS on it. I have done it twice in the past week, even flew through a typhoon this week without getting wet on final.
We dont fly 180/5, we leave that up to those heros in the US who "never" have accidents or incidents with the worlds best ATC, and best RT standards.
Fri Aug 16, 2013 7:39 am
Quoting zeke (Reply 20):
Could someone please explain the 180 to 5 miles expression?
Fri Aug 16, 2013 8:04 am
Quoting Starlionblue (Reply 21):
Maintain 180 kts indicated to 5 nm from landing, 160 to 4 is more common and a lot safer.
Kinetic energy is 0.5*m*v^2, an extra 20 kts is only an extra 12% in speed (above 160), however around an extra 27% in kinetic energy. 180 kts is above or at the maximum flap speed for most jet aircraft.
[Edited 2013-08-16 01:05:17]
Fri Aug 16, 2013 10:30 am
Quoting zeke (Reply 22):
Mir
Fri Aug 16, 2013 5:12 pm
In the US, ATC will often ask pilots to maintain 180kts until a 5 mile final. This requires a technique where you don't extend the flaps for landing until past the 5 mile point (due to flap extension speeds). And that runs up against certain foreign carriers' SOPs which require the aircraft to be fully configured for landing earlier than that.
-Mir
XFSUgimpLB41X
Sat Aug 17, 2013 4:49 am
Still being obtuse. It's quite obvious the two are related in this situation.
Just giving you crap from all the yelling you did on the Asiana thread.   Widebody airliners can do 210 to 5 miles no problem and meet stabilization requirements for us no problem (given no tailwind)!
In the CRJ 200, that thing was such a brick that you could do 250 until 5 miles!
[Edited 2013-08-16 21:50:40]
glen
Sat Aug 17, 2013 6:24 am
- TOGA power.
Setting TOGA-Thrust and maintaining the configuration is correct. But then - at least on the Airbus - you follow the Flight Director Pitch Commands which should guide you through the windshear. The windshear recovery guidance tries initially to keep the speed with a positive rate of climb. If this is not possible it keeps altitude and lets speed decrease, down to αmax (corresponding to Clmax) if necessary.
So you may end up at αmax with the side stick fully back, but you don't want to go straight there - it is safer to have as much speed as possible as long as possible in a windshear situation.
(Different thing is terrain recovery, where climbing is the most important thing. In this case you would pull and hold the stick fully back from the beginning of the recovery.)
"The horizon of many people is a circle with zero radius which they call their point of view." - Albert Einstein
Sat Aug 17, 2013 6:53 am
Quoting glen (Reply 26):
Thanks for clarifying!
Sat Aug 17, 2013 7:01 am
Quoting XFSUgimpLB41X (Reply 25):
Not at all, how many winshear go-arounds do you do a year ? I would do at lest one, and every time it is due to mechanical turbulence of wind interacting with terrain. We had up to 65 kts of crosswind last week with the passing typhoon, and had numerous windshear go-arounds. The metars had +TSRA on them as well, it was however not TS related, it was the wind coming over the terrain.
Just goes to show your inexperience to suggest it HAS to be related.
Hero plots in the US can, for a lot of airlines the stabilisation criteria is 1500', which is 5 nm, 210 is not stable, nor is 180.
Tell me what airlines are flying with 70% more energy at 5nm, and how can they possibly be stable ?
XFSUgimpLB41X
Sat Aug 17, 2013 7:09 am
Correct! Our prescribed response is TOGA power, 15 degrees nose up, and then follow the guidance.
I experienced the real deal for the first time (and hopefully only time) back in June at about 800 AGL. It was amazing how similar it was to the simulator. I did end up in alpha floor at the end of the escape, and of course the recovery from the recovery is about as much of a challenge as flying the windshear escape in itself.
XFSUgimpLB41X
Sat Aug 17, 2013 7:20 am
Quoting zeke (Reply 28):
Considering hail damage and subsequent windshear, are you really that hard headed to not notice the linking?
Your airline's stabilization is 1500... neat. That's 5 miles out and quite early. At lower volume airports that works. I operate out of the busiest airport in the world typically. 180 to 5 is perfectly safe, day in and out. I typically find myself drumming my fingers to throw out the gear and the rest of the flaps after doing 180 to 5 even to be fully configured and spooled at 1000 agl. If you hit the marker at 210, you'll have to use the speedbrake probably, but it's not difficult. If I'm doing 180 to 5 and immediately dial the speed back and configure, I'll be configured and spooled by 1200. Ideally in visual conditions, I prefer to be more efficient and get configured right at 1000 and meet spooling at around 800 (min in visual is 500 for us). Nothing heroic about it...the airplanes are designed to do it, and anyone with a clue on energy management can do it half asleep.
Sat Aug 17, 2013 8:39 am
Quoting XFSUgimpLB41X (Reply 30):
Zeke's home airport is HKG. It is the 12th busiest in the world for pax and the busiest in the world for cargo. Not really low volume...
Sat Aug 17, 2013 11:22 am
As I said earlier, it goes to show your inexperience if you say they HAVE rather than COULD be linked.
I have operated into over half of the top 30 busiest international airports in the world in the past year, my home airport HKG is the 3rd busiest international airport behind DXB and LHR. 160 to 4 is normal at these airports. They are the highest volume wide body airports.
Your profile says you are an A320 FO, that is not a wide body (my last landing weight into HKG was 189.8 t, over double the MTOW of the A320), like to know who operates wide bodies 210 to 5 nm and what weights they are doing that at.
How many accidents and incidents have there been in the landing phase in the US this year ? Why is it not happening at the other busy international airports ?
Quoting Starlionblue (Reply 31):
HKG is the 3rd busiest for international passengers, and the busiest for international freight.
http://www.aci.aero/Data-Centre/Mont...ational-Passenger-Rankings/Monthly
http://www.aci.aero/Data-Centre/Mont...ernational-Freight-Traffic/Monthly
XFSUgimpLB41X
Sun Aug 18, 2013 1:43 am
If ~9000 hours is inexperienced, so be it. Most if my time at my current carrier was in the 767 fleet, which of course included flying the 757. I bid to the 320 for better schedule control with a new addition to my family.
I've done 210 to the marker on the 767 to 5 miles at 295,000 lbs (max landing). Get the gear out and configure on speed... no big deal. I wouldn't attempt it with a tailwind. Like I've said before, your understanding of energy management in higher energy situations is a bit concerning.
As far as accidents in the US- One of those was an asian carrier with a tradition of safety issues and automation overdependence, the other was the one that has a wonderful tradition of get-r-done. It's starting to appear that UPS just let the autopilot fly the plane into the ground. They were configured and on speed. We've had a major push at my carrier to guard against automation dependence this year.
The WN LGA hit was the only one that is positively identifiable as a high energy situation where they did not meet stabilization requirements. WN is less familiar with LGA ops, and the runway 4 is one where you have to manage your speed and energy appropriately. Of all the approaches I've done into LGA in everything from the CRJ to the 767 (yes we fly the 767 into there from time to time- one of the pictures of it at LGA taken a few years ago is me flying it!), that approach with a tailwind is by far the greatest threat to meeting stabilization requirements. Asiana had a 17 mile final and still royally messed it up. No excuses there.
[Edited 2013-08-17 18:57:35]
TheRedBaron
Mon Sep 02, 2013 12:16 am
Great that I read this thread. I flew on US airways 3 weeks ago from MEX to PHX a morning flight.
The approach was a little bit bumpy with scatered clouds all over the place and an overcast layer at around 7000 feet.... the A320 made a turn to align with the runway and they dropped the slats and flaps just a little ( guess position 1), and then after a few seconds the gear came down making a LOT of noise, we were overflying PHX and getting at 1500 to 2000 feet and I became very alarmed to see the flaps still on position 1, our speed quite high, then no more than 40 seconds till touchdown, I saw them bring the flaps to position 2, and we landed like that....super fast...
I wish I had made a video of the landing.... weird landing...
TRB
The best seat in a Plane is the Jumpseat.
Pihero
Mon Sep 02, 2013 11:16 am
Quoting TheRedBaron (Reply 34):
- On an approach, when you select *FLAPS 1*, only the slats will extend --> the configuration was therefore *FLAPS 2*
- A further extension then was for *FLAPS 3*, which is a possible landing configuration.
...and btw, flaps 3 at 150 kt gives a rate of descent of 750 ft / min, of which 40 seconds before landing equate to a height of 500 ft... which is the almost universally adopted stabilisation height on a visual approach.
[Edited 2013-09-02 04:22:03]
Contrail designer
flylku
Mon Sep 02, 2013 12:39 pm
Now that is hilarious! I've also heard it called a lawn dart because of the nose down pitch during approach.
...are we there yet?
TheRedBaron
Tue Sep 03, 2013 12:08 am
Quoting Pihero (Reply 35):
Thanks ! I guess we were at that height, I was really alarmed, because I am very acustomed to approaches where you can see the changes in configuration and a low landing speed, this time it was Fast and with a rate of decent to match, maybe USAir like to save fuel retaining some kinetic energy.... but it was weird, BTW the landing was very smooth and the one in SEA was a greaser... !!!
TRB
Wed Sep 04, 2013 1:28 am
Quoting XFSUgimpLB41X (Reply 33):
Just goes to show hours in a logbook does not equate to experience.
295klb is a light aircraft for me, I am flying that plus the weight of a full A320 with a much cleaner aircraft than a 767, our descent profiles are 4:1, the 767 is 3:1.
What you are describing is not even in accordance with the manufacturers procedures (the Boeing low-drag, delayed-flaps procedure). Our SOPs are conservative, what you are describing if it is a company SOP is not conservative in relation to what the manufacturer publishes. If you were to have an accident, you could be personally exposed for negligence and/or criminal charges.
That Asian carrier after a recent ICAO audit was found to be safer than most airlines in the US, I am not aware of any airline in the US achieving a higher safety rating.
Quoting flylku (Reply 36):
I was actually thinking dangerous and stupid.
XFSUgimpLB41X
Wed Sep 04, 2013 3:35 am
If you saw the flaps come out, then that was flaps going to Flaps 2. The gear is typically deployed and Flaps 3 is selected, which is the second movement of the flaps you saw. Normal USair landing config is Flaps 3, so what you saw was normal!
The gear can be deployed at up to 250 knots for extra drag in high energy situations and comes quite in handy as the airbus is very clean and has relatively low flaps extension speeds.
XFSUgimpLB41X
Wed Sep 04, 2013 3:49 am
Quoting zeke (Reply 38):
It's still a widebody, very clean and proved your point wrong. Only airports like JFK that do very wide patterns was I ever able to get away without using speedbrakes on every approach. We utilize FMS idle path on descent and don't reference charts. The path is highly variable as we run tactical cost indexes. It can swing from 2.5:1 at a high cost index to 4:1 at 0.
We are allowed to configure the aircraft as need be to be as efficient as possible while hitting the stabilization criteria. We utilize modified Boeing procedures, so....well.. wrong again.
They also were flying two hands on the wheel and completely ignorant to the fact that their engines weren't spooling... Not a carrier I want my family on.
Your opinion. We used to have high flaps speeds on the CRJ, and the flaps produced a lot of drag. Deploy the landing gear and speed brake, then flaps on speed, you'd make configuration right a 1000 feet and be on speed and spooled by 600. It was a bit abrupt, but was a good tool to have in your back pocket. With the lowered flaps speeds on an AD a few years later, that was no longer possible.
Wed Sep 04, 2013 6:44 am
Quoting XFSUgimpLB41X (Reply 40):
767-200 "very clean", I guess that is why they are still selling so well ....
Tactical and cost index in the same sentence......OMG.
Where has the manufacturer has published this ? You are talking about flying the glideslope at 210 kts until 5 nm, that is the MAXIMUM flap extension speed for flap 20. The maximum speed for CAT D aircraft on final approach is 130 - 185 kts (PAN-OPS), hence the reason 180 to 4 is the international "norm", the 767 is either CAT C or CAT D depending on the model. TERPS is around 140 CAT C and 165 CAT D ?
What I have seen published by Boeing for the 767 for the low drag delayed flap approach states to intercept the glide slope with gear down and flaps 20 at flaps 20 (FCTM 5.17).
From the same page in the 767 FCTM it says the aircraft should meet stabilised approach criteria IF on a glideslope EVEN in VMC conditions by 1000' AFE.
Your opinion.
Did the manufacturer publish this procedure ?
What is the maximum final approach speed for that category of aircraft ?
What protection did you have from the designed procedure at that speed ?
What rate of descent is the procedure based upon ? What rate of descent are you doing at 250 kts ?
XFSUgimpLB41X
Wed Sep 04, 2013 6:29 pm
Quoting zeke (Reply 41):
Never flew the 767-200. Only the 300 and 300ER. The 200s were parked before my time.
Go on? We do variable cost index during the flight depending on a number of factors.
That's nice. We have relief from that to delay being on airspeed and engines spooled until 500. We have a very close relationship with Boeing, FWIW. Works great, lasts long time.
I've never seen the bombardier books, only our Fed approved ones. It was simply pull the power to idle, put the gear out, open the speed brakes, and as you reached the flap limit speeds, deploy the flaps. A slight level off was needed at the marker putting you slightly high for a moment, but you'd be right back on the slope by 1000. The CRJ is THAT draggy.
mandala499
Thu Sep 05, 2013 7:59 am
Airbus FBW 101 training.... from the very beginning pilots moving to the Bus FBW get told that the aircraft on pitch maintains longitudinal trajectory. So no stick inputs, reduce speed and pitch goes up, increase speed pitch and goes down... as the aircraft maintains 1G longitudinal trajectory...
Users browsing this forum: Grizzly410, mat66, txjim and 1 guest
