airforceone
White Light/Button On 777 Autopilot Panel
Fri Nov 08, 2013 3:56 am
Hello, I notice in the cockpit of the 777 there is white button/light located on the autopilot panel between the LNAV button and the HDG selector display. Im wondering what is its purpose/function?
N243NW
RE: White Light/Button On 777 Autopilot Panel
Fri Nov 08, 2013 4:17 am
According to this website:
http://www.meriweather.com/flightdeck/777/glare/mode.html#
"Cabin Light Sensor - This sensor checks the ambient light in the cockpit then adjusts all of the cabin display lights accordingly."
airforceone
Fri Nov 08, 2013 11:11 pm
Thank you for showing me the website. I was looking for something like this.
Natflyer
Sat Nov 09, 2013 3:29 am
Quoting N243NW (Reply 1):
"Cabin" light sensor? On the MCP? adjusting "cabin" lights?
I'll believe it when a 777 pilot confirms. Until in my mind it has to do with cockpit/lighting/displays.
N243NW
Sat Nov 09, 2013 5:21 am
Quoting Natflyer (Reply 3):
I think it was an error in translation. It is indeed for the flight deck lighting, not the passenger cabin. If the manual brightness control knobs for most instruments/panels are placed in the center position (indicated by a dot), a MASTER BRIGHTNESS knob will work in conjunction with the ambient light sensor to adjust almost all panels and displays.
LTC8K6
Sat Nov 09, 2013 5:33 am
It's an ambient light sensor.
Qantas744er
Mon Nov 11, 2013 11:50 pm
Straight from the B777 FCOM2
"Two remote light sensors, located left and right on the top of the glareshield, measure brightness in the forward field of view and adjust the overall display brightness as required. Individual sensors on the front of each display unit also affect display brightness. The CDUs, mode control panel displays, standby flight instruments, and aisle stand panel displays are also controlled by the automatic display brightness control system."
The light sensor you are referring to on the MCP (mode control panel) automatically adjusts the brightness of the various LCD windows on the MCP.
You live and you die, by the FMA
AA737-823
Tue Nov 12, 2013 8:11 am
Quoting N243NW (Reply 4):
Everyone seems to be nit picking... fact of the matter is, "cockpit" is an antiquated term, and Boeing most often uses "Control CABIN."
So yes, it's adjusting some of the lighting in the CABIN in which it's located.
Other models feature similar sensors spread throughout the control cabin. On the 737NG, for example, each DU has its own independent sensor. You can shine a flashlight at it and watch the display brighten.
airforceone
Tue Nov 12, 2013 8:38 am
This is pretty cool. I didn't know other planes had it. On the 737 I always though pilots themselves adjusted it.
wilco737
Tue Nov 12, 2013 2:33 pm
Quoting AirForceOne (Reply 8):
I just realised that the 747-8i has it as well. Never actually recognized it, until I saw this thread and was on board a 747-8i tonight
You basically don't need to touch the brightness controls for the screens anymore. They are adjusted automatically.
wilco737
7BOEING7
Tue Nov 12, 2013 11:02 pm
Quoting AA737-823 (Reply 7):
Don't know about that, all their ops manuals and panels say "Flight Deck".
Users browsing this forum: flipdewaf, GloomyDe and 24 guests
