futureatp
Cycling Flaps On Ground
Wed Aug 28, 2013 9:35 pm
Just was on a flight (737-300) and something happened I have never seen before from a passenger window. I am just curious what was going on.
Push back from gate. Flaps set to takeoff setting. Then extended to about 15deg. Then retracted. Then extended to 25-30deg (remember Im eyeballing it from row 18...) about 3 or 4 times then retracted. Then set to takeoff. Depart normal. After landing, flaps were retracted and extended to around 10-15deg twice before arrival at gate.
Ive never seen this before as a passenger. I just curious if anybody had a guess as to what was going on. Company mechanic was in flight talking to crew as I deplaned.
KC135Hydraulics
RE: Cycling Flaps On Ground
Wed Aug 28, 2013 11:25 pm
Maybe it was some sort of inflight (sorta) ops checks due to maintenance performed. Or, maybe it was an "2nd verification" clearly done on the ground to verify if a maintenance write-up was infact legit or an anomoly.
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
musang
Thu Aug 29, 2013 10:25 am
In extreme cold weather, after engine start and before taxi, flaps are run out to 40 degrees (full) then back to zero, to check unobstructed movement. A close eye should be kept on the flap position needles to catch any asymmetry or disagreement with the flap lever position selected. The flaps are then extended to the take-off position, unless there is frozen precip, in which case they're kept retracted until just before line-up.
Regards - musang
113312
Thu Aug 29, 2013 3:39 pm
Most likely there was abnormal indications of slat position and they were running through the settings to verify the sequencing of the slats/flaps in all of those positions. Must have turned out to be OK otherwise you would have returned to the gate for maintence.
boeingfixer
Thu Aug 29, 2013 4:47 pm
Quoting musang (Reply 2):
Not all ops are that way. We routinely operate our B752's in -30C to -40C in the winter here and never do a full flap check as it's not needed.
Quoting 113312 (Reply 3):
This is probably the case here.
Ciao,
John
Cheers, John YYC
Thu Aug 29, 2013 7:59 pm
Probably finding an indication light not functioning as required......so recycling to check the problem.
Users browsing this forum: ThePointblank and 1 guest
