JAAlbert
What Is The New 787-9 Drag Reducing Technology?
Mon Oct 14, 2013 10:51 pm
I watched a Boeing video on the 787-9 recently and the engineer interviewed stated that they had to find a way to reduce drag on the 787-9. Their first attempt failed, but by "leveraging a number of different disciplines" and "bringing together the best and the brightest," Boeing was able to reduce the aerodynamic drag of the 787-9. Of course this little video is just a marketing tool and doesn't provide any actual information, but it got me wondering:
1. Why is drag a bigger problem on the 787-9 vs. the 787-8?
2. Is the increased drag related to something other than the increased size of the plane?
3. What specific technologies was Boeing able to "leverage" to reduce the drag and any information by how much they were able to reduce drag? (I suppose that info is proprietary, but I might as well ask!)
4. If drag is an issue with the larger 787-9, what kind of challenges will Boeing face with the larger still 787-10 and how will they solve that problem?
Here's a link to the video - go about midway down the page to the right and click on the 787-9 Innovations link: http://www.newairplane.com/787/787-9/?v=2
Stitch
RE: What Is The New 787-9 Drag Reducing Technology?
Mon Oct 14, 2013 11:23 pm
Boeing is implementing passive hybrid laminar flow control into the vertical stabilizer of the 787-9. This is being done to reduce stabilizer drag by upwards of 1%, which reduces fuel consumption. It is being implemented on the 787-9 because Boeing manufactures the vertical stabilizer for this model (Alenia Aeronautica builds the one used on the 787-8). I expect HLFC will also be used on the 787-10 vertical stabilizer.
Both the 787-8 and 787-9 employ natural laminar flow on the engine nacelles.
Guy Norris had a nice write-up about it in Aviation Week.
[Edited 2013-10-14 16:24:52]
Mon Oct 14, 2013 11:50 pm
Quoting JAAlbert (Thread starter):
Increased area means increased skin friction drag.
Increased weight means increases induced drag. Given the same wing, for a higher weight the angle of attack will be higher since the wing needs to generate more lift. More lift gives more induced drag.
JAAlbert
Tue Oct 15, 2013 3:48 am
Quoting Stitch (Reply 1):
Thanks for the insight. I reviewed the Aviation Week article. As I understand it, the vertical (and perhaps horizontal) stabilizers will have tiny holes on the leading edge that will suck air into the stabilizer and out an exit. The system is entirely passive. So now my questions is, isn't there a danger that these small holes can become plugged up with ice during certain flights? Much like the AF flight's pitot tubes that froze over? I don't suppose clogged intakes would interfere with the plane's ability to fly, but if they became clogged, it would cancel out the benefit of the system. Thoughts?
Tue Oct 15, 2013 4:30 am
Quoting JAAlbert (Reply 3):
They could become clogged, but all you'd get is some extra drag. Also I'm assuming these holes would be quite a bit larger than a pilot tube, so less risk of icing.
musang
Tue Oct 15, 2013 10:57 am
Quoting Starlionblue (Reply 4):
Co-incidentally I was talking to a Boeing sales manager about this a few days ago. The holes are like pin-pricks.
Regards - musang
jetmech
Tue Oct 15, 2013 1:25 pm
This appears to be the patent for the system;
http://www.google.co.in/patents/US7866609
Regards, JetMech
Tue Oct 15, 2013 1:47 pm
Quoting musang (Reply 5):
Cool! Seems to be related to laminar flow control on the Buccaneer and such. This system is passive though.
GAIsweetGAI
Wed Oct 16, 2013 2:13 am
I recall reading about some research Dassault had done about laminar flow - although I really don't recall where. One of the notable findings was that even with a significant fraction of the pores in the airfoil surface clogged by insects, dirt, etc., the drag of the wing was still lower than if a classic "smooth" airfoil had been used.
Does this sound familiar to anyone?
"There is an art, or rather a knack to flying. The knack lies in learning how to throw yourself at the ground and miss."
dynamicsguy
Wed Oct 16, 2013 9:33 am
I know in discussions around the weight of the -9 during development it was stated that if it didn't hit a particular benchmark for performance then it would potentially lose half its market, so it make sense that they would also need to pull out all stops for drag. As well as keeping weight down, we made some small aerodynamic tweaks to our parts.
I'm actually not entirely sure the aerodynamic advance referred to in the video is the hybrid laminar flow control. If that was it, then why wouldn't they refer to the horizontal stabiliser in the video? The script seems to have been deliberately written to say nothing. It could be the HLFC ("deemed impractical for the past 30 years") but it could be something else.
nomadd22
Wed Oct 16, 2013 11:32 am
It's not "A bigger problem" They're just making a lot of improvements on the -9 now that they have all the data and knowledge from manufacturing the -8. Most of those improvements will be rolled back into the -8 eventually.
Anon
