cramos
"Sound File Ungueltig"?
Fri Feb 08, 2002 10:28 pm
Has anyone ever had a error message comeup when you load an aircraft that says "Sound file ungueltig"? I know "ungueltig" in german means "not good" but how is that when my sound file is from the default 737-400. Also, when I try to set my fuel selectors to ALL, they just go back to OFF when after the error message described above shows. I'm using FS2002, can anyone help me out on this? Thanks.
petertenthije
RE: "Sound File Ungueltig"?
Sat Feb 09, 2002 2:44 am
I have had, well actually still have, the same error. I use FS98. I get this message when I start up some of the downloaded planes. Curioulsy, not all planes have this. Just some of the downloads.
Attamottamotta!
jwenting
Sat Feb 09, 2002 3:15 am
That is because only some downloaded planes use the gauge that produces the error. It is a GPSW gauge I think, and the files are missing.
The error is NOT in the aircraft, but in the panel. Put in another panel and you should be OK.
I wish I were flying
cramos
Sat Feb 09, 2002 4:32 am
Yes I just solved it. It is because some file was missing, I was able to install all files this time, and it worked. It's probably a sound that is not being loaded by the panel.
petertenthije
Sun Feb 10, 2002 9:59 pm
Attamottamotta!
cramos
Mon Feb 11, 2002 8:09 am
You got it fixed Petertenthije? If so, I'm glad I was of help!  Big thumbs up
xtristarx
Tue Feb 12, 2002 7:49 pm
i also use good ol'FS98 and i have the same problem when i use my downloaded A318/19/20/21, i also think its in the panel. but when i click the error message away it still works normally.
regards
xtristarx
cramos
Tue Feb 12, 2002 9:32 pm
It's a sound file not found by the panel. This is the problem I believe. It worked on mine. Although it still doesn't matter because my other posts are about the other problems (see Engine Tmp. Gauge, and 747-200 Start-up). I've put it on the side for now.
