airlinebuilder
Few Questions On Aircraft Mechanisms
Fri Sep 13, 2013 1:52 am
Hello All, I have a few questions on Aircraft mechanisms that I have periodically been dying to ask.
Airbus : Why is it that almost all airbus aircrafts except the A380 leading edge and trailing edge flaps are left extended when on ground? (is this a basic operational manual requirement?)
Why are airbus trailing edge flaps except the A380 span area when extended are quite small and during full landing configuration there seem to be just a small difference on the angle when taking off especially on the A330/340?
Boeing : Was wandering why the two inner leading edge flaps of the B747s retract during reverse thrust?
I know this has been covered before but a refresher, cant seem to find it. Thank you
AA737-823
RE: Few Questions On Aircraft Mechanisms
Fri Sep 13, 2013 2:56 am
Quoting airlinebuilder (Thread starter):
Because the thrust reversers direct high velocity air up into the backside of the Krueger flaps if they are extended. To protect the mechanical mechanisms, the flaps are retracted, to prevent any debris from impacting the actuation works.
No clue what you're talking about. I've never seen an Airbus that had the wings in anything other than a clean condition at the gate. ???
Boeing has, for decades, built far more complicated and capable high-lift devices than any of their competitors, domestic or abroad. That said, there are drawbacks, and we've seen Boeing retreat from the maintenance-intensive, though very effective, designs. The 747-8 and 787, for example, have far simpler flaps than their predecessors.
The A320 flaps do their job, but aren't quite as fancy as some of the Boeing designs.
Fri Sep 13, 2013 4:07 am
Quoting AA737-823 (Reply 1):
One more reason. On widebodies, Boeing favors a high speed and a low speed aileron. With the low speed (outer) aileron locked out at high speeds, the wing can be made more flexible, and thus lighter without risking aileron reversal. The downside is that you lose flap area. Some of that is mitigated by using the high speed aileron as a flaperon.
Airbus, on the other hand, favors an unbroken flap line with only one aileron. This means more efficient lift creation since there is more flap and it is continuous from root to aileron. Thus it probably doesn't need to be extended as far.
Another reason Boeing is retreating is because of the weight of these devices. Setting aside materials, I bet the offset hinge flaps on the 787 are way lighter than the Fowler flaps on the 777.
DeltaB717
Fri Sep 13, 2013 4:47 am
Only thing I can come up with is the ailerons and elevators drooping once their electrical/hydraulic/whatever power is taken away. Which the A330 and A340 do, and pretty sure A32X also. Not sure on A380?
Fri Sep 13, 2013 4:52 am
Quoting DeltaB717 (Reply 3):
Probably the same. Gravity is a harsh mistress...
PhilBy
Fri Sep 13, 2013 7:44 am
Ailerons will droop with no power but slats and flaps will remain retracted.
The only time an Airbus should have slats and flaps extended on the ground is for maintenance.
Not forgetting the double-slotted flaps on the A321. They're as large as they need to be to do the job. Any extra would just add weight.
Compared to Boeing, Airbus wings tend to be less flexible and therefore by implication have a deeper section. This may lead to an apparent difference.
mandala499
Fri Sep 13, 2013 10:27 am
In hot weather, for A320 family to the A340, the manual requires you leave the leading edge slats extended (therefore the trailing edge flaps too) to prevent a temperature misread for I think the bleed air system. This is for above 33C I think... *can't remember correctly*
Different wing design to Boeing... Yes, the clean flap lines with no inboard aileron as previously mentioned.
DarkSnowyNight
Fri Sep 13, 2013 12:49 pm
Quoting PhilBy (Reply 5):
This done most commonly on the 330 & 340, to setting one. The reason is that in warmer locales, like DFW, PHX, DXB, etc, enough heat will generate an ECAM msg, and will most likely delay the flight considerably, as there is no relief (eg, you cannot just clear out the message, it has to go away for real after troubleshooting, and a call to MX Control; there is no MEL for this).
Much like a GE90, I'm a huge fan of Big Twins...
Pihero
Fri Sep 13, 2013 2:54 pm
I beg to differ : The technology has tremenduously evolved and the simple single slotted flap of, say, an A320 is far superior to the triple slotted TE flap of a 727 or a 732.
See the evolution
The 732 :
Photo © Serge Bailleul - AirTeamImages
vs the 738 :
Photo © Laszlo Gyori
the 742 :
Photo © Jochen Thoma
vs the A333
Photo © Hardy Springborn
the A320 :
Photo © Allan Martins Antunes
compared to the A321 double slotted TE Flap :
Photo © Felix Roitsch
There is very little gain in coefficient of lift on the A321 : The reason for it was to have a flatter body angle at rotation and landing. The A321 is still one of the fastest approaching airliners around.
Quoting Starlionblue (Reply 2):
That solution is the reason Boeing did away with the single slotted flap for the 777.
For the 767, this configuration is exactly due to the same reason as the A321.
Contrail designer
Users browsing this forum: Yahoo [Bot] and 2 guests
