RyDawg82
Southwest Airlines 737 With LED Strobes
Thu Oct 17, 2013 4:05 pm
Last night I saw a Southwest 737 fly over on approach to KDAL and the standard white wingtip strobes had been exchanged for white LED wingtip strobes. The red anti-colision and white tail strobes were still standard issue.
Does anyone have information about this modification? Will it be a conversion available on all 737s? Are there plans to changes the remaining strobes over to LED at some point?
Ryan
barney captain
RE: Southwest Airlines 737 With LED Strobes
Sat Oct 19, 2013 12:58 am
I'm unaware of any LED strobe installations on our a/c - but that certainly doesn't mean it's not happening. Did you happen to notice if it was a -300 or a -7/800? I've seen a few JetBlue 320's with the new winglets that also incorporated the LED strobes as you've described.
Southeast Of Disorder
RyDawg82
Sat Oct 19, 2013 3:40 am
Quoting barney captain (Reply 1):
I believe it was a -700 on account the strobe was from the root of the winglet versus up high like on the -300s.
Ryan
barney captain
Sat Oct 19, 2013 7:00 am
Quoting RyDawg82 (Reply 2):
Wow, great observation. I suspected it would have been on a classic, but as you pointed out, the strobe would have been higher on the winglet. I will be in Dallas over the weekend for training, let me see if I can find out anything.
fghtngsiouxatc
Mon Oct 21, 2013 5:42 am
I saw a WN 738 with LED strobes the other day while working at MDW. Must have been a brand spanking new delivery. I've only seen the one, and haven't seen another since. Oddly enough, the LEDs are only on the wingtip strobes, with a conventional strobe on the tail.
Okie
Mon Oct 21, 2013 3:57 pm
Quoting fghtngsiouxatc (Reply 4):
I guess my question would be does that tail strobe have an LED light source with a conventional globe/lens?
Okie
RyDawg82
Mon Oct 21, 2013 5:22 pm
The 747-8 also has LED wingtip strobes, while the tail strobe is a conventional strobe.
Ryan
cargolex
Thu Oct 24, 2013 5:01 pm
Quoting RyDawg82 (Thread starter):
I do not know about conversion (though I would imagine that conversion is not a particularly difficult thing to do), but new 737s began rolling off the line with LEDs on the wings over the summer.
I first noticed it while I was photographing this guy:
Photo © A. Kwanten
QANTAS747-438
Sat Oct 26, 2013 3:36 am
Yes, new build -800s for WN have the LEDs. Saw one recently on N8617 or 8618 maybe.
DocLightning
Sat Oct 26, 2013 7:26 pm
It does make a lot of sense. LEDs at the 5,000-6,000K color temperature seem easier to see than the lower color temperature of standard lights and strobes. And LEDs can be made to fade in/fade out, blink on and off, or strobe. Their "on/off" times are essentially instantaneous (you can cycle them at hundreds or thousands of Hz if you like). Also, they age by total time powered up, but by number of times powered up. And, honestly, once the LED is installed, a given airline might have to replace it once during the entire lifetime of the aircraft. They're an especially good choice for the exterior of aircraft because they perform well even at very low temperatures.
The big issue is that, while they're easy enough to replace for bulbs in your house, it might not be so simple in an airplane or a car. A LED's electrical behavior is different from standard bulbs/strobes and some vehicular electrical systems are finicky enough that a simple swap-out isn't possible.
Quoting rydawg82 (Reply 6):
I wonder why they went that way.
-Doc Lightning-
-Carl Sagan
baqnav
Sat Oct 26, 2013 7:57 pm
N8617E, just flew her from MDW-BWI-TPA on Thursday. The wing is full LEDs (position and strobe). Looks sharp and much brighter.
[Edited 2013-10-26 13:03:01]
My opions are mine, not my employers
fghtngsiouxatc
Sun Oct 27, 2013 4:44 am
I saw another WN 738 with LEDs at MDW yesterday. The left strobe was either burnt out or inop. The right side worked and the (conventional) tail strobe worked, but the left one didn't blink. Looks like they're still working out some kinks...
Sun Oct 27, 2013 8:54 am
Longer lasting and no need to replace the LEDs in service are def an advantage in terms of cost saving.
Anyone having a video link of how these LED strobes actually look like while functioning.
barney captain
Sun Oct 27, 2013 10:39 pm
Interesting news. Does anyone know why the tail strobe is still conventional?
SPREE34
Thu Oct 31, 2013 8:11 pm
Quoting Barney Captain (Reply 13):
Wondered about that myself. It's the same way on the Airbus versions with sharklets, as well as the B748.
I don't understand everything I don't know about this.
Okie
Fri Nov 01, 2013 3:10 am
Off hand I would say no real regulatory requirement but may require an approval before use.
My guess is that they are going to use up current stock of units before switching to the LED's. What would you do with say a hundred conventional assemblies when the replacement unit is eventually going to be LED's
Okie
shamrock137
Fri Nov 01, 2013 3:36 am
Most likely because an LED tail strobe assembly would require additional certification. Both Boeing and Airbus were able to certify the wing lights as part of the winglet certification, while to change the tail would require an additional separate certification = more money.
Time to spare? Go by air!
barney captain
Fri Nov 01, 2013 9:11 am
Quoting shamrock137 (Reply 16):
Maybe. But this:
"The 747-8 also has LED wingtip strobes, while the tail strobe is a conventional strobe."
Makes me think there's more to it. Why would a newly certified aircraft also have this configuration?
tjwgrr
Fri Nov 01, 2013 4:48 pm
Quoting HAWK21M (Reply 12):
748:
http://www.youtube.com/watch?v=roMydUSoIgs
788:
http://www.youtube.com/watch?v=1d4viIVhJBM
For some reason the strobes on the WN 738 look more like conventional ones and not LED:
http://www.youtube.com/watch?v=OuiozR9_9oE
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
barney captain
Fri Nov 01, 2013 5:04 pm
Quoting tjwgrr (Reply 18):
I believe those are conventional strobes. Someone mentioned it was just the last few -800's delivered that had the LED's.
hotplane
Tue Nov 05, 2013 10:56 pm
El Al -900s also have 787-style strobes. Anti col light standard though.
barney captain
Thu Nov 07, 2013 7:31 pm
They're definitely out there - well, at least one. I caught a glimpse last night of a SWA (I assume -800) landing in SAN with the LED strobes.
DocLightning
Sun Nov 10, 2013 12:34 am
Are all exterior lights on the 787 LED or are the spotlights something else?
-Doc Lightning-
-Carl Sagan
NOLAWildcat
Sun Nov 10, 2013 4:59 am
At the risk of moving slightly off-topic, does anyone know if United has installed LED strobes on some of their older aircraft? I was driving down 101 towards SFO last week and observed what looked like a 767 or 757 (definitely not a new delivery 737 or 787 as it was in United's old Blue scheme) with the new LED wingtip strobes.
skyhawkmatthew
Sun Nov 10, 2013 7:06 am
Quoting DocLightning (Reply 22):
Strobes, beacon, position lights are LED; landing, taxi, inspection, etc spotlights are HID Xenons.
Qantas - The Spirit of Australia.
Thu Nov 14, 2013 3:02 pm
Thanks Interesting video esp the B787.
united319
Sun Nov 17, 2013 4:31 am
I flew on a brand new UA739ER this week LAX-MSY and it was the 250th next-gen for United as well. It had the LED strobes. The beacon lights were normal with other 737's.
It's Time To Fly
Max Q
Sun Nov 17, 2013 8:53 am
Seriously, this has to be one of the nerdiest post's..
Even for A. net, and yes, I am guiltier than most
yeelep
Sat Nov 23, 2013 5:12 pm
Alaska also has led wingtip strobes on its latest 900ER's. N431AS, N433AS, N435AS, N440AS.
[Edited 2013-11-23 09:16:18]
Users browsing this forum: Dalmd88 and 3 guests
