SPRINGBOK
TrafficTools Help!
Wed Jan 23, 2002 6:21 am
Hi everyone, i have read the readme file many times but still cannot get my added aircraft to appear as AI aircraft on flight plans or even if i create my own flight plans using Traffic Tools Version 1.1.
I simply added the desired aircraft title to the flight number e.g AC#26,464,"British Airways 767-300ER", as it suggests in the readme file(I think), but still no appearance when i am at the correct airport and the correct GMT time, anybody had this problem?? its got me.
Any help much appreciated!!
SPINGBOK
Dash8King
RE: TrafficTools Help!
Wed Jan 23, 2002 8:26 am
Do you still have general traffic? I didn't and had to re install the whole flight sim program.
TropicalSQ744
Wed Jan 23, 2002 8:59 pm
AI aircrafts in FS2002 needs to be made in gMax. And currently, there are very few of them out there... The ones made from gMax are the IL-86(recently released) and A320.
TropicalSQ744
SIN/WSSS
DMK(TG773/772) PEN(SQ772/MH734) PER(QF333) PEK(CA763) HKT(MI320) HKG(SQ744) ICN (OZ333), CJU,TAE(OZ734) TPE(3K320) KUL(T
GOT
Thu Jan 24, 2002 4:44 am
Is "British Airways 767-300ER" exaxtly what it says in your a/c .cfg file? Otherwise you should change it.
TropicalSQ744:
There must be more than these planes available. I haven't tried so many so far, but atleast AA 727 is working, but the landing gears are not out  Sad.
GOT
Just like birdwatching - without having to be so damned quiet!
SPRINGBOK
Sat Jan 26, 2002 2:38 am
THANKS FOR THE REPLIES!!!
Still isnt working though , anybody else ??
THANKS AGAIN
SPRINGBOK
Tbird
Sat Jan 26, 2002 5:54 am
Greetings:
I had the same problem you did, finally gave up. Until an easier program comes out to add your own AI flights I'll be content with repainted 737's, 777's, 747's, and MD-80's.
Thanx
Tom
Bernard Shakey
Sat Jan 26, 2002 8:42 pm
the repaints available are making things more realistic. I've spent a lot of time lately going through the entire data base to substitute more appropriate aircraft and flt numbers on the base AI set. Also, the NW 747-400 I've got is a frame rate killer.
Mindless drifter on the road, Carries such an easy load
