musang
Engine Ice Ingestion
Mon Nov 04, 2013 6:09 pm
If a CFM56 or any bypass engine for that matter, is operated in icing conditions without the engine anti-ice selected on, in flight, at idle/low speeds, when the ice lets go does it all get flung out centrifugally and go out the bypass duct? How much if any goes through the core?
How about at higher thrust settings?
Thanks - Regards - musang
VC-10
RE: Engine Ice Ingestion
Sat Nov 09, 2013 12:35 pm
On the A346/Trent 500 combination there is an ECAM warning 'ENG STATOR ICEING RISK' if the engine has been operating in iceing conditions at low power for 10 minutes. From a maintenace POV if this appears in the log book we have to boroscope the engine before next flight
akiss20
Sat Nov 09, 2013 5:39 pm
Quoting musang (Thread starter):
Almost all fan ice shedding gets centrifuged out through bypass. The FGV ice also obviously goes through bypass. The IGV ice goes through the core and the splitter lip ice can go either way depending on the thrust level and thus the core streamtube capture area.
Change will not come if we wait for some other person or some other time. We are the ones we've been waiting for. We are
Users browsing this forum: LH707330, Max Q, TailDragging and 1 guest
