katanapilot
A Question About Tri-jets
Fri Sep 20, 2013 2:23 pm
I have read so much about how Tri-jets were a solution to ETOPS issues before twins were allowed to go long distances over water and that planes like the MD-11 are now very inefficient because they are running three engines compared to more efficient twins...so my question is this:
Why weren't tri-jets built with two efficient (for their time) engines and an on-demand emergency engine on the tail that wouldn't run unless there were issues over water? If they had built them like this maybe they would have had a much longer service life and we'd get to see them for a few more years!
Stitch
RE: A Question About Tri-jets
Fri Sep 20, 2013 2:24 pm
Quoting katanapilot (Thread starter):
Hauling that extra engine around would be a fair bit of dead-weight and I am not sure how easily it would be to start such an engine if it had been shutdown for a significant period of time during the flight.
katanapilot
Fri Sep 20, 2013 2:31 pm
Quoting Stitch (Reply 1):
Surely hauling dead weight is more efficient than running a third engine!
As far as the start-up, couldn't an 'emergency engine' have been developed with sure-fire startup if the industry had asked for it?
Fri Sep 20, 2013 2:47 pm
Quoting katanapilot (Reply 2):
Actually no. It is much more efficient to run a third engine at all times than to carry a shut down third engine. The drag from a shut down engine alone is horrendous.
Sure. It is called an APU and most airliners have one.
United1689
Fri Sep 20, 2013 2:52 pm
One word: Weight
Quoting Starlionblue (Reply 3):
Bingo   The drag would kill any efficiency benefits the twin engine config would render. Not to mention the increased fuel burn from the larger engines.
vikkyvik
Fri Sep 20, 2013 3:08 pm
Indeed. It can see strange, but you get a lot more drag from a shut down engine than from a running engine.
And, take any random tri-jet. Say you have 150,000 lbs total thrust, split among the 3 engines. If one engine is "emergency-only", you now only have 100,000 lbs total thrust, excepting an emergency. So you now need more powerful engines on the wings, which will likely be larger and heavier. So not only are you carrying around a spare third engine plus its associated drag, you're carrying two heavier primary engines.
Basically, you'd be hemorrhaging money at the end of the day.
Tristarsteve
Fri Sep 20, 2013 3:24 pm
Before the B777-300ER was invented, there was a proposal from Boeing for a B777 with a much larger take off engine in the APU position. This would be the APU, but provide thrust for take off only. I remember an article in Flight Global about it.
And then lets not forget the HS Trident 3B. This was a tri-jet with three Spey engines, but also had a tke off only Boost engine fitted in the tail above the Nbr 2 engine. This engine was switched on during taxy out, then ran up to take off when the main engine throttles were advanced. It was made mostly of fibreglass, had a total loss oil system. made really loud noise, but worked most of the time!
bohica
Fri Sep 20, 2013 5:40 pm
Quoting United1689 (Reply 4):
One word: Weight
I don't have the exact numbers but the weight of an MD-11 engine is well over 10,000 pounds. Carrying that engine around as a spare means 10,000 pounds of lost payload.
If the average weight of each passenger is 200 pounds, that means a loss of 50 passengers, a huge loss of revenue.
Then we get into the issue of drag, extra fuel, etc, etc, etc. It ain't gonna fly.
katanapilot
Fri Sep 20, 2013 6:42 pm
Awesome answers, thanks everyone!!
Viscount724
Sat Sep 21, 2013 10:16 pm
Quoting TristarSteve (Reply 6):
Rolls-Royce RB162-86, the Trident 3B's booster engine.
Photo © Paul Markman
http://www.bredow-web.de/Triebwerke_und_Flugzeugmotore/Rolls-Royce_RB_162/Rolls-Royce_RB_162.jpg
YQBexYHZBGM
Sat Sep 21, 2013 11:21 pm
Interesting, I knew nothing about the takeoff boost engine on the Trident 3 -- I guess it wasn't as close to the 727 in weight and performance as I thought. What other trivia or interesting tidbits regarding differences between the two types are you aware of?
Al
Kuja
Sun Sep 22, 2013 12:02 am
Quoting YQBexYHZBGM (Reply 10):
The Trident was similar in original conceptual role to the 727, I think. However, due to the BEA's demands, HS fitted it with comparatively small Rolls-Royce Spey engines which left it quite underpowered (indeed it was known by its crews as the 'ground gripper') and necessitating the fourth booster engine for the Trident 3.
(Of course, BEA then turned around and said that the Trident was underpowered and that they wanted the 727, but it seems the government told them they had made their bed and now they had to lie in it.)
Like the 727, the Trident was designed for high speed, but as far as I can tell, did not share the 727's short field performance. The Trident did have fascinating landing gear, though. Offset nose gear that retracted sideways and quad wheel but single axle main gear that rotated 90-degrees to retract.
See this video for a brief demo.
prebennorholm
Sun Sep 22, 2013 1:23 am
When British Dan Air many years ago operated a substantial fleet of Comets, then they found out that when they had to shut down an engine, then they actually burned slightly less fuel when continuing high altitude cruise on three engines.
That was of course an entirely different ball game compared to modern high bypass ratio fan engines since those RR Avon engines had a very small frontal area causing a lot less drag. Also turbojet engines generally lose less power at altitude than fan engines do. The remaining three engines were actually slightly more fuel efficient when operating at the somewhat higher power setting needed.
It also helped that the Comet had a very slow cruise speed.
Dan Air proposed to make it SOP to shut down one engine during cruise to save a little fuel. The authorities, however, didn't approve it, likely because in case of one more (unscheduled) shut down they would lose too much redundancies on electric, hydraulic and/or pheumatic systems.
But the military Comet, the Nimrod, skimmed the North Atlantic at low altitude and low speed for Russian submarines for decades during the Cold War, always with two of its four RR Spey engined shut down. They only used all four engines for climb and high altitude cruise. It extended the available loiter time considerably.
But for modern airliners cruising at Mach 0.8 or faster with large fan engines it doesn't work at all. The windmilling fan would have tip speed well into supersonic causing a horrendous supersonic and transsonic drag. Losing an engine means descending to lower altitude and slowing down in order to fight the drag penalty, and even then the fuel flown goes steeply north.
Sun Sep 22, 2013 1:38 am
The offset and sideways retracting nose gear mentioned by Kuja comes to mind. This meant more space for the forward cargo hold.
Photo © Alex Pan
Apparently the main gear rotated through 90 degrees during the retraction cycle.
YQBexYHZBGM
Sun Sep 22, 2013 3:32 am
Quoting Kuja (Reply 11):
Also interesting. I know the Spey was small, since it was used on the BAC 1-11 and Fokker F28, which are both quite small when compared with the Trident Three. But, I would have thought that three Spey engines with larger intakes would have been enough for the Trident. Guess not!
I had no idea about the offset landing gear either. I can't even imagine a crosswind landing -- crabbing without wing scrapes must have been a very touchy operation with a setup like that.
Al
Sun Sep 22, 2013 3:37 am
Quoting YQBexYHZBGM (Reply 14):
I don't see how it would have made a big difference. By the time the nose gear touches down you should be going straight. Besides, it is only barely off centerline.
Tristarsteve
Sun Sep 22, 2013 9:53 am
The Trident was designed for autoland. The designers were so sure of themselves that they were worried about the nose wheels running over the centreline lights on the runway, This drove them to fit the nosegear offset to avoid the drumming as it hit the lights.
The boost engine was not used on every departure, just the long distance, high weight flights. This was its problem. The aircraft might spend a week on short range shuttle flights, and then go off to Athens. The boost engine was not started until after the aircraft was taxying, (It was soooo noisy), and then it didn't start and the aircraft had to return to the gate.
CALTECH
Sun Sep 22, 2013 1:32 pm
The tri jets did have the most efficient engines installed. Compare the DC-10/L1011 to the A-300 B4 and see what a third engine could get you.
For your on-demand emergency engine in a tri-jet, the closest thing would be the FedEx 727s after re-engining. The number 2 engine was supposedly left at idle during flight while number 1 and 3 engines did most of the work. On the other hand, UPS re-engined their 727s with Rolls-Royce Tays in all 3 positions.
The gun is a precious Symbol of Freedom
Criminals are the deadly cancer on American society
Those who believe otherwise are consumed by an ideology
That is impervious to evidence of tyrants who disarm their citizens
113312
Mon Sep 23, 2013 3:54 pm
You are assuming that there were more efficient engines available at the time. There were not. The CF-6, original RB211 and the JT-9D were the most efficient engines available at the time the DC-10 and L-1011 were developed.
Max Q
Tue Sep 24, 2013 1:02 am
Quoting CALTECH (Reply 17):
That is not correct, all three engines were used normally.
YQBexYHZBGM
Tue Sep 24, 2013 2:35 am
I've read so many accounts of the 727s being withdrawn from most fleets due to the difficulty of replacing the JT8D with more efficient and less noisy engines, particularly the S-ducted #2 engine. How did UPS manage it, then? Why didn't others follow suit -- just not economical?
Al
Max Q
Tue Sep 24, 2013 6:54 am
Quoting YQBexYHZBGM (Reply 20):
Well, UPS only re-engined their lower powered -100's with the Rolls Royce Tay engine.
Even so that required an enlarged inlet lip on the #2 engine, a bit like the MD11.
Other operators re-engined their -200's though, like Fed Ex who installed the Valsan conversion, fitting JT8D 217's or 219's on the #1 and #3 position and retaining the same engine but removing the reverser on the centre #2 powerplant.
CALTECH
Thu Sep 26, 2013 1:11 am
Quoting Max Q (Reply 19):
That is why I wrote 'supposedly.' Might be mixing it up with the Valsan Super 27 project that rermoved the #2 T/R, which wasn't needed anymore during landing and lessened the noise footprint. Thought it was written that the number two on the Valsan 727 engine mods was able to be left at a lower thrust than #1 and #3 engines because of the extra thrust, which increased thrust and performance.
http://www.freepatentsonline.com/4836469.pdf
'An airplane equipped with the system requires a runway at least about 17% shorter for takeoff, if the center engine is operated at full power."
Just not economical. Re-engine some old frames or buy newer ones ? Two engined 737/757s were coming into their own.
UPS re-engined all of their 727-100s, 50 of them ?, with the R&R Tays.
FedEx did a hush kit first with all 3 of the original JT8Ds for most of their 727s.
http://www.fedex.com/us/hushkit/helpdecide/index.html
It would be the last 15 727-200F Advanced that received the Valsan mod, not sure exactly how many did. Continental Airlines was supposed to do the Valsan retrofit also.
Max Q
Thu Sep 26, 2013 2:23 am
Quoting CALTECH (Reply 22):
That was never done.
CALTECH
Thu Sep 26, 2013 4:12 pm
Quoting Max Q (Reply 23):
That is incorrect. It sure was. Continental was looking at the re-engining program.
http://www.flightglobal.com/FlightPDFArchive/1988/1988%20-%202089.PDF
"13 August 1988
The second re-engined 727 is for Continental Airlines and is scheduled to be complete with new Pratt & Whitney JT8D-200s in October, entering service on November 1, Johnson says."
Just like people not believing a Continental Airlines DC-10 flew with winglets.
Max Q
Sat Sep 28, 2013 8:08 am
Quoting CALTECH (Reply 24):
"13 August 1988
Fascinating, you get your information from an Aviation magazine who derived theirs from a program that, obviously
never came to fruition.
I know, I was there, actually flying the B727 for over seven years at Continental and until it retired CALTECH and I know, beyond a shadow of a doubt we never re-engined that Aircraft. They looked at a lot of things but that's a lot different than carrying them out.
As I said, it was never done, you assume a lot from a magazine article and might want to check your sources next time.
Wadrs.
kenanc
Mon Sep 30, 2013 11:15 pm
Question: In trijets such as the L1011, the engine mounted on the tail doesnt have anywhere for the thrust to output? Where does it go? In others like the MD-11 or DC-10, though, its just like a regular engine mounted on the wing.
Kuja
Mon Sep 30, 2013 11:44 pm
Quoting KenanC (Reply 28):
The type of arrangement you refer to is known as an S-duct, and as far as I know is used on all trijets apart from the DC-10 and MD-11. The DC-10 and MD-11 used a 'straight through' design, which is less complicated but also less aerodynamic.
The S-duct places the engine in the tail of the aircraft, with the intake on top of the fuselage being connected to the front of the engine with an 'S' shaped duct. The thrust from the centre engine (the No.2 engine) therefore is projected from the tail of the aircraft. Images usually help explain this, so here is a diagram of the L-1011 centre engine and a photograph showing the centre engine from behind.
Photo © Szabo Gabor
For more detail, look up a technical breakdown of trijets or see https://en.wikipedia.org/wiki/S-duct
LH707330
Wed Oct 02, 2013 6:49 pm
Ok, the net/net of Caltech and Max Q's discussion is that CO 727s never had the Valsan retrofit, though there were plans that never materialized, and everyone is now on the same page about that, so let's move on.
Quoting Kuja (Reply 29):
I read the article on the S-duct, what are the reasons for the reduced drag? I imagine there's less parasitic drag because the engine is in with the fuselage instead of sticking through the fin. Did the L-1011 actually have better burn numbers overall relative to the DC-10?
[Edited 2013-10-02 23:25:05 by SA7700]
Kuja
Wed Oct 02, 2013 11:03 pm
Quoting LH707330 (Reply 32):
I will compare the two designs, although firstly, a disclaimer - I am not an aerodynamicist, so my understanding of this is limited to what I have heard from others and from technical sources. I am sure that some of our best users can give a clearer explanation than I.
In a paragraph, the benefits of the S-duct configuration are reduced drag, improved stability, lower weight and easier access to the engine for maintenance. The benefits of the straight-through configuration are simplicity of design, lower cost of construction and no loss of engine performance due the lack an angled intake (although the last point can be negated by the use of a shallow curve on the S-duct configuration, as used on the TriStar).
In more detail, some of the benefits of an S-duct over the straight-through configuration are as follow:
The S-duct configuration is lighter than the straight-through configuration, I believe due to combined effect of the weight of the extra structural reinforcement required in the latter's case to hold the engine partway up the tailfin and the extra size of the vertical stabiliser required due to the No.2 engine's placement (explained in the third point).
The S-duct configuration is more aerodynamically efficient, due to the drag that comes from the engine being stuck through the tailfin in the straight-through configuration as opposed to being integrated into the fuselage. Furthermore, the exhaust from the No.2 engine in an S-duct configuration combined with the design of the tail section induce a laminar flow with virtually no parasitic drag. I am not sure of the precise efficiency gain, but it is very noticeable.
The S-duct configuration allows for a more effective rudder in relation to the height of the tailfin than the straight-through configuration, as the rudder is closer to the longitudinal axis. In essence, the S-duct configuration allows for the full height of the trailing edge of the tailfin to be used for the rudder, whereas the straight-through configuration only allows the portion of the trailing edge not interrupted by the No.2 engine to be used for the rudder.
To demonstrate the final point, compare the relative size of the rudder on the L-1011 and on the DC-10 / MD-11. I have used the schematics of the L-1011 and DC-10 from Wikipedia to create a comparison with the rudders highlighted in red.
This is why the L-1011 has a very effective rudder whilst the DC-10 and particularly the MD-11, despite having a double-hinged rudder to try to compensate, have issues there.
As for fuel burn on the L-1011 versus the DC-10, I don't have the figures for that. As far as I know, the L-1011 was more efficient than the DC-10 mission for mission, but I am just going by what I have heard. I do know that the RB211-524B4 engines used in the L-1011-200, -250 and -500 had ~15% lower fuel burn than the RB211-22B engines used in the earlier models. Of course, the L-1011-500 was compromised in terms of efficiency due to the fact that it was a shrink.
ferpe
Fri Oct 04, 2013 7:17 pm
Well made, now Douglas were no pushovers and no dummies. Their reasons for their somewhat unusual design must have been well documented and argued at the time, anyone who knows their party line?
Non French in France
Flighty
Fri Oct 04, 2013 11:33 pm
As a Concorde and Soyuz captain of many years ('supposedly'  ) my colleague on B744 showed the 747 burns more fuel on 3 engines versus 4. Recall the BA LAX-LHR fuel emergency several years ago. That proved the point quite well (at least for big turbofans).
United1689
Fri Oct 04, 2013 11:56 pm
Quoting Flighty (Reply 31):
As a Concorde and Soyuz captain of many years ('supposedly' &nbsp  my colleague on B744 showed the 747 burns more fuel on 3 engines versus 4. Recall the BA LAX-LHR fuel emergency several years ago. That proved the point quite well (at least for big turbofans).
Interesting, and hardly surprising. The dead weight, added drag, and increased thrust (and likewise fuel burn) from the remaining three engines would surely cause a higher fuel consumption.
United1689
CALTECH
Sat Oct 12, 2013 2:24 pm
Looking at that, I can believe that, supposedly.   Long ago, had to put a # 3 engine inlet cover on a 727-200, for a ferry flight back to Denver from Kansas City. Empty she was okay for takeoff, but burned a lot of fuel flying back to Denver flying on just 2 engines. Had them at a higher thrust setting than normal. The 727 burned more fuel on 2 than 3 engines.
And on the B-52s, when we lost a engine or 2, fuel burn went up a noticeable bit.
Users browsing this forum: Google [Bot] and 34 guests
