aps
AirNav Acars
Thu Jan 03, 2002 10:31 pm
Not sure if this has been asked B4 but HELLLLLLLLLP !!!!  Crying
When you are real time tracking flights .. how do you make the aircraft label on the map stay for longer than 15 mins.. is there a menu to set the time that the aircraft label shows for ???  Nuts
thanks in advance
FSDownloads
RE: AirNav Acars
Sat Jan 05, 2002 6:26 am
Hi,
I'm assuming your using AirNav 3.1...ok,so goto the track menu,then View Standby Flights, then a side menu opens and you can select how long you want standby flights to remain on the map. Hope this helps.
aps
RE: AirNav Acars
Sat Jan 05, 2002 7:11 pm
Thanks very much for your help ...  Smile
Users browsing this forum: OA412 and 8 guests
