777 Take Off In FS2k
Thu Mar 15, 2001 9:03 pm
I have a question for those of you flying B777 in FS2000:
What power setting and flap setting do you like to use for t/o? And when do you retract flaps?
KALB
RE: 777 Take Off In FS2k
Thu Mar 15, 2001 11:09 pm
I rarely fly it with a full fuel load especially if I'm doing a short to medium flight (600-2000 miles). I generally use flaps 10 or 15. Turn on Flight director and auto-throttle, select TO/GA button on the throttle quadrant. Once engines have stablized, I release brakes and rotate at 160 knots indicated.
Fri Mar 16, 2001 3:11 am
Depending on the load and wind factors, the 777 uses anywhere from Flaps 10 to Flaps 20. The 747 also uses these falp settings as well.
Both planes use Flaps 30 for landing.
