stevenmeyer2005
Flight Recorder Ping
Mon Mar 17, 2014 11:10 pm
Is it possible to turn the flight recorder off from the flight deck? For example by removing a fuse?
Does the flight recorder start pinging when an impact of the structure of the fuselage is detected?
Steven Meyer
RE: Flight Recorder Ping
Mon Mar 17, 2014 11:57 pm
Quoting stevenmeyer2005 (Thread starter):
Yes, and in some instances crew need to pull that to preserve the information on the recorder.
No, it does have an underwater locator that transmits low power for around a month minimum.
Tue Mar 18, 2014 9:18 am
Yes through a CB....but some aircraft can have a always on in air logic.
no thats the function of the Impact ELT ...however a water activated beacon [underwater locator beacon/ULB] will send a transmission.
Dalmd88
Tue Mar 18, 2014 7:48 pm
While the recoders might be able to be turned off, the pingers on the Data and Voice recorders can not be turned off from the flight deck. They each have their own dedicated battery. The pinger and the battery are about the size of a two cell "c" flash light mounted to the outside of the recorder. They get tested I think yearly with a life cycle of a few years. Can't recall the actual numbers.
Wed Mar 19, 2014 7:18 am
The ULB would have a stamped validity date on it....
Dalmd88
Thu Mar 20, 2014 12:07 am
Quoting hawk21m (Reply 4):
True, but I've changed a few well before that date when they fail the test.
Thu Apr 03, 2014 9:56 am
Quoting Dalmd88 (Reply 5):
True....but scheduled replacement would be based on the stamped date unless as you state a test found a fault warranting its replacement.
L-188
Sun Apr 06, 2014 2:29 am
Quoting zeke (Reply 1):
Important point.
Didn't that FedEx crew that had the company rider go nuts with the crash axe due that to preserve the recording of the attack?
jetblueguy22
Sun Apr 06, 2014 3:09 am
Quoting L-188 (Reply 7):
I think the attacker pulled the fuse prior to the crew getting onboard hoping that the event wouldn't be on tape. The F/E caught it and I think they got it all. Though it has been a while since I read all of this.
Pat
Look at sweatpants guy. This is a 90 million dollar aircraft, not a Tallahassee strip club
Tue Apr 08, 2014 9:52 am
Quoting jetblueguy22 (Reply 8):
That was the CVR CB.
Users browsing this forum: sunrisevalley and 1 guest
