united319
AA Why Different Engines On Airbus Fleet?
Sun Nov 17, 2013 4:14 am
Just noticed in the new photos that AA has different engines on their A319 & A321 fleets....
The A319 has CFM's and the A321 has IAE V2500's...doesn't seem to make sense for brand new aircraft. I would think they would want the same engine manufacturer on their aircraft. Can anyone shed light on this?
UAL
It's Time To Fly
RE: AA Why Different Engines On Airbus Fleet?
Sun Nov 17, 2013 4:31 am
Quoting united319 (Thread starter):
I'm thinking it makes sense.
- The two aircraft have very different weights and somewhat different missions, so methinks different engines might be optimal.
- Given the size of AA's fleet, arguments about economies of scale and commonality between models weaken somewhat. Sure, if you have 5x A319 + 8x A321 in total, commonality is a big thing. AA wil have 65x A319 + 65x A321. Quite enough to realize any economies of scale within one model.
- Having two manufacturers ensures competition.
- Given the volumes involved, delivery slots come into play. Perhaps one manufacturer couldn't provide all the desired engines in the desired timeframe.
SPREE34
Sun Nov 17, 2013 4:56 am
The CFM is better suited to shorter legs. The IAE is the better performer on longer legs, and and offers a higher thrust rating, so is the better engine for the 321. I believe Lufthansa if following the same logic. US Airways did as well after the merge with America West.
I don't understand everything I don't know about this.
Chaostheory
Sun Nov 17, 2013 6:07 pm
Quoting SPREE34 (Reply 2):
That's not true.
My airline needed the most powerful option for the A321 so they went for the CFM which puts out around 32Klb max compared to the 31.5Klb of the V2500.
Don't trust the numbers on the OEM websites as they're not very accurate.
Other reasons in favour of the IAE V2500 are that the fuel consumption is lower (around 2% on longer sectors) and oil consumption is also considerably less.
mhkansan
Mon Nov 18, 2013 5:12 am
Quoting ChaosTheory (Reply 3):
This. The IAE engine is a much better performer on longer routes than the CFM. AY did the same thing also.
deltal1011man
Mon Nov 18, 2013 7:02 am
This is also why AA picked CFM for the 319s.
CFM has a ~27K engine
IAE is (IIRC) ~24K
bluejuice
Mon Nov 18, 2013 6:55 pm
Does "Power by the Hour" also play into the equation? I am guessing when fuel was cheap and airlines were responsible for all engine ownership/maintenance/spare parts, the loss in efficiency was made up with a simpler technical operations. Nowadays it seems airlines want to squeeze out every fraction of a percent in operating efficiency. Having the manufacturer bear the cost of engines and maintenance means the airlines can lease the exact engine needed for a particular mission. Am I making a correct assumption?
LH707330
Mon Nov 18, 2013 10:46 pm
Quoting BlueJuice (Reply 6):
Could be, not sure how their contracts are set up here. The architecture of the two engines largely determines their optimality, the V2500 has two HPT stages while the CFM56 has one. This means lower mx costs for CFM, but better SFC for V2500. MX on HPT is largely a function of cycles (heating/cooling stress), whereas SFC benefit is a function of distance flown and becomes more important on longer sectors. Thus, the short runs favor CFM because there are fewer expensive parts to replace regularly, while longer sectors favor IAE because you have relatively more hours/cycle, which shifts the equation more to burn and away from mx.
roseflyer
Mon Nov 18, 2013 11:02 pm
That was my first thought. I suspect AA might be doing power by the hour. When your engine is power by the hour, you depend on the engine manufacturer for all your support. There's very little benefit to engine commonality because AA won't be doing much engine work in house. The only engine work that they'd be doing is the type that doesn't vary much depending on engine type.
Sancho99504
Fri Jan 24, 2014 9:58 pm
Quoting Deltal1011man (Reply 5):
The A319 comes available with the V2527M-A5 engines which produce 27k pounds of thrust, so that isn't an issues. The A319s will be used or short to medium stage lengths which are better suited for the CFM56-5B7 due to lower maintenance costs associated with the short haul environment wear and tear.
kill 'em all and let God sort 'em out-USMC
Users browsing this forum: Joshs1000 and 1 guest
