qslinger
Boeing 787 - Extended Parking In The Sun
Wed Sep 11, 2013 8:24 am
Hi All:
When 787's are parked at Everette, I notice that the windows are covered by black cover. Correct me if I am wrong, but I guess they do this to keep the sunlight out and to keep it from bleaching the seats or interior etc
My question is, what does the operator do when the 787 is parked outside for a few days in the hot sun with no external power attached. Will the window dimmer still work without power? How will they keep the sun out in those cases without having to black cover the window's all over again.
Apologies if this topic has been covered.
Raj Koona
baldwin471
RE: Boeing 787 - Extended Parking In The Sun
Wed Sep 11, 2013 2:41 pm
May be something to do with the electro-chromatic windows? Pure guess work here though.
KELPkid
Wed Sep 11, 2013 6:51 pm
It is not unusual at all for aircraft under storage to have the windows covered. Plexiglas is quite sensitive to the sun, and prolonged exposure to the sun can lead to the the windows starting to haze and crack. I'm sure Boeing does not want to have to replace the outer pane of the cabin windows when they pull aircraft out of storage
In service, the aircraft windows are regularly cleaned and polished, which prevents the problem.
Thu Sep 12, 2013 5:25 pm
Quoting qslinger (Thread starter):
Is this cover on from the inside or is it the dimmer selected on.
duncan16
Fri Sep 13, 2013 10:23 pm
My understanding is that the dimmable windows use a technology called electrochromatic. These dimmable windows go to a clear state when there is no power. They cannot select that the windows be darkened. So, a maximum amount of heat is transmitted inboard when parked on the ramp. This must be why the black covers are needed.
KarelXWB
Crew
Sat Sep 14, 2013 4:20 pm
Not just the windows, they seal off every hole:
Photo © Royal S King
Photo © David Lednicer
This server is powered by a lemon and two electrodes.
pygmalion
Thu Sep 19, 2013 11:00 pm
the dimmable windows arent installed until after the interior goes in. The airplanes in storage dont have interiors.. Interiors install only takes a couple weeks. The dimmable portion of the window is a separate portion from the structural pressure portion that is seen on the outside.
the exterior window panes are covered just to prevent dirt and grit from sitting on the pane and degrading the optical quality over a medium storage period. Covering has nothing to do with the CFRP or UV.
KarelXWB
Crew
Fri Sep 20, 2013 11:05 am
Quoting Pygmalion (Reply 6):
You sure about that? I read the first batch had interiors, the original idea was to deliver them directly after certification.
bikerthai
Fri Sep 20, 2013 1:44 pm
I thought the "dimmable" function is integrated in the window itself. The only thing that is on the sidewall are the individual switches. Even without the switch, the windows can be controlled by the attendant panel.
bt
Sat Sep 21, 2013 7:16 pm
Quoting KarelXWB (Reply 5):
Under Line Mx parking too.....Are you sure?.
Users browsing this forum: 9vswr, lightsaber, LINYUSA and 1 guest
