YQBexYHZBGM
Why No Recent T-tails Larger Than RJ?
Mon Sep 16, 2013 7:04 pm
The title of this thread is self explanatory. Since the end of the 717 line, no T-tail designs larger than RJs have been produced by the major passenger aircraft manufacturers. More importantly, since the end of 727 and Tu-154 production, no T-tails in the 180 passenger range have been produced, and the design has never been used on a passenger aircraft larger than the latter two models (although the initial concept of the 757 had a T-tail).
I understand that the T-tail design is subject to the "deep stall" phenomenon, but given that a number of large military / cargo aircraft use the design, does anyone have any conjectures as to why it hasn't been used on larger passenger aircraft, or on any recent models larger than the RJs?
Al
YQBexYHZBGM
1337Delta764
RE: Why No Recent T-tails Larger Than RJ?
Mon Sep 16, 2013 7:06 pm
Quoting YQBexYHZBGM (Thread starter):
The MD-90 almost has the same amount of passenger capacity as the 727-200; it was originally supposed to be DL's 722 replacement until remaining orders were cancelled in favor of the 738. In fact, prior to removing the rear galley, DL's MD-90s had 150 seats, vs. 149 on the 722 prior to retirement.
[Edited 2013-09-16 12:13:31]
cargolex
Mon Sep 16, 2013 7:19 pm
It's heavier and less flexible in terms of future engine options for large aircraft (large meaning anything bigger than a CRJ, which has it's origins in the Challenger) and a limiting factor in stretches.
Fuel burn is everything now - and so devoting more weight and complexity and potentially limiting the future powerplant choices is a decision few would want to make.
c680
Mon Sep 16, 2013 7:28 pm
A further thought:
There are very few Business Jets that do NOT use a T-Tail design.
The smaller frames actually make for simpler systems by moving quite a bit to the tail.
And it is almost unheard of to have engine options on a Business Jet.
Center line thrust makes for greater stability in an engine out situation = easier to fly = safer.
My happy place is FL470 - what's yours?
bohica
Mon Sep 16, 2013 7:32 pm
That is to protect the horizontal stabilizer from accidental "ramp rash" during loading/unloading.
Viscount724
Mon Sep 16, 2013 7:39 pm
A search would find many earlier threads on this subject. Here are 3. There must be at least a dozen.
Benefits Of The T-tail (by Brenintw Feb 21 2008 in Tech Ops)
Why No More T-Tail Airplanes, Besides Regionals? (by c5load Mar 31 2010 in Tech Ops)
Are T - Tails Condemned To Extinction? (by Gonzalo Apr 4 2013 in Tech Ops)
T-tails are inefficient for larger aircraft. They also add to the overall length but much of that additional length is only to permit the engines to be attached and and doesn't increase passenger or cargo capacity.
Look at the original and smallest DC-9-10. It's overall length is a few feet longer than the 737-200 but the passenger cabin is several seat rows shorter. The 727-200 is also a few inches longer than the longest 707.
[Edited 2013-09-16 12:56:47]
sankaps
Mon Sep 16, 2013 7:54 pm
Quoting Cargolex (Reply 2):
Tell that to the DC9 family!
[Edited 2013-09-16 13:18:57]
Aloha717200
Mon Sep 16, 2013 8:02 pm
There's also the deep stall issue. That's why Boeing quit using the T-tail. It's in the Guy Norris book.
IADCA
Mon Sep 16, 2013 8:28 pm
Quoting Aloha717200 (Reply 7):
*Facepalm*
I believe MX is also a factor. It's easier to do maintenance on an underwing engine than it is to get up alongside the fuselage on an MD-80 sized plane, although tail-mounted engines can also allow for shorter gear.
Viscount724
Mon Sep 16, 2013 8:36 pm
How many 727 deep stall incidents have there been? The only one I recall being mentioned was during the test program. If deep stall was a problem for the 727 I think there would be more reports considering that 1,832 727s were built and it's been in service for 50 years.
Aloha717200
Mon Sep 16, 2013 9:15 pm
Quoting Viscount724 (Reply 9):
It wasn't that there were a number of incidents, but that the potential for an incident was a risk that Boeing no longer wanted to build into its designs. The change came about during the early stages of the 757 and 767 programs, where both planes were originally designed with T-tails, and subsequently altered to eliminate the risk of a deep stall.
My source is this book:
http://www.amazon.com/Boeing-Guy-Norris/dp/0760304971
[Edited 2013-09-16 14:17:23]
BoeingGuy
Mon Sep 16, 2013 9:24 pm
Quoting bohica (Reply 4):
I think the real reason is so that paratroopers can jump out and not get sliced in half by the horizontal stabilizer.
Yflyer
Mon Sep 16, 2013 9:29 pm
Quoting IADCA (Reply 8):
My understanding was that the main reason planes like the DC-9 and 727 had t-tails was to accommodate the tail mounted engines, and they had tail mounted engines to allow for shorter gear. This was to make the plane easier to service at smaller airports that might not have air stairs, baggage belts, etc. That's not really a problem anymore, particularly at airports served by mainline jets, so there's no good reason for tail mounted engines anymore and thus no good reason for t-tails anymore.
SEPilot
Mon Sep 16, 2013 9:35 pm
The aerodynamic advantage of the T-tail is that it puts the horizontal stabilizer in "clean" air that is undisturbed (relatively) by the wing. This, I believe, reduces drag slightly and increases effectiveness, also slightly. The aerodynamic disadvantage is that it is subject to the deep stall effect, which is that when in a stall the wing can block airflow to the stabilizer, making it difficult or impossible to recover. The mechanical advantages of the T-tail is that, with rear mounted engines, engine access is much easier, and the horizontal stabilizer is less vulnerable to FOD or vehicle collision damage, which is why it is used so much on military transports. The mechanical disadvantages are that it requires more structure, and hence more weight, and is harder to access for maintenance.
And this raises the question of the advantages and disadvantages of tail mounted engines. Joe Sutter proved when working on developing the 737 that, for a large airliner, wing mounted engines would allow two more rows of passengers for the same weight and size of the airframe. This has been why all subsequent designs have had wing mounted engines. And with wing mounted engines the advantages of the T-tail just do not overcome the disadvantages, especially the extra weight, which leads to less efficiency.
[Edited 2013-09-16 14:36:05]
YQBexYHZBGM
Mon Sep 16, 2013 9:50 pm
There were no incidents (to my knowledge) involving deep stall on the 727, mainly because of the lessons learned from development of the BAC 1-11. The test flight of the 1-11 crashed due to deep stall with the loss of all aboard, requiring a redesign of the tailplane.
Quoting Yflyer (Reply 12):
Not to mention the reduced likelihood of debris or slush ingestion on gravel surfaced or poorly-maintained runways. Nonetheless, airlines such as Canadian North, First Air and Air Inuit now use 737s for such missions, despite their short gear and low-mounted engines.
In terms of aesthetics, the reason I find the 727 more visually appealing than other aircraft (including other T-tails) is the shallower angle of the forward edge of the vertical stabilizer. Very graceful.
A T-tail 767, I would have loved to have seen that!
Al
YQBexYHZBGM
Tue Sep 17, 2013 12:58 am
Quoting YQBexYHZBGM (Reply 14):
I believe NW 6231 was in a deep stall at the end. However the initial stall was recoverable. The report mentions "uncontrollable stall".
Linking the report itself leads to a broken post, but it reference #2 on the Wikipedia page. http://en.wikipedia.org/wiki/Harriman_State_Park_plane_crash
On page 18
pitched up to nn extremely high angle of
the left horizontal stabilizer. Thsreaftcr, the aircraft probably rolled
attack, and continued todescc-: in?., uncontrollable stall to :he ground.
Quoting from the report about 727 stall characteristics.
Like other aircraft which have horizontal stabilizers located near or
on top of their vertical stabillzcrs. the R-727 does pass through a range
of high angles of att:lck where longitudinal instability occurs. ?his in-
stability causes the aircraft, when no control force is applied, to pitch
to even htgher angles of attack. Longitudinal instability is caused by
derraded horizontal statilizcr ctfectivcness whcn thc a:rcraft's attitude
is such that the horizontal stabilizer Is enveloped by the lowenergy tur-
bulent sir in the wake from the wings. When these high anzles of attack
are reachcd, a push forcc on the control colu;m is required to reduce the
angle of attack. For a b-727 with an aft c.8. location and stabillzcr
trim in the cruise range, wind cunncl data show thnc a noscdovn pitching
muent will dacrease the angle of attack and stall recovery can be attained
bg applying push forces to the control column
YQBexYHZBGM
Tue Sep 17, 2013 2:45 am
I've read about NW 6231 before. I still haven't figured out why they didn't manage to recover from the stall. It's sad that the crew perished, but at least they weren't carrying passengers.
Al
Tue Sep 17, 2013 2:53 am
Quoting YQBexYHZBGM (Reply 16):
Seems to me it was classic tunnel vision caused by stress and worsened by a lack of understanding of stalls. Eerily similar to AF447 with iced up pitot tubes and holding back on the control column. In Macarthur Job's excellent Air Disaster series, the deep stall during this accident is clearly described and illustrated.
[Edited 2013-09-16 19:55:05]
Fabo
Tue Sep 17, 2013 11:04 am
IIRC at least one if not more Tu-154s were also lost to deep stall, possibly Il-62 as well.
Speaking of Il-62, both that and VC-10 were T-tails bigger than 727/154.
Yes, but the 737-200 has to have an additional system to alleviate that risk, that is the nose gear deflector and the tubes that blow air in front of the engines so that any small debris (sand, gravel) would be blown down or away isntead of being ingested.
Quoting BoeingGuy (Reply 11):
That would be alleviated by use of rear ramp, as is the case on several conventionally tailed military turboprops, i.e. An-26, C-130
Quoting SEPilot (Reply 13):
Does it not have to be larger though, since the center of gravity and center of lift is closer, and the arm is shorter?
Especially the Tu-134 always strikes me as having a particularly large tailspan. Well visible when looking head on.
Photo © Vladimir Korobkov
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
Tue Sep 17, 2013 11:11 am
Quoting Fabo (Reply 18):
The opposite. Given the swept fin, the stabilizer of a t-tail tends to have a longer moment arm, and can thus be smaller.
YQBexYHZBGM
Tue Sep 17, 2013 2:27 pm
I checked passenger capacity of both the VC-10 and 154 before posting, both were less than a 727-200 in all coach configuration would have. I did not check the overall dimensions of the VC-10 in comparison to the other two; I believe the 154 is the largest of the three. I didn't think of the Il-62 at all.
Al
Fabo
Tue Sep 17, 2013 3:16 pm
VC-10 and Il-62 both had relatively similar seating capacity with the 727, but much higher MTOW, owing to their long-range application. In both cases, just the fuel load itself attacked 727-200 MTOW, maybe even exceeded.
Quoting Starlionblue (Reply 19):
That is true... didn't think of that.
speedbird128
Tue Sep 17, 2013 6:02 pm
I would argue that a lot of people have jumped from a C130 and not died. It doesn't have a t-tail...
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
Western727
Tue Sep 17, 2013 7:57 pm
Makes sense. No wonder the C-130, C-5 and C-17 all have high wings.
Jack @ AUS
DocLightning
Tue Sep 17, 2013 11:26 pm
You're confusing a T-tail with tail-mounted engines. While it is true that many (most?) T-tail aircraft have rear-mounted engines, and that most rear-engine aircraft have T-tails, not all do. If the engines are rear-mounted, then the tailplane must be larger because the center of gravity is closer to the rear, you are correct. However, with wing-mounted engines (as on the C-5), a T-tail can be a bit smaller in span than a fuselage-mounted tailplane, as Starlionblue says.
Just to clarify, you are describing the optional "gravel kit" that is available for the 732, but not any subsequent models.
There are good reasons why T-tails were more popular in the past, but aren't anymore. In the past, T-tails were designed on smaller jet aircraft that would serve smaller markets. 30-50 years ago (yes, we've had small jets for over 50 years), some of those airports might have semi-prepared airfields with gravel runways, much as those airports in northern Canada still do. In addition, such airports might not have a set of airstairs or a scissors-lift baggage loader available back in 1965. Mounting the engines on the rear of the fuselage served the purpose of reducing fuselage height (and indeed, built-in airstairs were much more popular back then) and also reducing FOD ingestion risk.
In this century, most airports with any commercial service have prepared airfields, even in the third world, while belt loaders and airstairs are standard eqiupment. Thus, those major benefits of rear-mounted engines are negated. Most of the T-tailed airliners being built today are regional jets with legacy designs. Back when the first CRJ and ERJs were made, they still had to take semi-prepared fields with no airstairs into account. Today, that is much less likely of an issue and so the new regional jets are being built with wing-mounted engines.
Wing-mounted engines allow for a weaker (lighter) wing structure because the bending moment from the wing's lift is alleviated by the mass of the engine. The fuselage doesn't need to be as strong to transmit all the thrust, so it can have a lighter construction. The placement of the engine nacelles almost completely in front of the wings also acts as an anti-shock body, which softens the sudden widening in aircraft cross-section at the wing root (the flap track canoes soften the transition back on the trailing edge). The proximity of the engines to the ground also simplifies maintenance. For that reason, almost all airliners being built today have wing-mounted engines and a conventional empennage.
This article discusses both the area rule with some of the aerodynamic issues with the T-tail.
I will add that military cargo aircraft like the C-5 have high-mounted wings for several reasons. First, it means that the wing spar does not have to protrude through the lower part of the cabin, making it much easier to load vehicles into the hold. Second, it allows the fuselage to sit very close to the ground so that vehicles may be loaded by built-in ramp. Third, such aircraft must be designed to fly into semi-prepared and even unprepared airfields and so raising the wing allows the engines to sit higher and out of the way of FOD. In those cases, T-tails are often used both to protect against FOD and also to keep the tailplane out of the jetwash.
-Doc Lightning-
-Carl Sagan
daviation
Wed Sep 18, 2013 12:18 am
I've always been fascinated by NW 6231 because (1) I was flying from LGA-BUF at the same time 6231 was flying from JFK-BUF (on a football charter), and (2) I live less than five miles from Harriman State Park, the crash site.
Your comment above is actually one of the reasons that the NW flight crashed - there were no passengers and the pilots thought that the (erroneous) overspeed readings were due to their light weight. They continued to apply back pressure on the column to arrest the overspeed, but they were in fact stalling the airplane. They missed the pitot tube heat during the takeoff checklist. I have the entire NTSB report which is chilling.
PlaneFlown:717,727,737,747,757,767,777,DC8,DC9,DC10,L1011,F100,A300,319,320,321,330,340,CRJ,ERJ,E190,Av85,DH8,Beaver,ATR
Viscount724
Wed Sep 18, 2013 1:57 am
Quoting DocLightning (Reply 24):
The only T-tail commercial jets I can recall that once served airports with gravel runways in northern Canada were the 727 and (quite briefly) the Fokker F-28. Not many 727s were used in the north and I believe the F-28 wasn't very suitable due to its lack of main deck cargo capability. It also lacked thrust reversers.
The few 727s once used in the north were combis. The 737-200 combi with gravel kit has been by far the most common commercial jet used on those routes. 17 are still registered in Canada with 6 operators.
I'm pretty sure the the DC-9 and it's MD-80/90/717 relatives were never certified for use on unpaved runways.
YQBexYHZBGM
Wed Sep 18, 2013 3:30 am
Excellent technical review, DocLightning. I am an engineer, so at least I understand bending moments. I had to take fluid mechanics as an undergrad, but since I don't deal with aeronautics, sometimes having someone summarize makes all the difference. I do remember the area rule, but wouldn't know how to apply it in practice, other than to emulate the CV990 wing design.
Al
Wed Sep 18, 2013 3:53 am
Quoting YQBexYHZBGM (Reply 27):
In concept it is not very complex. The ideal aerodynamic shape is a cigar with pointy ends, with a constantly changing profile. This is the "Sears-Haack" shape.
http://upload.wikimedia.org/wikipedia/commons/3/33/Sears-Haack.png
Since you need wings, engines and such, this shape is impractical for an airliner. The point is that given the area rule, you get much of the benefit no matter the actual shape as long as the cross-sectional development is the same. Say you chopped the plane up like a salami along it's length. As long as the area of each cross section gradually increases (then decreases at the back), you're good. That's why after the wing on modern airliners you get massive wing-body fairings and flap track fairings.
Here's a great illustration of the concept.
DocLightning
Wed Sep 18, 2013 5:03 am
I am an engineer,
Disclaimer: I am not. I'm a physician, but I understand basic mechanics (physics) well enough.
-Doc Lightning-
-Carl Sagan
mandala499
Wed Sep 18, 2013 6:17 am
The reason why nowadays T-tailed passenger jets will remain for smaller capacity aircraft is not just the above...
Back in the days where VC-10 was having its glory days, many large-ish airports still had propeller airliner infrastructure.
Small T-tailed jets are nice to open new routes... but as traffic builds up, the airport would prepare for larger things to come... hence, limiting the use of the T-tails... We experienced this in many of our now main airports over the past 40 years... First was the F-27, then the F-28... then came the 737s then 320s...
Quoting daviation (Reply 25):
Especially this part: the recording revealed that the pilots believed that the shaking of the stick shaker mechanism was caused by the airliner reaching the speed of sound, and not a warning that it was going into a stall.
But anyways... this picture never ceases to amaze me...
Photo © Don Rogers
jetstar
Fri Sep 20, 2013 12:13 pm
Northwest Orient Airlines Flight 6231 was the fatal crash of a Boeing 727 on December 1, 1974 in Harriman State Park near Stony Point, New York. The Northwest Airlines 727 had been chartered to pick up the Baltimore Colts football team in Buffalo, New York. All three crew members on board were killed when the aircraft struck the ground following a stall and rapid descent caused by the crew's reaction to erroneous airspeed readings caused by atmospheric icing. The icing occurred due to failure to turn on pitot heat at the beginning of the flight.
JetStar
YQBexYHZBGM
Fri Sep 20, 2013 2:38 pm
Quoting JETSTAR (Reply 31):
I know that part. It still doesn't explain why they didn't figure out how to recover from the stall, unless as was previously suggested, the crew mistakenly believed the stick shaker was due to the (false) overspeed condition rather than a stall.
I've always thought that the stick shaker makes an already stressful situation controlling the aircraft in an emergency even worse. I'd hate to be wrestling to control a crippled aircraft with the control column shaking like that. Why did they choose the stick shaker rather than an audible stall warning?
What about sidestick controlled aircraft? I'm assuming they don't have a stick shaker. If frozen pitot tubes and a stall induced by erroneous flight inputs were at least in part responsible for the loss of AF 447 as conjectured, is there any secondary system to inform the crew that the aircraft is about to stall?
This is a diversion from the main topic of this thread, but I think it's an important one. Since I started the thread, all is well (I hope)!
Al
YQBexYHZBGM
LH707330
Fri Sep 20, 2013 4:24 pm
Quoting YQBexYHZBGM (Reply 32):
There are a number of AF447 threads discussing the sidestick and stall warnings, which in the 330 are an aural warning that says "Stall" repeatedly, and text on the PFD. Some have argued that a tactile warning would have helped alert the crew as to their situation, and the investigation looked into mental prioritizing of different inputs while under stress.
Fabo
Fri Sep 27, 2013 1:05 pm
Two reasons,
a) stick shaker should emulate the "shaking/buffeting" feeling many small airplanes have when approaching stall, that should, in theory, prompt the pilot to react the same way he would react in a small airplane - by pushing.
b) siren is just a siren, in a stress moment you might be unable to tell why it sounds (Is there a fire? Is my gear down and should be up? Is my gear up and should be down? Am I loosing pressurization?), while a tactile signal in the controls immediately alerts the pilot in that situation is developing in airframe, to be fixed by controlling the airplane into a different pitch/power combination. This is in fact evidenced in said crash, the crew believed the shaking is structural, due to approaching speed of sound. Granted, this is not the correct interpretation, it they went of in a good direction - and only later took a wrong turn.
Users browsing this forum: chimborazo, curlyheadboy, WholaLottaLove and 2 guests
