UA787DEN
LCY Aircraft Restrictions: Interesting Info
Thu Aug 15, 2013 9:59 pm
Hi All,
Today I was learning more about ops at LCY. For those who don't know: only multi-engined, fixed-wing aircraft can operate into LCY, and must be of an approved type. The list of approved types may be found here:
http://www.londoncityairport.com/con...0of%20Aircraft_and_Concessions.pdf
I found a few things interesting:
1) The 318 is approved, but not the 736. European airport laughing at Boeing, the airlines operating (AFAIK the BA Limited 318 service is the only 318 flight), or noise/performance issues?
2) While a wide variety of Dassualt and Cessna jets are approved, the only Gulfstream approved is the G150. Is this simply because Gulfstream doesn't think the hassle to approve the rest is necessary? I would assume many a Gulfstream owner would like to fly into LCY vs, say LGW. The E190s are approved, and most Gulfstreams can takeoff in a shorter space than a 190, correct?
3) Only the ERJ135 is approved, not the 140/145, and the CR7 isn't either.
Thoughts?
Polot
RE: LCY Aircraft Restrictions: Interesting Info
Thu Aug 15, 2013 10:02 pm
Quoting UA787DEN (Thread starter):
Nobody has wanted to fly the 736 to LCY so it has never been certified for it, although I don't know if it has the performance for it. Nothing to do with European airports laughing at Boeing.
UA787DEN
Thu Aug 15, 2013 10:08 pm
Quoting Polot (Reply 1):
I assumed as much. Any idea what the T/O roll for a 318 vs a 736 is?
Horstroad
Thu Aug 15, 2013 11:36 pm
Quoting UA787DEN (Reply 2):
I don't think it's the the runway length, that is the problem. LCY has a G/S of 5.5° (used to be 7.5°) for noise abatement reasons. the A318 is certified for steep approaches, the 736 probably not (I assume)
roseflyer
Thu Aug 15, 2013 11:55 pm
A G550 can land and takeoff on a runway that short. I assume it can handle the glideslope. One of the problems is where to park it. The business jet ramp is small and the G550 has the same wingspan as an Embraer 190, so it would take up one of the airline gates. It might not be worth it to get the airplane certified.
UA787DEN
Fri Aug 16, 2013 4:46 am
It all seems to come down to the fact there isn't a point to certify these a/c. The gulfstreams might have to take an airline gate. Good point.
And though the 736 might be able to handle the glideslope and noise it just isn't worth attempting.
If the CR7 was approved would LH Cityliner (sorry forgot their code) or someone else fly it in?
Mir
Sat Aug 17, 2013 6:10 am
Can't make the glideslope. The 318 has to use special software connected to the flight spoilers in order to do the approach. The 736, being non-FBW, doesn't have that option.
It's not about the runway, it's about the steep approach. And there are a lot of types that just can't do it.
Quoting roseflyer (Reply 4):
No, it can't. One of the downsides of a very low-drag wing is that it's tough to get it to descend fast enough on a steep glideslope without speed increasing. You could design it to, but then you'd have to build in larger (and thus heavier) flaps and perhaps leading edge devices, which adds weight and complexity. Apparently there's not the need.
-Mir
musang
Sat Aug 17, 2013 8:26 am
The glideslope is a major issue. I used to operate Avro RJ 100s there and if you weren't in the landing config before starting down the 5.5 degree slope, there was little hope of slowing it down subsequently. The required mod was a Steep Glideslope switch, which de-sensitised the GPWS system to accomodate the greater closure rate. This could only be selected before glideslope capture. I also flew Do228s there after the glideslope was adjusted to 5.5. I heard that to get one down the original 7.5 degree slope, the engine bleeds had to be switched on to slow the engines down a bit!
Regards - musang
rfields5421
Sat Aug 17, 2013 1:39 pm
For a corporate type jet - LCY is a poor choice - costs are extremely high and they really don't want that corporate jet to stay on the ramp for very long.
Biggin Hill EGKB / BQH is a much better choice for smaller jets, and Stansted for larger jets.
SA7700
Sun Aug 18, 2013 8:29 am
Quoting UA787DEN (Reply 5):
Lufthansa CityLine's IATA code = CL
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
kenanc
Sun Aug 25, 2013 6:14 am
I have a feeling it is noise abatement for nearby residential areas. SNA in CA has similar restrictions (just not as tough) but it could also just simply (as said above) airlines have not been interested in flying it there.
RussianJet
Sun Aug 25, 2013 5:24 pm
I assumed as much
I do have to wonder why you even considered it remotely likely that the reason would be a 'European airport laughing at Boeing'. I appreciate your clarification that it seemed unlikely, but to even mention it seems a bit strange to be honest. It really wouldn't be in the airport's interests to thumb their nose at customers wanting to fly a particular type in if it could be certified to do so in the prevailing operating conditions, As far as I know, airports are not in the habit of arbitrarily banning certain manufacturers from their fields purely for political fun. Or, am I wrong? Have there been such examples?
Quoting musang (Reply 7):
That was a really enlightening post. Really put the operational difficulties of LCY into context. Properly challenging stuff.
✈ Every strike of the hammer is a blow against the enemy. ✈
Viscount724
Sun Aug 25, 2013 10:28 pm
Quoting RussianJet (Reply 11):
The Indian government ban on A380 operations to/from India is a good example of that.
http://www.traveldailynews.asia/news...cle/51888/ban-on-airbus-a380-deter
RussianJet
Sun Aug 25, 2013 11:31 pm
Quoting Viscount724 (Reply 12):
Thanks for that. How about in the 'western' or 'developed' world though? The EU or US, for example? Has this happened?
Viscount724
Mon Aug 26, 2013 12:42 am
Quoting RussianJet (Reply 13):
Concorde was banned from the U.S. for quite a while before BA/AF finally received permission to start service. That's why BA initially introduced service to SIN via BAH. If memory correct the U.S. ban was officially for noise-related reasons, but I expect politics were also involved since no U.S. carriers had plans to operate the type.
PlymSpotter
Mon Aug 26, 2013 12:53 am
IIRC the 736 was looked at, but it could not economically be modified to fly the steep glideslope.
The small number of business aircraft is for a mixture of reasons; the steep approach, lack of slots, noise limits and lack of parking. But for business aircraft LCY is not as popular as people think, you are required to have two captains both trained on steep approaches, for most business jet and even private operators that is not really practical.
The early jungle jets have dire runway performance, even the 135 is not ideally suited to LCY and on a hot day the 145 wouldn't lift itself off the deck even when empty.
Dan
Okie
Mon Aug 26, 2013 1:05 am
Quoting Viscount724 (Reply 14):
Concorde started service Jan 76 on routing mentioned.
Concorde started service to Dulles May 76, so no politics were involved, the flights were welcomed.
Concorde started service to JFK Nov 77 after noise complaint suit (filed locally) was over turned easily on the grounds that the POTUS aircraft VC-137 was louder than the Concorde.
So, it was held up for about 1.5 yrs. over noise at JFK but not by the government or political efforts just NIMBY's
Okie
rfields5421
Mon Aug 26, 2013 1:55 am
The Concorde came into service soon after the Vietnam Anti-War movement turned into the start of the Enviornmental movement.
Sonic booms were associated with military testing back in the 60s. Any super-sonic aircraft was environmentally 'dangerous' and super-sonic flight over land was 'unhealthy' for people under the flight path.
If the Concorde had been operational five years earlier - it likely would have serviced ATL, ORD, LAX or SFO and possibly DEN and/or DFW. Timing is everything for revolutionary aircraft.
The Concorde would have been allowed to serve those airports - but having to fly under the speed of sound across the United States make serving any but a couple key east coast airports impossible in the US.
Yes, the restrictions were political - but not because the aircraft was 'foreign' or operated by non-US airlines. It was the politics of a growing environmental movement taking on the US government, airport operators and airlines (big business and therefore 'evil') and exerting political pressure at the most fundamental level - the local level.
[Edited 2013-08-25 18:57:54]
Mon Aug 26, 2013 6:14 am
http://www.traveldailynews.asia/news...deter
Didn't know about this one but it is classic Indian politics when dealing with foreign companies. Inconsistent and arbitrary rules make foreign investment much more difficult than it needs to be in many areas. The net effect is slower development. Protecting domestic companies in the short term while hurting domestic citizens in the long term.
But I digress...
LH707330
Mon Aug 26, 2013 4:29 pm
Quoting rfields5421 (Reply 17):
In cases like the Oklahoma CIty experiment, that sentiment was entirely warranted. What they thought they were thinking there is beyond me, we could have had SSTs if this sort of stuff were done more tactfully.
Devilfish
Mon Aug 26, 2013 5:50 pm
Given that the E170 is listed, it's possible that the E175E2 might also be approved (with restrictions).....
http://www.beholdthepowerof2.com/ejets/e175
However, published estimated short field performance specs and absent definite guidance from Embraer that they would qualify the E175E2 for the steep-approach requirement at LCY...its projected 2,240m TOFL is almost the same as the 2,244m figure for the current E175AR...much worse than the standard E170's 1,483m - and over LCY's 1,508m runway length.
Stitch
Mon Aug 26, 2013 10:37 pm
As noted, the temporary ban of Concorde operations at JFK was due to NIMBYs, not by the US Government due to the lack of US customers or lack of a US SST. If the Boeing 2707 or Lockheed L2000 had entered revenue service, the same NIMBY's would have sought to ban it's operations, as well. Of course, that same environmental movement that fought Concorde played a major role in killing the US SST program.
LH707330
Mon Aug 26, 2013 11:14 pm
Quoting Stitch (Reply 21):
Not to mention the huge cost overruns that they had with the 2707....
Viscount724
Mon Aug 26, 2013 11:53 pm
What was the position of U.S. competitors like Pan Am and TWA on approval of Concorde service to the U.S.? Did they come out in support of the delaying tactics? I can't remember. I expect they would have used whatever influence they had with the various levels of government and airports etc. to stall Concorde service as long as possible.
[Edited 2013-08-26 17:03:30]
Okie
Tue Aug 27, 2013 12:00 am
Quoting LH707330 (Reply 19):
Well being a survivor of Bongo II, I will say this from my perspective.
There were a few "cracked" panes of glass, not shattered. Largely had to deal with the way glass was mounted in windows from the 30's onward through the 60's which the glass was "glazed" into the frames and would have to be re-glazed every 4 or 5 years or the glass would rattle around in the frame. Glass is mounted with more permanent methods now.
It definitely smoked some kooks out of the woodwork with all sorts of allegations looking for settlements for all types of claims. There were some parents of a teenaged girl claimed that the cause of her becoming pregnant was because of the sonic booms, she definitely was not responsible. So there you go sonic booms cause unauthorized orgasms.
The plus side was that you could set your clock by the sonic booms as they came the same time every day. Quite handy with my Latin class as the teacher would talk way past class time if something did not interrupt her and you would be late to your next class. Sonic boom everyday at 1pm did the trick.
Now back to the thread.
I noticed that LCY has expansion plans clear out to 2030 so it will be interesting what aircraft will be certificated to handle that 5.5 slope in the future.
Okie
Tue Aug 27, 2013 6:30 am
Quoting Viscount724 (Reply 23):
Given that several US carriers, including Pan Am and TWA, ordered Concorde I think it is fair to say they were counting on approval.
Here's an orders list for Concorde and B2707 followed by chronological Concorde orders.
AIRLINE Concorde B2707
Aer Lingus - 2
Air Canada 4 6
Air France 8 6
Air India 2 2
Airlift Int. - 1
Alitalia - 6
American 6 6
BOAC 8 6
Braniff 3 2
Canadian Pac. - 3
Continental 3 3
Delta - 3
Eastern 6 6
El Al - 2
Iberia - 3
JAL 3 5
KLM - 6
Lufthansa 3 3
Middle East 2 -
Northwest - 6
Pakistan Int. - 2
Pan American 8 15
Qantas 4 6
Sabena 2 -
Trans-Am. - 1
TWA 6 12
United 6 6
World - 3
TOTALS 74 122
Concorde:
01apr1984 British Airways 1 (for spares use)
14apr1980 Air France 1 (c/n 13 previously on loan)
Oct 1972 Iran Air (2(+1)) (cancelled)
28jul1972 Air France 4
24jul1972 CAAC (2(+2))(cancelled)
25may1972 BOAC 5
May 1966 Qantas (4) (cancelled)
1966 Eastern (6) (cancelled)
1965 Air Canada (4) (cancelled)
1965 Air India (2) (cancelled)
1965 American (6) (cancelled)
1965 Braniff (3) (cancelled)
1965 Eastern (2) (cancelled)
1965 JAL (3) (cancelled)
1965 Lufthansa (3) (cancelled)
1965 MEA-Air Liban (2) (cancelled)
1965 Qantas (6) (2 options cancelled 5/66, last 4 later cancelled)
1965 Sabena (2) (cancelled)
1965 TWA (6) (cancelled)
1965 United (6) (cancelled)
16jan1964 American (4) (cancelled)
1964 Air France (2) (total 8)
1964 BOAC (8)
1964 Continental (3) (cancelled)
1964 TWA (4) (cancelled)
03jun1963 Air France (6)
03jun1963 BOAC (6)
03jun1963 Pan American (6) (2 more later optioned, 1 then all cancelled)
Stitch
Tue Aug 27, 2013 3:10 pm
Quoting LH707330 (Reply 22):
Costs were actually never a major issue with the program.The program had the full support of the Nixon Administration (the FAA had been fixated on a US SST since the 1950s) as well as major labor unions, who saw it as a massive jobs program. It was also seen as a matter of national pride, much like the Space Race had been.
What was the position of U.S. competitors like Pan Am and TWA on approval of Concorde service to the U.S.? I expect they would have used whatever influence they had with the various levels of government and airports etc. to stall Concorde service as long as possible.
As Starlionblue noted, they were both Concorde (and, I believe, 2707) customers. Yes, they cancelled their orders by the time the plane entered service with BA and AF, but that was because the operating economics were too poor. So if anything, you'd think both would want BA and AF to fly it because it was losing them money (at the time - I am aware BA (if not also AF) eventually operated them at a profit thanks to being able to set fares at whatever level they wanted).
And as the plane was allowed to operate at IAD and DFW (with Braniff), whatever influence they had certainly wasn't effective at stopping Concorde from serving the US.
LH707330
Tue Aug 27, 2013 5:02 pm
Quoting Stitch (Reply 26):
I stand corrected, looks like it was nimbys and congressional bickering based on a short Wikipedia read.
Tue Aug 27, 2013 5:17 pm
Overland routes were subsonic, making them massively inefficient and negating any advantage apart from coolness factor.
Stitch
Tue Aug 27, 2013 5:43 pm
Quoting Starlionblue (Reply 28):
True, but the objection to operations at JFK involved subsonic operation - take-off and landing.
To my knowledge very few countries allowed supersonic overflight of their territory (Iran, for example, during the time the Shah was ruling). India was expected to allow it and when they did not, I believe that crimped the plans for flights to Southeast Asia and Oceania.
Tue Aug 27, 2013 5:47 pm
Quoting Stitch (Reply 29):
Logical. Concorde was very loud subsonically as well unfortunately, especially on approach.
'tis a shame Concorde-B never got off the ground. It would have mitigated many of Concorde's weaknesses, including approach noise and noise overall. Couple that with much lower fuel consumption and bigger tanks...
http://www.concordesst.com/concordeb.html
Viscount724
Wed Aug 28, 2013 12:42 am
But Concorde also took a lot of premium passengers from PA/TW and other carriers' F class cabins. And losing money wasn't a problem for BA and AF then as they were government-owned and their governments didn't seem to mind pumping in additional funds when they ran short.
Stitch
Wed Aug 28, 2013 2:30 am
Quoting Viscount724 (Reply 31):
Well it evidently didn't hurt them too bad, since both PA and TW survived Concorde's entry into service. *shrug*
musang
Thu Aug 29, 2013 10:15 am
Quoting okie (Reply 16):
To elaborate - LHR - BAH began January 1976, the short-lived SIN extension was December 1977.
And in BA's case the airline was relieved of the aquisition/ownership costs, buying the fleet from the government for a token fee.
Regards - musang
Stitch
Thu Aug 29, 2013 12:36 pm
Quoting musang (Reply 33):
As I recall, only a handful of the frames were acquired at the greatly reduced price. I believe BA did pay "contract price" for a number of their earlier deliveries.
Users browsing this forum: Natflyer, Starlionblue and 2 guests
