mika
How To Dial In Com Frequencies Yourself?
Mon Feb 18, 2002 4:36 am
I have read somewhere that u can instead of letting the ATC system dial in the right frequency every time u are handed over by ATC, do it yourself manually in the radio stack. Is this true and where does one change this setting? Would be more realistic.
jwenting
RE: How To Dial In Com Frequencies Yourself?
Mon Feb 18, 2002 4:58 pm
yes, you can (in fact I usually do so).
Open the radiostack on the panel (if needed, the radios could be in the main panel) and change COM1 to the new frequency.
You can even buy a box you can put next to your screen where you turn dials to change the frequency like on a real panel.
I wish I were flying
