Faro
Airliner Stress Questions
Fri Sep 20, 2013 8:52 am
For a normal, uneventful flight what, in descending order of severity, are the greatest mechanical stresses imparted to an airliner structural frame?
What is the single greatest stress event allowed for by airworthiness regulations: severe weather encounters, beyond-MLW landings, MTWO rejected take-offs, etc? If a specific airframe accumulates a statistically significant series of such peak stress events, may it have to be retired early? Who makes that decision, the operator or the maker of the ariframe?
Faro
The chalice not my son
PhilBy
RE: Airliner Stress Questions
Fri Sep 20, 2013 11:04 am
Quoting faro (Thread starter):
That will depend on the part of the structure but normally for an uneventful flight
Landing
Take-off
Gust loading
Crash (for much of the airframe) followed by hard landings.
After certain peak-stress events the a/c will be inspected. If damage is found the a/c may require more frequent fatigue inspections. Normally the routine take-off, flight and landing cycle (or operating from San Francisco) is more punitive to the airframe than infrequent peak stress events.
Retirement of a modern a/c due to fatigue issues is rare. Normally it is for commercial reasons but increased maintenance costs may play a part.
Faro
Fri Sep 20, 2013 2:03 pm
Quoting PhilBy (Reply 1):
Landing
Take-off
Gust loading
Are landings more stressful because of thrust reversal? Otherwise it would seem to me that landings are quite pedestrian occurrences stress-wise...
Also, by gust loading I imagine that this is the non-CAT type.
What is the peak vertical G deceleration which regulators consider as "survivable" for i) passengers and ii) the airframe itself?
Faro
roseflyer
Fri Sep 20, 2013 2:44 pm
I would assume it is landing because that is the only real impact in a routine flight.
In general I am not sure how to answer the question since stress analysis is compartmentalized and focused on each area. I have not really seen it at an airplane level.
Faro
Fri Sep 20, 2013 3:19 pm
Quoting roseflyer (Reply 3):
From what I recall, pavement loadings and change in kinetic energy are much greater during takeoffs, mainly because of the high weights as compared with landing weights...don't know really...
Faro
LH707330
Fri Sep 20, 2013 4:26 pm
Is this due to the corrosive salt air, or are you making a joke?
PhilBy
Fri Sep 20, 2013 5:10 pm
Quoting LH707330 (Reply 5):
The runway surface is sufficient that there are FAA mandated (I believe) fatigue loadings specific to this runway i.e it may be the worst runway in regular commercial use. I'm not entirely sure of the specifics.
Quoting faro (Reply 4):
Pavement loadings are higher due to the higher MTOW but the take-off is more gentle.
Wheels-up landing can also be a little severe.
Quoting faro (Reply 2):
Best place to get the exact answer is CS25 (EASA or FAA) . Airframe must be certified for 6g vertical, I'm sure that I saw something aout seats being certified for 16g but that's hearsay.
Fabo
Fri Sep 27, 2013 1:08 pm
Quoting PhilBy (Reply 6):
Something to do with the earthquakes and the construction? How would other Californian airports measure up?
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
bikerthai
Fri Sep 27, 2013 1:33 pm
Early in my career I had the opportunity to tour the Boeing Fatigue test facility. So bear with me as my memory is not that great.
They don't fly the fatigue airplane with max load every flight. They do the standard Ground Air Ground (GAG) profile. Then once in a while they would throw in a series of spikes to simulate random turbulence.
Max Rejected take off is tough on the airplane but the load is more fore aft. The fuselage and wing is very strong in that direction.
Hard/heavy landing is one of the max stress condition where they will need to go in to inspect structure components for damage.
I'm not sure whether they inspect the structure after heavy/severe turbulence.
16 g for seat is for forward loading only and is a dynamic load situation where the load profile varies with time. The 6g vertical also applies to the seat but it is purely a static load.
So if an airframe do experience one of these high load situation, then the fatigue life is affected and is reduced. But the reduction is all estimates and calculation to aide in determining the maintenance intervals of the frame. Final determination of whether the frame is still structurally viable is best obtained through visual inception and determine if the crack growth exceed the point where repair and maintenance cost prohibited.
bt
PhilBy
Mon Sep 30, 2013 8:18 am
It seems that there was a "severe bump" on the runway prior to resurfacing.
From CS25 AMC25.491
"Some manufacturers used actual runway profile data to calculate loads. The runway profiles of the San Francisco Runway 28R or Anchorage Runway 24, which were known to cause high loads on aeroplanes and were the subject of pilot complaints until resurfaced, have been used in a series of bi-directional constant speed analytical runs to determine loads."
Also:
"The profiles of those runways are described in NASA Reports CR-119 and TN D-5703."
Quoting bikerthai (Reply 8):
It is also possible for a one-time peak load situation to increase crack initiation life for a structure as plastic strain can leave residual compressive stresses that mitigate the tensile portion of the cyclic fatigue loading. Think of it like pre-stressed concrete.
Crack initiation due to fatigue loading is probabilistic. It will not occur reliably at the same number of cycles for each identical structure under the same loading. For this reason a large scatter factor is applied meaning that, on average a component will have a fatigue life several times longer than the certified life of the a/c. For critical structure analysis is often based on showing that the time taken for a crack to reach a critical length after it is detectable exceed the inspection interval or that loss of a piece of structure will not cause loss of safe flight.
The manufacturer will define operationally acceptable structural damage. The operator will decide if he wants to pay repair/maintenance costs.
dh121
Tue Oct 01, 2013 1:14 pm
I seem to recall from my aero apprenticeship many years ago that a severe "braked taxi" was one of the highest stress loading cases. Worst, I guess, in a take off condition.
citationjet
Thu Oct 03, 2013 12:56 pm
Design limit loads are determined for each component on the aircraft (fuselage, wing, tail, gear, flaps, etc) for various scenariois (taxi, turbulence, maneuvers, landing, etc). The component that sees close to a limit load on most every flight are the flaps and speedbrakes, as they are usually deployed close to the max flap extension speed for almost every flight. Landing gear loads for any given landing are usually much lower than the maximum sink rate for the design limit load (10 ft/sec?).
[Edited 2013-10-03 06:45:56]
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
Users browsing this forum: DFWflightpath and 1 guest
