LH707330
Why The Gap In The 367-80B Core Duct?
Wed Nov 06, 2013 9:49 pm
I noticed the other day that the 367-80B has a gap in the core duct that is not in the production 707s, does anybody know why this is? I would think the aerodynamics of the former would be unfavorable.
Photo © Mark Carlisle
Photo © Petr Popelar
Viscount724
RE: Why The Gap In The 367-80B Core Duct?
Thu Nov 07, 2013 1:18 am
Isn't that just the rear part of the thrust reverser in the deployed position?
Photo © Marlene Leutgeb
jetmech
Thu Nov 07, 2013 3:31 am
Quoting LH707330 (Thread starter):
I suspect it may have something to do with attempts at reducing noise. When a jet of fluid is issued into another, quiescent (still) body of fluid, the turbulence and shearing produces much vibration of the fluid body, which results in the generation of much noise. Increasing the relative speed of the jet, results in more emitted noise.
The gaps in the core allow the hot exhaust gasses exiting from the last turbine stage to induce cold, slower moving ambient fluid into the exhaust jet. The two streams will mix to some extent inside the exhaust cone, and thus, a cooler, slower jet of fluid will be issued from the exhaust cone outlet. The end result is less shearing and turbulence, and thus, less emitted noise.
The multitube / cookie-cutter exhaust of RR Conway powered 707's reduced noise by using the numerous tubes / convolutions to increse the shear area of the exhaust jet, which again, promoted more rapid mixing with the freestream. In this case, most of the mixing took place outside the engine.
http://www.adastron.com/707/gallery/vh-ebg-2.jpg
Photo © Gary Vincent
Photo © Steve Fitzgerald
The cookie-cutter nozzle is still used on some modern engines such as the RB211-524G2.
Photo © JPC van Heijst - AirTeamImages
Photo © Wenzai
Regards, JetMech
[Edited 2013-11-06 20:14:02]
boeingfixer
Thu Nov 07, 2013 4:08 pm
Quoting Viscount724 (Reply 1):
It is indeed the core thrust reverser cascades you see there. The T/R's on the JT3D have gone through many different configurations and this was just a style without the translating cowl at the aft of the engine. Another thing to consider is the fact the Dash 80 was a development airframe and had of lot of non-standard items on it compared to production 707's and 720's.
John
Cheers, John YYC
LH707330
Thu Nov 07, 2013 6:30 pm
Quoting boeingfixer (Reply 3):
I found a few more where the plane is either flying or taxiing, in this one at left it would look like a highly unsafe maneuver if it is indeed a deployed T/R:
Photo © Royal S King
Quoting jetmech (Reply 2):
If this is the case, it must have been some experimental design. IIRC, N70700 was retired around 1980, before the 707 hush-kit party got going, and I doubt that the test team was concerned about noise before that, unless this was some experiment to meet upcoming noise regs. The three 707 hush kit designs I'm aware of are 1) an extended bypass duct, 2) an integrated mixer design, or a 3) lengthened duct and intake, but I've never seen the gap in the core duct:
Photo © Tim Wagenknecht
Photo © Szabo Gabor
Photo © Capture A Second Photography
boeingfixer
Thu Nov 07, 2013 7:36 pm
Quoting LH707330 (Reply 4):
The T/R isn't deployed. It's only the cascades you see which are always in view with that configuration of nacelle. The blocker doors(Clamshells) are in the core exhaust gas path and can be seen stowed in the following pic of the same engine.
http://www.flickr.com/photos/chrisst...3075730507/sizes/l/in/photostream/
That's not a gap but just the exposed cascade vanes. Looks to me like the translating portion of the aft nacelle has been disabled and the section covering the cascades was modified to expose the cascades.
Exposed cascade vanes are nothing new. The 727 had them as well as early 737-100's. Other aircraft that also had this feature were the Vickers VC10 and the Il-62.
John
Cheers, John YYC
LH707330
Thu Nov 07, 2013 8:08 pm
Quoting boeingfixer (Reply 5):
This explanation makes sense, thanks.
Maybe they modded this to test the layout for the 727s. I found a few old gray photos from the early/mid 1960s with this layout, so it's nothing new.
kanban
Fri Nov 08, 2013 2:23 am
Then again, it may just be a museum display setting to show more of the engine.
jetmech
Fri Nov 08, 2013 6:23 am
Apparently, there was a fair bit of design work carried out on the J57 exhaust which I believe was in relation to the 367-80 and DC-8. The photos below show a variety of jet pipe modifications that were tested in the wind tunnel.
http://grcimagenet.grc.nasa.gov/shar...ons&maxcnumber=44496&maxcyear=1957
The combined cookie-cutter / gapped (ejector) nozzle design seems to have been an approach used on the DC-8 and some of the retro-fitted hush kits seen today.
Regards, JetMech
boeingfixer
Fri Nov 08, 2013 8:50 pm
Quoting kanban (Reply 7):
Pretty positive it's not. As seen in the following photo the reverser cascades are normally exposed.
This really looks like a one-off installation which was very common on the Dash-80.
Quoting jetmech (Reply 8):
I would surmise that these tests are for the C-135 and not for commercial 707's or DC-8's as the engines are J57's and not JT3C's. I know that they are essentially the same engine but there are subtle differences due to civil certification of the JT3C.
The 737-200 hush kit from Nordam also had a slotted ejector. It was a tremendously heavy hush kit and not too many of them were sold compared to AvAero's installation.
Photo © Stefan Sydow
John
Cheers, John YYC
Users browsing this forum: LAE320 and 1 guest
