N139J
FS2K Eng. Trouble
Sat Mar 24, 2001 10:08 am
Can anyone help me? I was just flying MIA-ATL. Nearing FL480 (Cruise Alt), I noticed my IAS falling bellow 240. I checked autopilot to see if I had changed it from the 310knts I had orginally entered after passing FL010. Nothing worked, so I diverted to an airport I found in GPS, making an emergency landing. The aircraft, once off autopilot, was very erratic and out of control. I was able to calm it before landing, but I was off the RW due to the weird flying. Does anyone know what happened? All help is appreciated.
-N139J
Jason
nbirger
RE: FS2K Eng. Trouble
Sat Mar 24, 2001 4:13 pm
Jason,
That seems like a very high flight level.
What aircraft were you flying?
You also have to remember that the higher you are flying the thinner the air is. So your KIAS (knots in air speed) will be far less than normal. When I fly a 747 at FL390 the KIAS is usually around 275-285 which is around mach .84 (the cruise speed for this a/c). The best tip I can give you is to switch over to mach hold instead of speed hold on the autopilot. For the HEAVIES use around mach .84. This is far more accurate at higher altitudes.
Hope that helped.
-Nick
B737-112
Sat Mar 24, 2001 4:54 pm
I agree with Nbirger, the highest I ever cruise is FL410.
N139J
Sun Mar 25, 2001 7:46 am
I was flying a Learjet 45A, max cruise FL530. I will try that though (mach hold). Thanks.
-N139J
Jason
