Dash8King
How To Open The .CFG File?
Tue Feb 26, 2002 2:26 am
I have replacement textures but can only replace the defualt 3. I remember reading on here that you can get more if you open the .cfg file. So can anyone tell me where is this file is and what code to I paste?
Thanks a lot
dc-10 levo
RE: How To Open The .CFG File?
Tue Feb 26, 2002 2:32 am
I had some trouble with this too.
Anyway, open up notepad and then just find your aircraft cfg. file.
It's really easy when you get to know it a bit better.
Hopefully someone else will reply and give you a little more info on this.
DC-10
crank
Tue Feb 26, 2002 2:34 am
you can open up the .cfg files with Notepad (Start-Programs-Accessories-Notepad)
Dash8King
Tue Feb 26, 2002 2:43 am
Well I tried to change the ATC name and I will see if that works thanks, but if anyone could help me with adding more then just 3 textures that would be great!
crank
you beat me to it DC-10!
Dash8,
you can have more than the 3 different textures if you want, you'll just have to create another texture called texture.4 or any other word/number as long as the word texture is there, for example:
[fltsim.3]
title=Boeing 737-400 Paint3
sim=boeing737-400
model=
panel=
sound=
texture=4
checklists=
kb_checklists=Boeing737-400_check
kb_reference=Boeing737-400_ref
atc_id=NC-FRYL
atc_airline=Air Canada
atc_flight_number=1123
ui_manufacturer=Boeing
ui_type=737-400
ui_variation=OrAir Canada
description=One should hardly be surprised that the world's most prolific manufacturer of commercial aircraft is also the producer of the world's most popular jetliner. The 737 became the best-selling commercial jetliner worldwide when orders for it hit 1,831 in June 1987 (surpassing Boeing's own 727 as the previous champ). However, it wasn't always that way\s in the first few years of production, there were so few orders that Boeing considered canceling the program. They didn't, and the airplane has more than proven itself in over three decades of service.
as you can see above, the line texture has a number 4 next to it, it refers to my texture folder with the Air Canada textures in it, which is called texture.4
Hope this helps
Dash8King
Tue Feb 26, 2002 2:45 am
Yes ok I see what you did, I will try that later thanks a lot crank!
Dash8King
Can't Get It To Say Westjet
Tue Feb 26, 2002 6:23 am
I have gotten it to say Delta Airlines but I can't get it to say Westjet here is what I have maybe someone can see what I did wrong
[fltsim.0]
sim=Boeing737-400
model=
panel=
sound=
texture=
atc_id=N700MS
atc_airline=Westjet
ui_type=737-400
ui_variation=Westjet
description=One etc,etc
[fltsim.2]
title=Boeing 737-400 Paint2
sim=Boeing737-400
model=
panel=
sound=
texture=2
atc_id=N700MS
atc_airline=Delta
ui_type=737-400
ui_variation=Delta Airlines
So what did I do wrong?
crank
Tue Feb 26, 2002 6:27 am
maybe you didn't add the name Westjet in your airline.cfg list?
Dash8King
Tue Feb 26, 2002 6:35 am
Nope, haha and where would I find that list?
crank
Tue Feb 26, 2002 6:39 am
it's in your FS2002 aircraft folder, I'm not sure it's gonna work but it might.
You can also download a list with over 300 airlines from flightsim.com
Dash8King
Tue Feb 26, 2002 7:18 am
Yea I put it in already but it didn't work oh well I have another question I can't get my southwest 737 to appear
[fltsim.3]
sim=Boeing 737-400
model=
panel=
sound=
texture=3
kb_checklist=Boeing737-400_check
atc_id=N700MS
atc_airline=Southwest
ui_type=737-400
ui_variation=Southwest Airlines
description=One etc, etc
Now when I put paint 3 it showed on the list in the aircraft directory but when I clicked on it-it said that paint 3 is not a paint or something like that. Where do I go to add paints?
Thanks and sorry for all the questions I am not to computer literate
Craigy
Wed Feb 27, 2002 8:41 am
In the example below, all the bold entries must be unique for each variation and the [fltsim.X] must follow on consecutively 0, 1, 2, 3, 4 etc.
I find that the title needs a unique name too, hence the Paint1, Paint2 etc.
Craig.
[fltsim.0]
sim=Boeing737-400
model=
panel=
sound=
texture=
atc_id=G-BVNN
atc_airline=Speed Bird
ui_type=737-400
ui_variation=British Airways
description=From the most successful family of jetliners ever built comes the 737-400. This can be your entry into virtual airline flying. Whether you're making short-haul or longer domestic flights, the 737-400 is a versatile and efficient airplane. See the Aircraft Information section of Help for tips on flying this aircraft.
atc_heavy=0
[fltsim.1]
title=Boeing 737-400 Paint1
sim=Boeing737-400
model=
panel=
sound=
texture=1
atc_id=G-BVNO
atc_flight_number=886
atc_heavy=0
ui_type=737-400
ui_variation=British Airways 'Benyhone Tartan'
description=G-BVNO, a Boeing 737-4S3, delivered 30th June 1989. Currently painted in the Benyhone Tartan colour scheme.
Dash8King
Wed Feb 27, 2002 9:20 am
Yes but do you know what I did wrong on the one above, I downloaded an Air Canada one which had it layed out already and it works great! I get the name to apear on the list but when I click to fly it-it says that I am using the wrong paint or something so is there anywhere to add a paint i.e. paint5 or something?
Craigy
Wed Feb 27, 2002 10:17 pm
When you add a line TEXTURE=X then there must be a corresponding folder called TEXTURE.X which contains ALL the textures for the aircraft.
Sometimes downloaded replacement textures only include the bitmap for the fuselage, and not all the detail ones like wheels etc.
Try copying an existing texture folder and renaming it to the appropriate number. This should then work, except it will be the old texture.
Then copy the new texture file(s) to that new folder, overwriting what is there already.
If you are still having problems, send me an email on craig.hendley@btinternet.com as I can explain better if I can email a screenshot as an example.
Craig.
Dash8King
Wed Feb 27, 2002 11:34 pm
Well thanks a lot for the offer there craigy but I did something that works! I just took the defualt one I got with my AC737 and changed the info on it and then copy and pasted into 737 files!
Well thank you all for your replies its been a tough few days but we did it!
