TS-IOR
Syphax Route TUN-YUL
Thu Nov 07, 2013 10:05 am
On Oct.23 Tunisia's Syphax Airlines flew a kind of promotional flight to Montreal, Canada on the occasion of an exhibition there and some 140 businessmen and journalists were on that flight.
http://fr24.com/2013-10-23/10:12/12x/SYA8330/20ee728
You can notice that the aircraft didn't follow a NAT route and approaching Iceland it descended from FL380 to FL280. What could be the reason for that ? Flights to Montreal on that day were all on NATs, so why Syphax A330 flew further north on a classic route and why descended ? Does it have to do with MNPS certification ? Or ETOPS ? Or else ? The retour from Montreal on Oct.27 also did the same route back through Greenland and Iceland.
Viscount724
RE: Syphax Route TUN-YUL
Thu Nov 07, 2013 11:28 pm
Quoting TS-IOR (Thread starter):
Probably lacked the necessary RVSM certification and was thus restricted to altitudes below FL290. I think that's the lower limit but I'm sureone more technical can advise in more detail.
The more northerly route was probably due to the lack of ETOPS certification.
[Edited 2013-11-07 15:30:37]
TS-IOR
Fri Nov 08, 2013 4:06 am
The aircraft is ex-Emirates and AFAIK all A330s are ETOPS 180 at least or 240 even.
LAXintl
Fri Nov 08, 2013 5:51 pm
Quoting TS-IOR (Reply 2):
Yes but what operational specs is Syphax licensed for ? Also crew trained for ?
TS-IOR
Sat Nov 09, 2013 1:32 am
After this flight and the flight back home, crew, 2 captains and 2 first officers, was granted an ETOPS/MNPS qualification. They were supervised by a TRI from Airbus. So maybe next flights will use a NAT and within MNPS +FL290 ?
JAGflyer
Tue Nov 12, 2013 8:52 pm
Is this airline operating or planning to operate to YUL on a regular basis? I doubt it considering Tunisair already tried YUL-TUN. YUL already has a significant presence from the Mehgreb (AT and Air Algerie)
If you flew today, thank a Flight Dispatcher!
Tue Nov 12, 2013 11:50 pm
ETOPS certification is more than the plane. The crew, the airline and the maintenance organization also need to be certified.
Users browsing this forum: Accidentally, boeing767322er, calt03 and 2 guests
