questions
B737 Vs B757 Cockpit/Nose
Mon Sep 02, 2013 7:32 pm
If the 737 and 757 fuselage (height, width) are identical, as has been discussed on here many times... ie, a Boeing narrow body is a Boeing narrow body... why did Boeing alter the design of the cockpit/nose on the 757 (vs the 737)? It's been stated that the 737 cockpit is cramped and the 757 cockpit is more roomy. Why did Boeing not adopt and incorporate the 757 cockpit/nose design for the next gen 737s? Would a change have significantly impacted the aerodynamics of the 737?
DualQual
RE: B737 Vs B757 Cockpit/Nose
Mon Sep 02, 2013 7:34 pm
Boeing originally wanted to put the 757 nose on the 737NG. It would have not been a common type though with be Classics. I understand that SWA, as the launch customer, did not like that idea.
There's no known cure for stupid
L0VE2FLY
Mon Sep 02, 2013 7:43 pm
The 737 & 757 are totally different aircrafts, they just happen to have the same fuselage cross section. Boeing did the right thing, nothing defines a 737 like its signature nose.
DualQual
Mon Sep 02, 2013 8:33 pm
Quoting L0VE2FLY (Reply 2):
You've clearly never stowed a bag or bashed your head on the overhead in that cockpit
OldAeroGuy
Mon Sep 02, 2013 9:07 pm
Quoting questions (Thread starter):
To accommodate the 767 flight deck and gain a common type rating.
flyingcello
Mon Sep 02, 2013 9:32 pm
Quoting OldAeroGuy (Reply 4):
This is my understanding too...the innards of the 757 and 767 cockpits are the same. Difference is you step down into the 757 cockpit, and up into the 767 I think...
The 757 nose, for me, is still one of the best looking out there...although the 737, without eyebrows, looks good too. Noisy though from what pilots say.
OldAeroGuy
Tue Sep 03, 2013 12:16 am
Quoting flyingcello (Reply 5):
Correct.
Viscount724
Tue Sep 03, 2013 12:26 am
Width is the same, not the height. The 707 also had a deeper fuselage dimension vertically than the 727/737 although the width was the same.
Mender
Tue Sep 03, 2013 9:35 am
It's surprising how many people don't realise the 757 fuselage has a difference in cross sectional height fore and aft of the wing box.
You sit 'up' in the bigger diameter fuselage and lower in the smaller fuselage to give the pilots the same perspective when they are sat in the pilots seat. IE. it's the space behind you that is bigger in the 767. From the seat looking forwards they both appear to be the same size.
CALTECH
Tue Sep 03, 2013 9:33 pm
Quoting Viscount724 (Reply 7):
Actually, it is the other way around, and only in the aft cargo compartment where the 707 is actually the smaller dimension for fuselage height. The 727, 737 and 757 have a taller aft cargo compartment by 11.96 inches. The passenger cabins are pretty much all the same except for interior fittings. You can find all of the dimensions under Aircraft Description in the following link.
http://www.boeing.com/boeing/commercial/airports/plan_manuals.page
Quoting Mender (Reply 8):
Seems the 727 and 737 also share this difference which increases the height of the aft cargo compartments.
UNITED Would Be Nice
flyingcello
Tue Sep 03, 2013 9:49 pm
Mender, please explain! Are you saying that the fuselage height varies between the fore and aft fuselage? Why would Boeing do this? Surely a uniform cross section is much more sensible for all sorts of reasons...
...or am I misreading your comment?
CALTECH
Tue Sep 03, 2013 10:46 pm
Quoting flyingcello (Reply 10):
This might help,...
Boeing 707
http://i297.photobucket.com/albums/mm233/CALTECHphoto/scan5707_zps3c7cd56d.jpg
727
http://i297.photobucket.com/albums/mm233/CALTECHphoto/scan0001_zps490b0c58.jpg
737
http://i297.photobucket.com/albums/mm233/CALTECHphoto/scan0002_zpsbf0f2050.jpg
757
http://i297.photobucket.com/albums/mm233/CALTECHphoto/scan0003_zpsbd1f8857.jpg
I will measure the cabin width at shoulder and head level between the A-320 and Boeing 737/757 to see what the actual difference is.
DL_Mech
Tue Sep 03, 2013 11:32 pm
It is easily seen here:
Photo © Serge Bailleul - AirTeamImages
Photo © M.J. Scanlon Photography
Compared to the 707:
Photo © Peter Seemann
[Edited 2013-09-03 16:53:58]
This plane is built to withstand anything... except a bad pilot.
OldAeroGuy
Tue Sep 03, 2013 11:53 pm
After the 757 was certified, I asked Jack Wimpress, the 757 Chief Technical Engineer what he thought the biggest error was on the development program.
His answer was not having the same lower lobe for the whole airplane. Early wind tunnel data indicated the deeper forward lower lobe had an unacceptable impact on directional stability for some conditions. Later testing showed there was no issue but it was too late to change the airplane production plan.
CALTECH
Wed Sep 04, 2013 1:10 am
Quoting OldAeroGuy (Reply 13):
Did they find the same issue for the 727/737 programs ? They too have the deeper lower lobe in the aft cargo compartments.
Comparision of the 737/757 side views,
http://i4.photobucket.com/albums/y120/Aeroweanie/Sideview.jpg
A modified photo of a concept 757 with a 737 nose,
Viscount724
Wed Sep 04, 2013 1:53 am
Quoting CALTECH (Reply 9):
What is the other way around? I said the 707 fuselage (not the cabin) is taller from top to bottom. I wasn't referring to any specific part of the fuselage. Check the Boeing drawings and you will find that the 707 fuselage dimension vertically, at least forward of the wing, is taller than the 727/737. The width of the same.
speedygonzales
Wed Sep 04, 2013 9:04 am
Yeah, in a negative way
Ignorance kills. :tombstone:
CALTECH
Wed Sep 04, 2013 2:48 pm
Quoting Viscount724 (Reply 15):
If you could show that, that would be great. I still come up with the same as before, variance of just a few fractions which could be atributed to the structure and fastening of interior coverings. As far as the Interior dimensions, I do not believe a foot would be alllowed to be wasted space, and haven't seen it. If we use thicker Gill Patch in the cargo compartments, there is a formula to adjust the weight and balance of the aircraft. And it changes the interior dimesion ever so slightly. Tenths of a inch. The 707 seems to be just about a straight tube fore and aft of the wing, all the other Boeing narrowbodies are deeper vertically aft of the wing, and that is in the aft cargo compartment vertical dimension. The passenger cabins stay the same. Unless I am reading it wrong, interior dimensions;
707
Fore of the wing- 130.6
Aft of the wing---- 130.6
727
Fore of the wing- 130.3
Aft of the wing---- 140.3
737
Fore of the wing- 130.5
Aft of the wing---- 133.1
757
Aft of the wing---- 140.2
On the 757, in the wheel well, one can see the 1 foot drop from the front of the wheel well to the back. Very noticeable.
[Edited 2013-09-04 08:01:26]
Buyantukhaa
Wed Sep 04, 2013 4:02 pm
And I was one of them - and now that I know, I actually see it clearly on pics. One learns something new every day...
I can see it clearly on the 727 images, but not on the 737...
Quoting CALTECH (Reply 17):
737
OK 2.6 inch is 6.5 cm, not that much. Is it the same throughout all 737 series?
I scratch my head, therefore I am.
DL_Mech
Thu Sep 05, 2013 12:33 am
Here are some interesting cross section pics of the 707. I know you've been in the forward cargo pit of a 757, there's no way a row of seats could fit in there......
Photo © AirNikon Collection-Pima Air and Space Museum
Photo © Orlando Sotomayor
Viscount724
Thu Sep 05, 2013 1:30 am
In the following Boeing documents, scroll down past the tables at the beginning to the first page of aircraft drawings (section 2.2). You will find the vertical fuselage height is shown just forward of the wing.
707 - 14 ft. 2.5 in.
727 - 13 ft. 2 in. in forward fuselage, 14 ft. further back
737 - 13 ft. 2 in.
757 - 13 ft. 2 in.
707 fuselage slightly more than 1 ft. deeper top to bottom than the 737 and 757, and also the 727 in the forward part of the fuselage.
707:
http://www.boeing.com/assets/pdf/commercial/airports/acaps/707sec2.pdf
727:
http://www.boeing.com/assets/pdf/commercial/airports/acaps/727sec2.pdf
737:
http://www.boeing.com/assets/pdf/commercial/airports/acaps/737sec2.pdf
757:
http://www.boeing.com/assets/pdf/commercial/airports/acaps/753sec2.pdf
CALTECH
Thu Sep 05, 2013 5:07 am
Quoting Viscount724 (Reply 20):
Thanks, I stand corrected. It looked like that was the height of the top of the fuselage above the ground on the 707 drawing. The 707 seems to waste a foot of fuselage forward of the wing in the vertical dimension compared to the other narrowbodies, must be in the structure like intercostels. Looks like the aft fuselages, at least on the 727/757 are the same as the 707, the 737 seems to be a bit smaller there than the others too. The fuselage forward of the wing was made shorter on the 727/737/757. The differences are in the vertical dimension of the cargo pits. The passenger cabins are all the same in width and height. Thanks for your input Viscount724.
[Edited 2013-09-04 22:15:24]
[Edited 2013-09-04 22:17:31]
Fri Sep 06, 2013 8:56 am
Educational........Thanks.
Wish there was a forum to address manufacturing Q&A.
Users browsing this forum: curlyheadboy and 1 guest
