klm672
Downloading Off The Net For FS2K
Sun Nov 12, 2000 6:11 am
How do I download Panels/Scerenry to FS2K? I have Winzip. I can download Planes but that is it.....
N1641
RE: Downloading Off The Net For FS2K
Sun Nov 12, 2000 6:48 am
http://www.simviation.com/fsdhelp.htm
Sun Nov 12, 2000 12:31 pm
Unzip the file you downloaded it, look inside it and you will probably find four more folders named model,texture,sound and panel.paste the whole folder into the aircraft directory thats found in the Flight Simulator folder. Next use the converter and convert the .air file found in the folder of the aircraft you downloaded. Same thing for add on panels, simply unzip the panel, put the guages that came with the file in the guages folder and paste the bitmap(s) along with the panel.cfg file into the panel folder of the desired aircraft.
