airbus_330_340
What Is NAVhold And APR Hold In FS2000
Sat Aug 25, 2001 1:24 am
I have noticed on all planes there are two other buttons called NAV hold and Approach Hold how do you use them. I know approach hold is for when you land but how do you use it? -thanx
VgnAtl747
RE: What Is NAVhold And APR Hold In FS2000
Sat Aug 25, 2001 2:45 am
I never use NAV, but APR is used below:
APR::
Tune in the ILS for the runway you want to land at in Nav1. Once the ILS is active, you will hear the beeping as long as you have turned the radio on. Then turning on APR will alight you with the runway, and extablish you on the glideslope. I always use this, and I never miss the centerline when using it.
Work Hard. Fly Right. Continental Airlines
VgnAtl747
Virgin Atlantic Flight Simulators - Lets Go!
Sat Aug 25, 2001 2:51 am
Did you know that you can redeem your Flying Club miles for simulator time in Virgin's Flight Simulators?
Below is an excerpt from the Redeeming your Miles page on Virgin's website (http://www.virgin-atlantic.com/main.asp?page=3.3.6&rlg=1)
Partner -- Virgin Atlantic Airways
Reward
Flight simulator session (Sussex, UK). Experience the thrill of flying and landing a Boeing 747 at Hong Kong, New York or any other Virgin Atlantic destination.
Terms & Conditions
Unless otherwise stated, all activity rewards are per person and do not include transport, meals, accommodation or insurance. Other terms and conditions may apply and should be checked at the time of reservation.
There is a catch though - you need 40,000 miles.
crank
Sat Aug 25, 2001 2:57 am
NAV hold is for the ILS approach but be wary, on the very accurate panels it sometimes stands for autoland.
To do an ILS approach, you have to be alligned with the runway, and you have to have the frequency of the runway in NAV 1 (in the radio stack). There will be 2 purple needles that will guide you to the runway, 1 going up and down, thats for maintaining the glideslope, if its going down, you are too high, if its going up you are too low. the other one is going right and left, this one is to be aligned with the runway, if its going left, turn left a bit, its going right, turn right a bit. When you're at 300 ft. you shut down the autopilot and land manually.
APR switch is a kind of shitty autoland, it will hold the glideslope and runway heading for you but dont think of landing the plane with that switch on, you are going to smash the plane on the ground. I dont recommand on using it.
Hope this helps
