ConcordeAlpha
PMDG 747 vs 777 - What one to get?
Sat Aug 19, 2017 11:56 pm
Hi all,
I am a 'flight simmer', and I have been flying the PMDG 737 NGX for a while now. I am wanting to move on to the heavies, such as the PMDG 747 or the 777. I am wondering which one I should buy as they are kind of expensive (buying them for P3D), and which one is higher quality / better on performance, or simply which one would be a good aircraft to start flying heavies with.
Thanks in advance.
flymia
Re: PMDG 747 vs 777 - What one to get?
Mon Aug 21, 2017 3:28 pm
Both are fantastic and at some point you will want both. The 747 is newer so it has some more options and things the 777 and 737 don't have. Though the 777 has great set of options as well.
What I like a lot about the 747 is this: In one package you get pretty much four different planes. 747-400 747-400F 747-400 Combi and 747-400ER. I also enjoy the older technology and more hands on approach. Its not as hands on as the 737 but its close. Also, I really like how you can make your 744 more modern with LCD screens or more retro with the CRT displays and non-electronic A/P displays, no auto start etc.. The 747 is a higher workload airplane compared to the 777. The 777 is a bunch of put in auto and go.
Both are for long haul flying. Though with Cargo you can fly anything you want too. The only downside of the 747 is that less real world airlines are flying them (if you like flying real world current flights) and the 777 does have more range, though with the 747-400ER how much more range would you need.
Also the 777 comes only with the LR and F model, while the much more popular 777-300ER is part of another package for additional money.
To sum it up: Want more of a work load with more things to do with technology like the 737 go with the 747 and lots of different options for the airplane.
Want a very modern aircraft, less of a work load but amazing airplane performance, range, and (if you get the 77W) more popular passenger plane, get the 777.
I have both, and I find the immersion with the 744 to be amazing. The 777 is fantastic, but if you told me I could only fly one on FSX for the next year it would be the 744.
767333ER
Sun Aug 27, 2017 5:28 am
I have all three of their most recent Boeing products and I enjoy all three of them.
737: I have to say of the three my least favorite is the 737 as it is the original of the three and slightly less detailed than the 777 and 747 in subtle ways and has a few small issues such as the ailerons being nautally tilted down slightly or the rudder being too responsive especially when decrabbing. The engines start slower than the real thing too. It is also the least customizable. The sound pack it comes with is is pretty good, but again compared to their other products, it is the least realistic. Some of the lack of features however is the 737's fault itself as it is quite primative compared to the 777 and 747. With that said it is quite easy to use and I enjoy it very much despite not caring for the 737 much as a plane in real.
777: This is the second of their products and it is noticeably newer than the 737 in a few ways. It is about as customizable as a 777 would be in real and they way they were able to replicate the systems and their functions is quite something. There is very little I could find fault with on this one. I have to say it is the easiest of the three products to use because the 777 is so much newer and more advanced of a plane in real. It has the built in checklists which are also very helpful. If you start the cockpit from a turnaround state, the setup is very quick and simple. The sound pack it comes with is quite realistic featuring the various sounds the 777 and the GE90 make inside and outside the cockpit. The only thing I wish I could have is the 777 "classic" and it's lack of raked wingtips and different engines because then if I wanted to fly a United 777-200ER for example I wouldn't have to use the fictional United 777-200LR. That's not a big deal though. It is a very stable and polished product and one I absolutely love using.
747: This is their newest product of the three and is very similar to the 777. It is somewhat even more customizable partly due to it being a newer product, but also because the 747 is. It features various different configurations and all three engine types used on the -400. The engines all sound different and very accurate and all have their own characteristics inside an outside the cockpit. The ground handling of this product is where they made a significant advance over the 777 and 737. It comes complete with various service vehicles and cargo loaders and air stairs. One other major difference is that unlike the 777 and 737 where the ground connections are instant on and off, on the 747 you have to request them and wait for them to connect. Despite having a level of automation between that of the 777 and 737, the 747 can be a bit confusing to use at first, at least after using the 777 and 737, as some systems can require a lot of switching and mode changing such as the fuel system which can get a bit confusing with multiple crossfeeds and override buttons. The sounds as I already mentioned are again very realistic for the most part and I appreciate on this on the buzzing of the fan blades on the engines fade away as you climb just as in real. The level of detail on it is so high that they have simulated even things as insignificant as the visual difference between equipping the #2 and #3 hydraulic systems with air driven or electric motor pumps as the air driven ones have a small exhaust grille on the engine pylon where the electric ones delete that. Another issue that I understand is due to they way they have set up the sound system is that all the engines sound like a GE90 starting up. It is an extremely stable aircraft other than when it sometimes freaks out in turbulence and shakes like crazy, but that might be a glitch and hey may have fixed it. There are a few other nitpicky things I can think of such as the aux hydraulic pumps not having a sound when they run or the fuel pump sound file not playing when the APU system automatically turns them on, but these may also have been fixed. There is a possibility that they may be making a 747-8 expansion at some point.
All in all, any of these PMDG products do not disappoint. One thing I wish they could add to all of them are features such as openable windows and a few other similar miscellaneous things you would find in a cockpit. I also wish that they would make more products such as a 757 and 767, but that many would be unrealistic considering how much work they put into a product. The biggest downside is the price, but the product certainly justifies it. If you are like me and like to operate real flights only with the correct type of planes, the 777 will take you much farther, if you don't care so much about that than the 747 is just as convincing. I think the 777 is my favorite by a hair as there is something about watching it's heavily computerized systems do what they do I find fascinating like the automatic initialization tests done when first powered up. I suggest you watch some videos on how they function before you make up your mind, something I can't really do which is why I have both. :D
Been on: 732 733 734 73G 738 752 763 A319 A320 A321 CRJ CR7 CRA/CR9 E145 E175 E190 F28 MD-82 MD-83 C172R C172S P2006T
AirKevin
Sun Feb 04, 2018 11:06 pm
They have confirmed that they are making one.
Captain Kevin
Andre3K
Tue Feb 06, 2018 4:19 am
I say avoid both and for half the price you can get ahold of the iFly 747 V2. It's $59.99 and does at least 95% of what the pmdg 747 does. www.iflysimsoft.com
BillMoto53
Tue Feb 06, 2018 6:50 pm
I've a small suggestion you may find valuable, ConcordeAlpha:
A number of Flight Sim enthusiasts stream their sessions/flights in the FSX channel on Twitch [ http://www.twitch.tv ]. Oh -- and don't be misled by the channel's name -- all of the popular Flight Sim software is used. Anyway, in my experience, I've found streamers there to be very friendly and open/willing to respond to viewer questions. And when asked, most will offer an opinion, as well. Clicking around the channel at various times of day should connect you with someone flying the PMDG 74 and/or 77. That way, you can see them in action.
Good luck -- and enjoy!
AirKevin
Tue Feb 06, 2018 9:06 pm
There's that, too. All of my recent streams have been with the PMDG Boeing 747-400, although I must point out that given my job, I don't really get a whole lot of time to stream, so I can only really do this when I'm at home.
Captain Kevin
