ptahturan88
Fuel Exp Per ASK Vs Stage Length
Tue Nov 05, 2013 1:18 pm
Hi guys,
I was graphing fuel exp per ASK (y-axis) vs avg kilometers flown (x-axis) for both PGSUS AND THY. There's a strong negative correlation for PGSUS whereas a strong positive correlation for THY. What does that tell? Is it about being a LCC?
I thought the usual one is a negative correlation.
What do you think? Thanks in advance.
andrej
RE: Fuel Exp Per ASK Vs Stage Length
Tue Nov 05, 2013 4:20 pm
Try comparing other LCC (vs. PGSUS) and legacy (vs. THY). IMHO looking at two different airlines will not give you proper output (value-added).
Quoting ptahturan88 (Thread starter):
Why should the fuel expense decline with increased avg. km flown fuel?
I would also look at ASKM/RSKM vs. Fuel Exp. ASK (does/what is the relationship between the fuel expense increases vs. (increased) ASKM and RSKM).
Andrej
mandala499
Wed Nov 06, 2013 5:25 am
OK, what aircraft ? 737NGs I assume?
It does have to do with:
1. Their speed/cost index policy
2. Their 1st choice altitude policy
3. Payloads
4. Holding & Alternate policy
That, gives you the fuel burn in kg/km...
Now, then we go to:
5. Where and who do they buy fuel from? (vendor pricing policy)
6. Do they conduct tankering (this reflects on effects of #3 and #4)
(and the list goes on)
If this is not aircraft type specific, THY's diverse fleet would give that positive correlation instead of a negative one, as with widebodies, the difference in fuel burn per hour changes a lot throughout the whole flyable grossweight change... etc etc etc...
Users browsing this forum: alomar, Bing [Bot], David L and 2 guests
