Bernard Shakey
TraficTools V1.1
Sun Jan 20, 2002 10:13 pm
I noticed that TrafficTools V1.1 is now available (I saw it at avsim). What adjustments have been made? Could it be a fix for the gear-up taxi on 3rd party aircraft? I'm at work, so I can't download it and find out.......
Mindless drifter on the road, Carries such an easy load
TropicalSQ744
RE: TraficTools V1.1
Mon Jan 21, 2002 12:17 am
The description of TrafficTools v1.1 from avsim
File Description:
Description: This package contains a de-compiler and compiler for the FS2002 traffic.bgl file. That file contains the flight plans that control the movement of all AI aircraft traffic. You can view and modify existing AI flight plans or create new ones. You can change aircraft models, tail numbers and flight numbers. You can create new AI flight schedules and increase or modify the type of traffic at selected airports and generally make the AI traffic 'do what you want', within limits. Update:Flight plans can now be programmed for specific days of the week and flight cycles can run over 24 hours. Problems with the tools not finding FS2002 on some machines have been fixed.
TropicalSQ744
SIN/WSSS
DMK(TG773/772) PEN(SQ772/MH734) PER(QF333) PEK(CA763) HKT(MI320) HKG(SQ744) ICN (OZ333), CJU,TAE(OZ734) TPE(3K320) KUL(T
Bernard Shakey
Mon Jan 21, 2002 12:37 am
Thanks Trop.....
sounds like a good upgrade to avoid "parades" at 34,000 feet! Hopefully the gear up taxi will get fixed sometime soon.
jwenting
Mon Jan 21, 2002 2:02 am
The 'gear up taxi' has nothing at all to do with the flightplan. It cannot be fixed without changing the visual model of the aircraft. Only the aircraft designer can do that.
I wish I were flying
Users browsing this forum: Bing [Bot] and 1 guest
