BA
How Much Does TTools Affect Frame Rates?
Mon Mar 11, 2002 12:12 pm
I know it depends on how many flight plans you assign (how many aircraft around you at the same time), but in general how does it affect frame rates?
My guess is A LOT.
Any feedback would be greatly appreciated.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
RE: How Much Does TTools Affect Frame Rates?
Mon Mar 11, 2002 12:18 pm
I used to suffer frame rate lost from AI traffic. After i use only IFR trafic for ATC, the frame rate returns to good shape. Now, i have more room to add more flight plan.
Sen
mika
Tue Mar 12, 2002 6:52 am
Traffictools itself doesn't impact frame rates, it's the planes you add with it. I recently added a AA 732 which would show lately, was a killer on frame rates, so i replaced it. When i add new planes i usually take them out to a lone airfield somewhere with no other traffic or anything and then check what kind of frame rates i get with them when just letting it sit on the rwy. Then i compare that to the default AI planes and if it differs to much, the new plane gotta go.
